AIR CONDITION A FRIEDRICH AC MOD #XQ05J10-3 PURCHASED MAY 2001. RECENTLY WATER COMING INTO ROOM; TRIED RAISING THERMOSTAT SETTING TO NO AVAIL. THIS UNIT INSTALLED THRU THE WALL. ANY THOUGHTS AS TO WHY THIS JUST STARTED? ANY SUGESTIONS AS HOW TO CORRECT? THANKS FRANK L.
  • 76 Answers
Just tell me if you have a single unit or a split unit,I can help you with this problem,but need to know what you have..
Waiting for your youre reply.
Posted on Sep 10, 2008
Odor from ac
remove from window and clean with bleach and water.
Jul 26, 2014 | Friedrich CP10C10 Wall/Window Air...
Friedrich CP24F30 money saver mode not working
Money saver mode dose not regulate room temperature. All that mode dose cycle fan on and off with the thermostat if in the yes position then fan cuts on and off with the call for cool. if in the no position than fan runs all the time even when cool is not needed. that switch is like the auto/on on a thermostat for central air. the thermostat is what regulates temp in room.
Jul 01, 2014 | Friedrich Heating & Cooling
How do I troubleshoot a goodman 2 stage that always starts at high stage
It wouldn't be stuck if that's the case the valve would never shut off. Sometimes those 2 stage heat thermostats stats call for 2nd stage if the room temp drops more than 2 degrees. Easiest way to check is take the w2 wire off of the tstat and try a call for heat. If the furnace kicks on both 1& 2 stages then its either your wiring on the fan board or a dip switch setting. If it kicks on 1stage then it's your thermostat.
Mar 19, 2013 | Heating & Cooling
I have a Friedrich thru the wall air conditioner with a wall mounted thermostat but I cannot seem to regulate the temp. with the thermostat. What happens when I press the up and down arrows.....does the...
It is not uncommon for the room temperature and the set temp. on the thermostat to be several degrees apart. The room temperature should go down when you set the temperature on the thermostat down to a lower number.Hope this helps you and thanks.
Aug 17, 2011 | Friedrich Heating & Cooling
I'm looking for the accordian style panels for the friedrich qstar 06j10
Hello, here is a link to parts for your AC. http://www.searspartsdirect.com/partsdirect/part-model/Friedrich-Parts/Room-air-conditioner-Parts/Model-SQ06J10BA/3120/0904032/50024048/00002
Jun 20, 2011 | Friedrich QStar SQ06J10 Air Conditioner
Ac wall drips water days after being shut off
Probably get a lot of ice on evaporant,or check drain hose it must be obstruct,clean it.
Decrease temp. on the thermostat.
Jul 04, 2009 | Friedrich CP06C10 Wall/Window Air...
Friedrich AC through the wall ac leaking water out front vent
pull it out and check for packaging left in ac unit, and make sure drain is clear and large enough for water flow ,,,go ahead and tilt ac unit more and see if that doesnt do the trick
Jul 04, 2009 | Friedrich CP12C10 Wall/Window Air...
New AC unit mist
It sounds like the unit is either level or tilted down in the front, not allowing the water to run to the back of the ac and the blower wheel is picking the water up and blowing it into the room.
You need to put a level on it and lower the back of the ac so the water the coil removes can run to the back of the unit and that should solve your problem.
Jun 07, 2009 | Friedrich WallMaster WS10B30 Air...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
