Home | HP | DeskJet 1120cse InkJet Printer | No printing
HP DeskJet 1120cse InkJet Printer
Problem for HP DeskJet 1120cse InkJet Printer
No printing
By melx5 on Mar 29, 2006
The cartridge light blinks and the printer won't print. I've tried removing and reinserting the cartridges and it doesn't make a difference, even letting the levers push the cartridges into place instead of pushing them down by hand. I'm looking for ideas of what specifically to check for an clean and an reluctant to buy new cartridges to test with because I can't use them in another printer if this one isn't going to work.
Same Problem
Sep 07, 2008
-   My Epson Stylus CX2800 is not printing. Sometimes if I take out the black cartrindge it will print in black but not print attached photo's. I just removed all the cartridges to print a letter with color photo's and it only printed light and out of contrast phot's---- no black at all.
Help! The last time I asked for help, I got nothing.
helpfull.
Thank You very much,
teri-caltabiano@sbcglobal.net -   TCpotsy
Aug 28, 2008
-   the printed paper that I get from my printer Samsung ML1740 Laser Printer
is hard to read , it is not dark enough, what is the problem please?
-   oerrachidi
Aug 25, 2008
-   After replacing cartridge I get a message "cartridge no in, remove and reinsert". I keep doing that but always get the same messge. Cartridge does not seem to lock in and cartridge door doesn't want to close.-   nabbott
Jul 28, 2008
-   the red(magenta) cartidge is flashing that it's empty, but it really has exactly the same levels as every other cartridge. I took it out, shook it, tested it on some paper, replaced it, but nothing works. I've only printed a handful of pictures, so I highly doubt it is really empty.-   cat_niemiera
Jul 20, 2008
-   Red light flashing cant print -   pimpdadykool
Solution #1
posted on Mar 30, 2006
Somewhat Helpful)
silly girl
Rank: Wiz
Rating: 81%, 3603 votes
There can be a few causes for the ink light to blink.
1 - the cover isn't well shut. open and close it, and check for any obstructions.
2 - you're out of ink. let's assume you have this option covered, but if you want to check, look for the yellow indicator arrow on the cartridge.
3 - the carts don't sit right, or have a bad connection due to dried ink on the contacts. Take a damp cloth and gently wipe the contacts on the printer side till you get most of the ink off. Next, take the carts, and submerge them in hot water(1-2 mm high) so that only the contacts are in the water. Let the water dissolve the ink for a few minutes, take the carts out, give the contact area a few more wipes, wipe them dry, and try inserting them into the printer again.
If you want to check with new parts, but rightly don't want to waste the money, try borrowing.
Hope this helped
Was this helpful?
Yes
No
Solution #2
posted on Aug 27, 2009
Not Rated)
traceycowie2
Rank: Apprentice
Rating: 0%, 0 votes
i have a canon pixma mp760 and it want print at all i have changed all the ink cartriges
Was this helpful?
Yes
No
Solution #3
posted on Aug 26, 2008
Not Rated)
tecaso
Rank: Apprentice
Rating: 0%, 0 votes
Dear Sirs, we have an Epson C63 printer with Ink and paper red lights flashing same time. We replace black cartridge and don`t
work this printer. Please, help us. Many thanks.
Was this helpful?
Yes
No
Solution #4
posted on Jul 02, 2008
Not Rated)
jglassm
Rank: Apprentice
Rating: 0%, 0 votes
Please see web page: www.glassmoyer.net/HP2000C. Regardless if carts have ink or not, they can be expired and therefore rejected by printer default software - (not printer drivers). This is internal printer software, the printer's OS for lack of better words. Suggest you try a set of auto-reset chip cartridges, shown on web page above. Email me if interested from link on page. I repair 2000C's and offer fully refurbished ones as page will show.
jim
Was this helpful?
Yes
No
Solution #5
posted on Jun 21, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
nmghm
Solution #6
posted on Mar 21, 2008
Not Rated)
Ajkill
Rank: Wiz  HP Expert
Rating: 84%, 1094 votes
Use this link it may help you:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Was this helpful?
Yes
No
Solution #7
posted on Jan 27, 2008
Not Rated)
stanno
Rank: Guide
Rating: 100%, 1 votes
sounds silly but i had a problem a while back where i changed the ink and it didnt seem to register and would not print....... after some agonizing i figured out that i forgot to remove the tab that covers the contacts on the new ink cartridge.  maybe this could help someone.
Was this helpful?
Yes
No
Popular Solutions for HP DeskJet 1120cse InkJet
Questions and Unsolved Problems for HP DeskJet 1120cse InkJet
Do you recommend HP DeskJet 1120cse InkJet Printer?
Answer
Answer
storm took my phone line out now my printer won't turn on there is a red light on in the printer and... (More)
Answer
I have an HP910 just bought a few months ago. Now the on button blinks...the comp says cartridge... (More)
Answer
i have a hp deskjet 1120c printer. it stops printing and sends a message "out of pasper" i... (More)
Answer
when a document is dumped from any other software the printer document feeds a sheet but doesn't... (More)
Answer
i have a Canon IP 1800 printer.I ran out of colored ink but the black ink is full. When I try to... (More)
36 Other Users Have The Same Problem - Continued
Comment by uppya, posted on Jul 11, 2008
first the printer was too reddis then it stopped printing
Comment by MSNELL, posted on Jul 10, 2008
DONT WORK LIGHT STAYS ON
THEBETHLEMITES@COMCAST.NET
Comment by Guest, posted on Jun 22, 2008
i am looking for an instruction manuel for hp photosmart 130
Comment by Guest, posted on Jun 17, 2008
My LexMark Z65 will not print. I get an error message stating that my computer do not recognize the printer. The power on/and off button and the tray sheet blinks back and forth, I've downloaded new drivers and hooked the printer up to my laptop and still get the same message. Do you have any suggestions.
