Dell P780  17 in.CRT Conventional Monitor
Problem for Dell P780 (White) 17 in.CRT Conventional Monitor
Monitor is working out of scan range
By Troy on Mar 30, 2006
When using Microsoft Word, the computer freezes and the warning box states that the monitor is working out of range. How do I correct this problem.
Same Problem
Sep 03, 2008
-   Mine blacks out on every page scroll in Word. -   bluechip0309
Aug 07, 2008
-   My Monitor says 'out of range' and i cant get it off-   SarahKate
Jul 17, 2008
-   I use 200p4 monitor with Intel GMA950 onboard VGA. It works good on Vista & XP. but I also use Mac OS X. Unfortunately It didn't work on Mac OS X. I Test on another monitor, it works good in same environment. I don't know what to do. Help me. -   jwlong
Jul 16, 2008
-   The monitor displayed a message 'Scan ot of Range"
XYZHz/YZXHX-   Lonelinesssu
Jun 30, 2008
-   MY MONITOR SAYS INPUT SIGNAL OUT OF RANGE AND IT WON'T CLEAR OFF MY SCREEN -   Guest
Best Solution
posted on Sep 04, 2007
Very Helpful)
Guest
Rank: Apprentice  Computers & Networking  Expert
Rating: 0%, 0 votes
Your monitor cannot handle the video card's resolution. I had the exact same problem and I was using a 10-year old monitor. Once I switched the monitor out with a new one, the error message went away!
Solution #2
posted on Sep 03, 2007
Very Helpful)
sunligred
Rank: Master
Rating: 78%, 85 votes
IF URS OPERATING XP ,2000 WILL GO TO SAVE MODE RUN URS COMPUTER IN TO LAST GOOD KNOWN CONFIGURE NOW SHOLPED URS PROBLEM...
Was this helpful?
Yes
No
Solution #3
posted on Aug 26, 2008
Helpful)
Creon
Rank: Apprentice
Rating: 88%, 3 votes
It probabily happens after you change the settings of display in control panel (windows), if so restart the machine and press function key <F8> after memory test and you shoud get to the startup menu, choose VGA mode and undo the changes in display that you have made.
Best Regards
Creon
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #4
posted on Mar 30, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3631 votes
A few options:
1. Video card is dying, Swap it out, see what happens.
2. The video card has decided to set a resolution or refresh rate that exceeds the monitor spec.
3. You can try loading a proper driver for the monitor and see if that helps.
4. The problem sometimes happens when running 3D games. I usually solve it by selecting *Adapter Default* in advanced display properties (which looks crap) and the upping the resolution to 85Hz I then run the DirectX utility and test this using AGP/Direct3D rendering (if I'm going to have the Out of Range/Adjust Timing Frequency it happens when I run these tests). Anyhow try
the above and make sure you've tried to select the correct monitor.
Good luck
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
Somewhat Helpful)
De Guyver
Rank: Guru
Rating: 85%, 271 votes
replace video card, or have it serviced if you like.
Was this helpful?
Yes
No
Solution #6
posted on Jan 02, 2009
Very Helpful)
EAR1
Rank: Apprentice
Rating: 100%, 2 votes
when booting up press F8, select start in VGA mode. Then itgave me the option to fix the resolution and it worked.
Was this helpful?
Yes
No
Solution #7
posted on May 04, 2008
Not Rated)
dhoffm5
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem and i downloaded microsoft "SILVERLIGHT"
and now it works just fine !
http://www.microsoft.com/silverlight/resources/install
david.. redding calif
Was this helpful?
Yes
No
Solution #8
posted on Mar 20, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Solution from Silly Girl doesn't work.
Solution #9
posted on Feb 06, 2008
Not Rated)
Guest
Rating: 0%, 0 votes
Unplug the power cord to the Monitor for about 10 seconds and they plug the Monitor back into its outlet, and try turning the Monitor on and see what happens.
Solution #10
posted on Nov 30, 2007
Not Rated)
Guest
Rating: 0%, 0 votes
Replacee the control board i had the same issue with a 17" samsung, replaced the control board and works like a dream.
Popular Solutions for Dell P780 17 in.CRT
Questions and Unsolved Problems for Dell P780 17 in.CRT
Do you recommend Dell P780 (White) 17 in.CRT Conventional Monitor?
Answer
Answer
my medion monitor 7319 blink when trun on and it tack up fifteen min. to come on
Answer
how do I connect my lenovo monitor to a sony dvd player as a monitor
Answer
Describe your Dell P780 17 in.CRT Conventional Monitor Problem Monitor automatically goes into... (More)
Answer
Alchacpsaudala give anything and give the message out of range is resolved
12 Other Users Have The Same Problem - Continued
Comment by Alison7, posted on May 12, 2008
X9G OUT OF Rangs pops up. Any Suggestions?
Comment by Guest, posted on May 04, 2008
I had this same problem "out of scan range" but turning off the computer
manually and back on seemed to temporarely fix it,
I downloaded microsoft "silverlight" its free, and it seems to have repaired the problem !
david ,, redding calif
Comment by Guest, posted on Apr 14, 2008
when turning on the computer, the monitor screen turns black and in a blue box says out of scan range
Comment by Smilespwp, posted on Feb 13, 2008
Samsung Syncmaster 713MB 17" Monitor - Operates OK for about 20 minutes at initial switch on then video signal from PC dissapears to be replaced with a floating box stating that the input signal resolution and sync is wrong. Once this occurs, the video from the PC cannot be displayed until the monitor has cooled down.
Totally inoperative in this condition.
Comment by Guest, posted on Jan 08, 2008
nec lcd1712 blue bow "out of range"
Comment by Guest, posted on Jan 07, 2008
the computer monitor reads, " signal out of range"..... H:68. 5KHz V:84. 8Hz MODE SHOULD BE BELOW 1280X1042/75Hz
Comment by Guest, posted on Dec 21, 2007
out of range signal in the center of the screem
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
