Question about Apex Digital AT2008S 20" TV
Volume of the tv goes up by itself and no other buttons are working on the remote or the Tv
    President:
  • 3,130 Answers
Sounds like theres a problem with the front panel push button for the volume; In most cases it gets pushed too hard or just too week to stand up to multible presses and so the button cracks and de[resses the switch. If one switch is depressed none of the others will work as well . Simply open cabinet and pull back the chassis and relese the stuck button
Posted on Mar 30, 2006
  • Larry  Dillon
    Larry Dillon Mar 30, 2006
    oops sorry about the spelling
Volume on my Toshiba TV 32AV502U goes up on its own at random times. Remote brings the volume down but within minutes volume goes up again. Solution??
First off, take the batteries out of your remote to see if it is a problem with your remote, if it is I would buy a new universal remote and try that. If none of this works then the problem is with your tv itself. Either the volume button on the tv is broken and works on its own, or the tv is having programming errors and you will need to have it fixed.
Jun 26, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
The volume on the TV keeps going down by itself. What should I do?
Dont know what tv you have but. You can remove the batteries from remote and if volume still goes down you ruled out the remote as the problem.. Or just take remote to another room. If the problem still exists then Im guessing either a sticky button on the tv volume down or as I have seen to many times.. People clean their tvs with windex or some cleaner and it drips down into the tv messing up the control buttons. Hopefully its just a sticky button..
Oct 19, 2010 | Toshiba CT-90157 Remote Control
The volume on my tv goes down all by itself. I turn it up and it goes right back down to 0. With remote or manually, does the same thing. Also, can't turn tv off. have to unplug it to turn it off. Any...
Try taking the batteries out of the remote or taking it out of range from the tv. Then try turning the volume up on the Tv manually. If the volume continues to go down on its own then it is a problem with the tv set itself. If the problem stops with the remote out of the picture then it is a remote problem. As far as powering the unit off may be a similar issue. If there is an on/off button on the tv and it works to turn the power on but not off then it is a tv issue. If the remote turns the tv on but not off it may be something as simple as the wrong code being programmed into the remote(universal remote) or if it is the factory remote it may be an issue with that. You could try getting a new universal remote that works with your unit.
Jul 09, 2010 | Toshiba 32A33 32" TV
When i turn the tv. on, the volume line appears all the way to zero. if i turn the volume up, it goes up but when i release the up button the volume goes down all by itself.
It sounds like one of the volume down buttons is stuck in the activate position. The same as if you were holding the down volume button continuously. It could be either the volume down button on the TV or the remote. I would try remove the batteries of the remote then adjust the volume by the TV buttons.
If the volume doesn't go back down then the remote is the problem. In order to fix the remote you may need to take it apart. This is normally easy to do just locate any screws that may be holding the remote together. If you don't see any screws then you will need to pry the two sections apart. Separate the circuit board and rubber buttons and clean them both with some rubbing alcohol and reassemble it. If it still has the volume issue you may need to replace it.
If the problem persists with the remote deactivated then it's the volume button located on the TV. That is a little more difficult. You can try wiggling the button or some canned air (used to clean computer keyboards) to blow it clean. However it may need to be disassembled to gain access to the switches for proper cleaning.
Hope this helps.
Oct 19, 2009 | Toshiba 32A33 32" TV
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Aug 04, 2009 | Apex Digital PF2025 20" TV
The volume is turning itself down all by itself. The volume on the remote won't work, but the remote is fine with the other TV controls.
It sounds like the button is stuck. Take the remote apart if you can and see if the key is stuck somewhere. This happened to me once with a rubber key type of remote. It drove me crazy.
May 10, 2009 | Sansui HDLCD3210 32 in. LCD TV
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
Apex Digital AT2008S 20" TV Logo
223 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