Comment by Guest, posted on Jun 16, 2008
hp cartridge inserted but rejected
hp cartridge
toner light blinks and it won't print
Comment by guest1013, posted on Jun 13, 2008
I have full ink cartridges that came with the printer their properly installed, and when I turn on the printer the green and orange light blinks continuously and I get an error that says "An ink cartridge is not installed properly. Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." But the thing is they are installed properly.
Comment by Guest, posted on Jun 11, 2008
printer is ready, but I cannot print
Comment by Guest, posted on May 21, 2008
I had the inks refilled and it says , there is no ink.
I pressed the share button, and it tells me thats its initializing takes about 10 mins. lights are all blinking then it prints and empty paper, how do I get these pictures to print
Comment by zardoo, posted on May 13, 2008
The "replace the ink s"signal was blinking.I replaced them but it is still the same.The machine does nothing.
Comment by Guest, posted on May 04, 2008
I also tried cleaning everything possible, and because there is an issue with the color yellow, I cannot get the printer to print anthing. I just want to print in black and white but because of the error message, it will not do anything. Any suggestions?
Comment by Guest, posted on Apr 30, 2008
it just wont print no matter wat u do
Comment by Guest, posted on Apr 11, 2008
i power on the printer 1120c. cartridges comes forward and not goes back. i replace the cartridge but problem remains the same. no pare feeding . no printing and orange and green light goes on continuosly.
Comment by Delila, posted on Mar 28, 2008
The printer will not print. Have cleaned the heads etc and have manually cleaned the carriage, replaced and have new cartridges but still NO PRINTING. Any ideas????
Comment by cafsmf, posted on Mar 15, 2008
I have new cartridges in the four spots, but after numerous cleanings as per the manual, the printer will still not print a thing. Is there some way to clean the printer heads? It looks like that piece is molded right into the rest of the machine? The machine is only a year and a half old, is it even worth trying to fix?
Comment by jovenconde, posted on Mar 07, 2008
my hp 2300 series printer will not print and it stays offline the light keeps blinking
Comment by DianaLee, posted on Feb 24, 2008
printer won't print but the on button is lit up and also the down arrow which has never been lit before. the status bar shows it is off lie. i don't know how this has happened.
Comment by Chazlee, posted on Feb 08, 2008
Said color cartridges needed replacement on my oj7130 and I replaced them. Now the display tells me the color cartridge is empty. What can Ido besides getting 2 new cartridges to fix this?
Comment by IHA KING, posted on Jan 07, 2008
ME TO
Comment by Annabel H, posted on Jan 03, 2008
My printer was out of ink so I changed the cartridge. The cartridge installed fine and printed an alignment page. The alignment page did not seem to want to align and now it won't print and keeps flashing up that it is out of ink. The ink cartridge is fine though as the alignment page printed fine.
Comment by Erikanatasha, posted on Dec 18, 2007
I inserted a new cartridge into the printer. It printed a few pictures. Now suddenly it says theat there is no ink cartridge in the printer. I removed and reinstalled the ink cartridge numerous times, with no luck.. It still says there is no cartridge in the printer. What can I do to get it to work?
Comment by burasca, posted on Dec 17, 2007
Have just inserted refilled ink cartridges. Printer won't turn on - on/off green
light keeps flashing. Orange light E followed by 2 keeps flashing.
Alarm light keeps flashing.
Tried scanning and click on preview and message code 2250,0 comes up
Comment by BOA7, posted on Dec 17, 2007
Our Dell 1110 just blinks it's lights and does nothing. Removed the toner, checked plugs and connections, still nothing.
Any suggestions?
Comment by Guest, posted on Dec 02, 2007
my canon s500 printer the orange light blinks 8 times, according to the help menu this suggests that the waste tank is full, where do i get one of these and is it simple to replace.
Comment by notmyname, posted on Nov 28, 2007
I want to print but the printer continually says cyan empty. I have replaced all cartriges and the cyan three time in one month with less than 40 copies made. How can I print just black and white and bypass the color? How can I stop the problem?
Comment by chew toy 5, posted on Nov 19, 2007
Just got a canon ip1800 printer, installed it and have just gone to use it but when i try to print it comes up with a screen saying 'an ink cartridge is not installed properly' and suggests taking them out and putting them back in again. I have done this endless amoutns of times and yet it still displays the same screen over and over. Please help
Comment by Guest, posted on Nov 18, 2007
Printer light blinks yellow 7 times, then green. I reinstalled the driver and it worked for a day before blinking again. Now it won't stop blinking at all.
Comment by peverett, posted on Nov 15, 2007
printer is just not printing no matter what i try
Comment by shaggyman83, posted on Nov 13, 2007
6 yellow beeps and 1 green
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP DeskJet 1120cse InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
