Question about IBM ThinkPad 600X Notebook
Trouble starting laptop
I am getting an error message 0175crc1 bad when i switch on the power button of laptop, please assist.
Thanks,
Anitha
    Problem Solver:
  • 16 Answers
CRC= real time clock. 0175 means your eeprom data was lost. Solution? Check the 3V battery under the ram cover.
Replace battery then set date and time. If done correctly the machine should work. If the machine will not work after the above suspect the System board. It is almost always the CRC battery though.
Posted on Feb 22, 2009
I'm getting a door error "dr" on my ATF6700SF0 washer. How can I determine whether to replace the door lock assembly or the control board?
Hi Curt, this is AP
I understand you are having trouble with an error code on your Frigidaire front load washer. On your particular model, ATF6700FS, the error code "DR" indicates that the door is open or there is a problem with the door. If you know the door is not open you should check the door switch and wiring. If you need assistance with replacing the door switch I would recommend contacting an authorized technician in your area. I hope this information proves helpful to you, thank you for the post.
Thanks,
Mar 29, 2014 | Frigidaire ATF6700FS Front Load Washer
Laptop error F3-F200-0002
First, I recommend you call Toshiba support. Usually this happens because Toshiba may install some crapware with the laptop at first to control all part of the Hardware.
If you still have your recovery partition that the computer came with you can do this:
1. Initially you keep hold the power button for around 5 to 10 seconds to turn off your system. Keep in mind that keep holding the power button force the system to turn off. But any of the unsaved data will be lost.
2. At the similar time press and keep hold the zero key simultaneously, now push the power button one time to switch on your system.
3. While the screen is get appeared then free the 0 key.
4. If it any message to select the 32bit or 64bit operating system then you click Next button.
5. When provoked by the warning screen; click on to the Yes button to keep continue with the system recovery.
6. In that choose Recovery of Factory Default Software from the menu and then hit it off on the Next.
7. Choose Recover to out-of-box state option from certain options and then click Next button once again.
8. Understand and recognize this final warning screen.
9. Now finally click Next to start recovery
Feb 03, 2013 | Toshiba Satellite Pro C850-10N 15.6-Inch...
When I turn on my brother mfc 8440 I received this message in the screen : Error 6A
To clear the error, the procedure is as follows:
1. Turn off printer
2. Hold down MENU button on front panel and turn on power while continuing to hold.
3. Release button after 5 seconds (after the Please Wait message)
4. If error still occurs:
5. Press 91
6. If error still occurs:
7. Press 99
This should clear the error.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 05, 2011 | Office Equipment & Supplies
Error message F5E0
Hi
Thanks for using FixYa. This error means that you’ll need to check the door latch/switch and replace the part that has gone bad.Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | KitchenAid Ovens
My xbox 360 keeps freezing up on start up and while playing. I often get an E71 code error. I have tried clearing the memory Cache. Doesn't seem to help. What else can I do.
With the unit powered off hold down the sync button. Hit the power button and continue to hold the sync button until it boots up to dashboard. This should clear out any bad updates causing that error message.
Jan 08, 2010 | Microsoft Xbox 360 Console
My acer aspire 5920 will not power on!
Hi
Thanks for using FixYa. You will need to reset the Laptop if it is not starting up. Follow the procedure as under to reset it---
Remove all connections to and from the laptop. Now remove the battery and press and hold the power on button for 2 minutes. Release the power on button. Slip in the battery pack. Plug in the power to the laptop and to the wall. Please do not plug in any other devices and now try the Laptop powering it on to resolve the issue.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 15, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 5920 will not start up will turn on and acer screen appears followed by a window that says windows recovery error any ideas?
Hi
Thanks
Rylee
Sep 30, 2009 | Acer Computers & Internet
F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Thanks
Rylee
Aug 10, 2009 | Kenmore Kitchen Ranges
Hp compaq 6820s starts for a few seconds and than shuts down
if the problem is from the power button.. check the power button. if powering its means not power button problem.. and also check the cpu fan if working or not... open you laptop if you can't bring to the shooroom or call qualified laptop technician to check you laptop..
Jun 15, 2009 | HP Compaq 6820s Notebook
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
IBM ThinkPad 600X Notebook Logo
70 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
