Question about West Bend 82306 Stir Crazy® Popcorn Maker
Cover craacked how do we get a new cover
  • Anonymous Oct 03, 2008
    How can we get the cover replaced?
  • 4 Answers
You can purchase a new cover through website focuselectrics.com
They bought out West Bend in 2003 and have replacement parts. However, the cost of a new cover plus shipping may equal almost the cost of just buying an entirely new popper.
Posted on Dec 27, 2008
How to replace front wheel bearing on 2003 kia sedona
Disassembly 1. Remove oil seal from front wheel hub. 2. Remove front wheel hub assembly with suitable tool.
bi6c021a.gif 3. Remove retaining ring. note_icon_eng.gif If the bearing inner race remains on wheel hub, grind a section of inner race until approximately 0.020 in (0.5 mm) remains. Remove race with a chisel.
bi6c021b.gif 4. Remove wheel bearing with suitable tool.
bi6c021c.gif note_icon_eng.gif Do not remove dust cover unless necessary. Do not reuse dust cover if removed. 5. Mark relative positions of dust cover and knuckle for proper reassembly. 6. Remove dust cover with a chisel.
ai2a023c.gif note_icon_eng.gif Do not remove wheel hub bolt unless necessary. Do not reuse wheel hub bolt if removed. 7. Remove wheel hub bolt with a press.
bi6c021d.gif Assembly 1. Press in new wheel studs. note_icon_eng.gif Front wheel hub press in either bolt turning or loosening by the torque of 108.5 lb•ft (147 N•m, 15 kg•m) shall not be premissible.
bi6c022a.gif 2. Mark new dust cover to match the removed dust cover. 3. Align mark on new dust cover with knuckle. 4. Install new dust cover with suitable tool.
bi6c022b.gif 5. Install new wheel bearing with suitable tool. 6. Install front wheel hub assembly with suitable tool.
bi6c022c.gif note_icon_eng.gif Use a new oil seal, and apply grease to seal. Install oil seal so that it is flush with knuckle. 7. Install new oil seal with SST(0K993 331 016).
Jan 12, 2013 | 2003 Kia Sedona
Tip
A New Hot tub cover will lower your Hot Tub Costs
A New hot tub cover will help you run your hot tub at a more efficient level. Lower your energy costs as the new hot tub cover will insulate better. The question is when do you need a new hot tub cover.
The best ways to know if you need a new spa cover or hot tub cover are the following:
  1. The hot tub cover weighs over 100 pounds.
  2. You need more then one person to remove the hot tub cover.
  3. The hot tub cover is ripped and torn past repair.
  4. Faded cracked and just aesthetically ugly.
  5. The seam in the middle is ripped past repair.
Can you fix your hot tub cover? Some things you can fix like rips and tears. You can take the cover to a local seamstress to repair. You can not fix a saturated hot tub cover, it needs to be replaced at that point. New Hot Tub Cover for the Fall and Winter
on Sep 05, 2015 | Home
Trying to change the plastic cover over side mirrors to a new one how do you take the two mirror covers off to install new ones,Infiniti M45 sport 2007
The cover needs to be pryed off gentle, if it breaks then it doesnt matter if you are replacing it, its held in by plastic clips molded into the cover, you will need to use a small plastic wedge to remove the cover from the mirror. take a look at the new cover and you will see how its held on.good day.
Apr 17, 2011 | 2007 Infiniti M45 Sedan New Cars
Craacked lcd screen on harmony880
No, it cant be repaird, you are going to have to contact logitech to see what they can do for you. you also cant get any replacement PARTS. your going to have to get the whole remote replaced or get an out of warranty coupon which gives you 50% off harmony remotes on the Logitech website
Feb 01, 2010 | Logitech Harmony 880 LCD Remote Control
Radiator water in oil of my John Deere 310A backhoe. What steps do I take to repair.
You have either a blown head gasket, cracked block or craacked head. Major work ahead. Hopefully, the water didn't mess up your main bearings.
Sep 01, 2009 | John Deere Kids Tractor Loader & Backhoe...
Dream maker 400 cover always fill with water
You will need to either get a new cover or buy a new extralarge tarp and use as cover. Thanks jj505
Please rate
Apr 05, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
New battery cover
Get the right cover for your phone as there is no modification unless you brake the tabs off, but then the cover will keep falling off.
Mar 06, 2009 | Motorola Mobility RAZR V3
Ford windstar fuel filter
you could have a leak either at the throttle body, injector rail or a small craack in the intake. also i would check to see that the fuel lines to the injector rail are secure and tight
Aug 29, 2008 | 1997 Ford Windstar
Dmc-tz1 not working
Hi,there are many fixya repair shop near you you may enter zip code can you find fixya authorized repair shop.
Apr 15, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
West Bend 82306 Stir Crazy® Popcorn Maker Logo
490 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
