Question about Apex Digital PF2025 20" TV
Volume keeps going up by itself
The volume keeps going up by itself and the button for power on the tv brings it down and no other buttons are working
  • 2 more comments
  • ravi2103 Jun 18, 2008
    Similar. On My Toshiba 32A43, volume goes down automatically.
    Let me check if this solution works out.
    Thanks,
    Ravi
  • Anonymous Dec 09, 2008
    I have the same problem with my RCA F32648 32"TV the volume increases I have never really used the button on the front of the tv. One day I turned on the TV and the problem started.
  • kv32 Jan 01, 2009
    Same problem on my six year old Sony KV32-FV300.
  • mazesnowbird Apr 22, 2009
    my volume won't work on remote or tv set. just keeps going up. can get it to go on on tv button but when i let go it goes up again
Help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Posted on Nov 15, 2008
  • 1 more comment
  • max1
    max1 Jun 03, 2014
    lol
  • max1
    max1 Jun 03, 2014
    You have to unplug the side panel control buttons on your tv. The way you do this is to unscrew the back panel of the tv, which can take time as i had a 47"lcs lg and this happened to me, then in the corner of the tv or wherever your tv control buttons are ytou will see a cord attached to ta motherboard, unplug it fdrom the mother board usually its very small so you may need a tewwzer or small plyers. But when i did this it worked great, the tv stayed off and the volume on my tv stopped changing intermitently.
  • max1
    max1 Jun 03, 2014
    you may also want to try to use a air spray can just to blow some air in it becuase alot of times dust and if basement humidity can clog up your internal circuit.
I have the same problem. My Curtis Mathes TV volume keeps going up. I could go to the TV and manually turn the volume down but then it would go back up UNTIL we took the batteries out of the remote. After a while we will put them back in, until it happens again. But that will work for a few weeks.
Posted on Jan 22, 2010
    President:
  • 3,130 Answers
Sounds as though the volume up button is pushed in and activating the switch or the switch its self on the PCB is defective. The plastic push button gets weak or breaks and makes it stick. You could try to pull out the chassis a bit and push the button back out or on some sets you have to replace the front cabinet as one piece.
Posted on Mar 31, 2006
    New Friend:
This happens ti mine first it would go Down know it goes up ??????
Posted on Jan 03, 2013
4 Suggested Answers
SOURCE: TV lock on
Try this for 2402s
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=71c9242585ab36d831a426f43d10b975&q=Apex+AT2402s
Posted on Nov 29, 2007
jrweighing
  • 183 Answers
SOURCE: TV Volume goes up by itself and remote wont work
There are 2 reasons that this is happening in respect to the problem commencing after your daughter has cleaned the tv. Either your daughter has sprayed the volume button with cleaner and fluid has got into the the graphite pad under the button and conducting as though the button is being pressed continuously..or she has put too much pressure on the button if it is a metallic plate contact switch.One way to find out is by pressing the down volume button.does it it click ? if it does.try the up volume..If that doesnt click the problem is the metallic plate is dented in making contact hence a new switch. Another cause ive seen is cleaning the remote control with cleaner and fluid has got into the remote and it sends signals to the tv all the time..If the remote control is hidden under a cushion and the problem stops, then the remote control is at fault and needs drying out..Hope this helps :)
Posted on Aug 04, 2009
techman
  • 3130 Answers
SOURCE: Buttons on TV or remote not working. Can only cycle through video input options.
It sounds as though the TVs in a demo mode. Has someone recently been over and was playing with the remote. If so go into the menu of the tV set and look for set up and demo mode. Turn off the demo mode. if this doesent help call i-866-427-3946 and talk to the customer service deptartment. Good Luck
Posted on Aug 09, 2006
Samsung galaxy S2 mini keep restarting itself...i can t get to the menu to write codes or restore factory settings...it just resstart over and over again.....the button is not blocked and i tryed some...
Press volume up & down & power - when the phone vibrates IMMEDIATELY press the home button and after 2-3 seconds release the power button... What you're going for is that the phone tries to restart with volume up & down & home button pressed...
Press and hold both Volume UP and DOWN + POWER ON / -->( HOME ).
Select Factory reset with Volume Down button and press Power to reset. All data will be lost!
or
Turn off S6500. Press and hold POWER + ENTER button for reset menu.
Mar 07, 2014 | Samsung Galaxy Cell Phones
Volume keeps going down on samsung t260hd
The digital main board has the fault. This is not a user repairable one. Contact any technician.
Dec 05, 2012 | Televison & Video
Techwood tv volume going back down
I've got this problem these fixing only work for a sort time! Volume just turns itself down?! Anyone no the real fix?
Jul 03, 2012 | Televison & Video
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
The main menu setting keeps coming back on, unable to use cable 1 or turn to a different cable or channel. (Happened only after power surge) Already tried to re connect the TV, in the main menu setting we...
Hello
I have actually seen this before. The tv in my living room did it and it was a simple fix. I had to download the latest software. Put it on a usb key. Turn the tv off... Stick the key in and load the new software.
The only TRICK was that I had to hold down the VOLUME - button on the tv itself while my wife worked the remote.
So, if you can hold down your VOLUME - button and do things to your tv I would think this might work for you too. I know it sounds strange that a software upgrade can fix this, but it did for me.
Hope this helps
Nov 26, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
The volume on the TV keeps going down by itself. What should I do?
Dont know what tv you have but. You can remove the batteries from remote and if volume still goes down you ruled out the remote as the problem.. Or just take remote to another room. If the problem still exists then Im guessing either a sticky button on the tv volume down or as I have seen to many times.. People clean their tvs with windex or some cleaner and it drips down into the tv messing up the control buttons. Hopefully its just a sticky button..
Oct 19, 2010 | Toshiba CT-90157 Remote Control
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Volume turns down by itself
Its the buttons on the tv, they need to be replaced, or replace the whole key pad on the tv. that should fix ur problem
Mar 17, 2009 | RCA F36650 36" TV
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Apex Digital PF2025 20" TV Logo
10,433 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
