Question about Amana Heating & Cooling
Boiler doesn't fire up. 25 years old Amana outdoor boiler model #3612M-A Mfg # P68191-1F,It had leak in pump housing and replaced, replaced igniter ,but no fire, no leak in system ,pump are keep running How to remove air from system and why it doesn't fire up , like to have step by step diagnosis chart Thank you.
  • 1 more comment
  • shima Sep 10, 2008
    I having trouble with this Amana outdoor boiler for 2 or 3 years.I have replaced igniter 3 times( I have this house for 5 years) also I replaced fire tube unit with good used one,
    I don't know how to remove air from system or how to diagnosis system, I don;t like to keep replacing parts it will cost too much and heating tech cost very high and sometime they doesn't care and keep charging bills, PLEASE HELP
    I will try tomorrow at day light, I will remove fire tube unit and give it clean up and jump wire at thermostat feed wire.
  • shima Sep 11, 2008
    no I was looking to have a step by step diagnosis chart. I will call professional to fix it .
    Genius:
  • 1,665 Answers
Have a look at general maintenance tips below
Boilers Inspection and Maintenance Tips
Posted on Sep 10, 2008
    Scholar:
  • 163 Answers
Ignitor seems to be faulty . have it checked before refiting it.
    Genius:
  • 1,011 Answers
    President:
  • 1,952 Answers
How a Central Air Conditioning System Works
Facts:
  • The typical central air conditioning system is a split system, with an outdoor air conditioning, or "compressor bearing unit" and an indoor coil, which is usually installed on top of the furnace in the home.
  • Using electricity as its power source, the compressor pumps refrigerant through the system to gather heat and moisture from indoors and remove it from the home.
  • Heat and moisture are removed from the home when warm air from inside the home is blown over the cooled indoor coil. The heat in the air transfers to the coil, thereby "cooling" the air.
  • The heat that has transferred to the coil is then "pumped" to the exterior of the home, while the cooled air is pumped back inside, helping to maintain a comfortable indoor temperature.
  • Central air conditioning can also be provided through a package unit or a heat pump.
Benefits:
  • Indoor comfort during warm weather - Central air conditioning helps keep your home cool and reduces humidity levels.
  • Cleaner air - As your central air conditioning system draws air out of various rooms in the house through return air ducts, the air is pulled through an air filter, which removes airborne particles such as dust and lint. Sophisticated filters may remove microscopic pollutants, as well. The filtered air is then routed to air supply ductwork that carries it back to rooms.
  • Quieter operation - Because the compressor bearing unit is located outside the home, the indoor noise level from its operation is much lower than that of a free-standing air conditioning unit.
ed.
  • mohammed marika thambi
    mohammed marika thambi Sep 10, 2008
    Every air conditioner is equipped with at
    least two motors, the compressor and the fan motor. It is possible
    for the fan motor to be defective and the compressor to be running.
    If this is the case the unit will appear to be running and may even
    sound "normal" but no air is blowing out the front or back of the
    unit. If, after removing the cover of the unit you discover the fan
    blade is very stiff and difficult to rotate, the fan motor should
    be replaced. If the fan blade turns freely the circuit powering the
    fan motor will require electrical troubleshooting. It will be necessary
    to have a qualified technician locate the cause of the problem, which
    may be either a problem with the capacitor,
    the selector switch or the motor itself.
  • 3,037 Answers
It just needs a cleaning .. I bet it hasn't been serviced in years since you had a leak.
.. just like a car .. you heating equipment needs regular maintenance.
.. get a certified technician to give it a tune-up.
.. the burner assembly needs to be removed and cleaned .. as does the pilot tubing, flame sensor, and heat exchanger.
    Genius:
  • 1,847 Answers
You could eliminate the boiler thermostat by temporarily removing the two wires from the rear and connecting them together. The thermostat is in series with the live feed to the gas control valve.
Just because you replaced the thermocouple last month doesn't not mean that this is not faulty, can you measure any output voltage from it? Has the nut loosened?
