Question about iRiver iMP-450 SlimX Personal CD Player
Can't switch on
After 1 year of good prosperity, my IMP 450 is dead. I cannot switch on (neither on batteries nor AC adaptor) I even cannot turn charging on. I took bateries and adaptor from other one, but it's still the same problem. Sometimes (after about x100 pressing play button) it switch on, play music !...but going to shutdown after few mintues. Looks like something cuts power off. I've done nothing wrong with my IMP 450. It's just stopped working during normal using. I also have previous model (IMP 400) and using it for 3 years without any problems
  • Anonymous Mar 07, 2008
    I have the same problem. In the circuit are ewerywhere voltage, but I cannot switch on... Any ideas what maybe is the problem? Maybe the softwhere isn't good...
    Champion:
  • 277 Answers
Hi try this: take a small flat (watchmaker) screwdriver open the battries cartige an look for the springs that connect and holds the battries shive the screwdriver between the last coil of the spring and extend it (for better connection) check with brand new battries look inside the inlet ac adapter and look for a little silver tab shove the screwdriver inside and make some distance from its position (for better connectin) check with the ac adapter if that didnt worked then check the play button - maybe it got bad connection open the cd player look at the play button - there is rubber between the button and the board clean the connection with borad with some alcohol assemble it all toghter and see if good NO?? sounds like one of those "ghost in the machine" thing GOOD LUCK
Posted on Mar 30, 2006
Why My Inspiron mini will not start?
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check hoe the Power LEDs on the system, battery and AC Adaptor react. Then I can check and help you further.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron Mini 10 Notebook
Totally dead, replaced ac adaptor, which was dead too, did not help. still dead.
Hello, I am thinking that your battery needs to be replaced as well. Possibly because of the stress it took from your ac adapter issues. So, to check to see if the issue at hand is now your battery... 1) UNPLUG THE AC ADAPTER FROM THE LAPTOP. 2) REMOVE THE BATTERY. 3) PLUG THE AC ADAPTER BACK INTO THE LAPTOP 4) TURN IT ON.
If the battery was now the issue, your laptop should have turned on at this point.. If it did NOT turn on, then there is a different issue that we should troubleshoot. Let Me Know, ok?
Sep 10, 2010 | HP 6530b Notebook
Laptop doesn't turn on ...
remove ur battery change ur adapter
if not work there is short inside ur laptop
it is recomended to consult ur technician
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
Laptop won't staart up.
Yes, it should run off AC power even if the battery is removed. Sounds like either the motherboard or your AC adaptor might be failing. I would start by trying the AC adaptor with another dell to verify it it's not dead.
Good luck,
Raf
Nov 09, 2009 | Dell Inspiron 5160 Notebook
Battery will not charge compaq presario v5000
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Sep 20, 2009 | Computers & Internet
Does not start; no power indicator light
Take out the battery and then try the different ac adaptors. If you still get no lights on the laptop then the motherboard is bad and would need to be replaced. Just make sure that you know at least one of your ac adaptors are good.
If the adaptors have lights and they turn on then you know the ac adaptor your working with is good. Also make sure they are plugged into a good working outlet.
May 29, 2009 | HP Pavilion ze2000 Notebook
Battery on lap top is not charging
switch off - disconnect ac adaptor - wait 3 seconds - connect ac adaptor - repeat about 20 times.
Is charge light blinking when you connect ac adaptor?
Try reseating battery.
If battery is old (over 2 years) or heavily used then it may need replacing. They only last for 250-500 complete discharges.
Aug 08, 2008 | Evesham Computers & Internet
iRiver iMP-450 SlimX Personal CD Player Logo
206 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
