Ok, you tell me I can refill it, and what to press after doing so. Any instructions on how to refill the cartridge would be greatly appreciated, and do you have to use canon refill ink, or can you use a universal ink?
SOURCE: reset Ink levels for canon mx310
I've heard that with canon there is a way around the ink-level chip monitoring on the cartridge by doing the following:
SOURCE: refilling of canon ink fine cartridge pg 41
reset the cartridge from the printer. there are a few steps to follow
SOURCE: Canon MX310 - refilling cartridge
Most canons have a chip on the ink cartridge that tells the printer the ink is empty so unless you reset that chip (which you cannont do), that newly filled cartridge will always read empty. This is how some printer manufacturer's thwart people saving money by refilling their cartridges.
thanks and please take a moment to rate as fixya.
SOURCE: How to change the ink in a Canon PIXMA MX310?
Note: - Do not attempt to reattach the protective tape once you have removed it.
- Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
*One
black cartridge and one color cartridge must be installed in the
machine in order for the printer to operate. It does not matter if the
capacities (Standard or High) do not match.
<1> The ink cartridge is not installed properly.
<2> The ink cartridge is installed properly.
Removing Ink Cartridges:
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
SOURCE: when refilling canon ip4500 cartridge they still show empty
I'm sorry you got that STUPID answer first. The Canon cartridges you use have a chip or small circuit board on the bottom front. You have to either reset that chip or get the reset chips from the place you get your ink. That little chip tells your printer how much ink has been used and once they are empty refilling doesn't help without a new or reset chip.
How to reset Canon MX310
printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold
power button also. Hold both buttons
together for 5 secs.
3. Still holding the power button, release the
stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now
say 'Service Mode').
5. Wait until the power button lights steady
green, then press the stop/reset button three times with a 3 sec space between
each press. On the 3rd press the
indicator should turn steady orange.
6. Press the power button once, (the orange
light should go off).
7. Open the printer and remove both
cartridges. Wait for 10 seconds. Replace the cartridges and close
printer. Wait for 30 seconds.
8. Press the power button, and wait until
printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper,
then ask you to set the language.
10. The page counter is now reset! Enjoy.
I have purchased refilled cartridges but cannot get the printer to recognise that they are full. Can you help?