Firebird boiler will start up but stops & will nor restart
You may have a carbon build up on the ignition probes but this will normally cause a lock out. It may be that the circulating pump is faulty. Ie boiler fires up but due to no circulation it shuts down on the boiler stat and as the heat remains in the boiler it will not fire again until the heat has dissapated. Changing a circulating pp can be done by a confident DIYer but remember due to new legislation the old three speed pps are no longer available. You will need to purchase a modulating pump to match you existing pump. Old and new pump threads and spacing a are the same.
Mar 11, 2014 | Computers & Internet
Tip
The extra benefit of a Modulating Boiler
You're looking to install a new hot water boiler or replace your existing boiler. You come across something called a "modulating" boiler. You wonder what on earth that means. I will attempt to explain some of the features of a modulating boiler.
How nice would it be if you could have your boiler make just enough heat to keep your house warm and nothing more? Your thermostat tells your boiler that you need heat in the house. The boiler starts up and heats the water that runs through the pipes to heat your house. The water does not heat up to temperatures that are more than just warm. But you notice that the temperature in your house is staying right where you want it to be.
This boiler is no ordinary boiler. It knows what the temperature is outside and varies your water temperature to make just the heat needed to keep you comfortable. The modulating boiler also runs much more then a normal boiler would but you can see by your gas bill that you are getting great efficiency from this thing.
The feature that makes this wonder so great is that it has the ability to vary the fire that heats the water up and down so that the water temperature stays precisely where the computer brain in the boiler wants it to be. This temperature is figured by measuring the outdoor temperature and changing the water temperature based on that. The colder the weather is outside, the hotter the water is going through your system.
With a system like this you will notice that your heat will run longer and still not cost anymore money. This makes you more comfortable. The modulating boiler will give you just enough heat to keep you warm without wasting much of the heat that a normal boiler would. This type of furnace will give you the most efficient heating possible on any given day.
Before buying a new heating system or replacing your old hot water boiler make sure that you check into a system that will modulate the fire and also vary your heating water temperatures according to the outdoor temperatures. This will save you money and give you a very comfortable heating system.
on Dec 08, 2009 | Heating & Cooling
Utica furnace hot water system problem
Check the heat Antisapator on the thermostat, or replace the thermostat.
Nov 13, 2013 | Heating & Cooling
Set up for heating and lighting pilot
When is the last time you had it serviced By a Tech?
Oct 24, 2013 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
Have a water leak inside boiler keeps putting pilot light out
Not good at all. Check for a fill level probe/float/sensor that may be acting up causing the unit to over fill, or you may be looking at buying a new boiler.
Feb 18, 2013 | Weil-McLain CGa-25-SPDN, NG, Gas Fired...
The boiler wont fire up and the blue light flashes once per second
Let's see what we can do to trouble-shoot this boiler--
First of all-- Are we talking about a Hot Water 'Boiler'-- In other words does this boiler heat water that circulates thru the house, to keep you warm?
Next-- What is your fuel?
Have you Shut the system down, to reset it?-- What happens when it comes back on again?-- Clicking sounds-- pumps trying to start-- solenoids trying to open, etc.-- Tell us what you observe-- so we can help you trouble shoot this problem.
Mack B
Jan 15, 2011 | Heating & Cooling
Chronotherm Three thermostat vs Buderus Logamatic Computer.
The outdoor thermostat senses the the temp of the outside air, and adjust the boiler water temp according to what it knows is best. The reason that the boiler is running longer is the old boiler used to be constantly sending 180ish degree water to the baseboard, now that water may only be 140ish degrees. The idea behind this is to reduce off cycle heat loss, as the greater the temp difference between the air temp and water temp, the quicker you loss heat. The theory in boiler run time is this, the less times it starts and stops, and the long run times will give you the best efficiency. Hope this answers you questions.
Sep 28, 2009 | Honeywell Power Humidifier: Furnace...
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
Baxi Boiler not firing, pilot light ok
first check the pilot is alight, it sounds like it is cause you can hear the boiler click. that click is the gas vale solenoid trying to open, if there is 240-230volts at gas valve when you here the click and pilot is alight the gas valve is broken. if you test for voltage look on the gas valve and see if its 240 or 24v obviously if it 24 v check for 24 volts, let me know
Nov 11, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
307 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
