Question about HP Smart Buy Notebook
Wireless button the network on and off button on the display doesn't work. I understand it should turn on by itself but it just doesn't. I has worked on and off but not every day. I have tried disabling and enabling the network connection and uninstalling and reinstalling the network driver. Yet nothing has worked. I read in another forum that I should restore the BIOS defaults but I dont know how to do that and I am afraid because this is a work laptop. Please Help I have been trying to fix the problem for a couple of weeks and im going crazy. PS I know there is no problem with the actual card cuz when it decides it wants to work it works beautifully.
  • Mike West Nov 14, 2008
    Where is the wireless button on the HP 6710b? I can´t turn on the wireless network, which for some reason has been turned of.
  • torrent_spy Nov 19, 2008
    I have the same problem, but where is that button, and how can I enable wireless??
  • 499 Answers
Is ur wirelesss work ort it's disabled because of the button
Posted on Jul 25, 2009
Ethernet and wireless not working
The wireless sounds like its not working or the drivers are not installed.
The Ethernet port may have been programmed with a static IP address or you do not have a DHCP on the network your plugging into.
open the network and sharing centre by right clicking on the network icon by the clock.
Then local area network.
Then properties.
Then internet protocol version 4 (TCP/IPv4)
The display should look like this :-
25583850-zrzcpkof2p0j4eifxttonmc3-2-2.jpg If it doesn't and there are numbers in the click the Obtain IP address automatically radio button.
Mar 17, 2015 | Computers & Internet
My new laptop doesn't work
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 12, 2012 | Samsung Computers & Internet
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
Light on printer keeps flashing orange. Router is working, if not I could not have wireless, right??? My printer is next to computer and router. Help
If your printer was wirelessly working before, try to unplug/replug your printer to the power outlet. Doing this usually fixes minor communication issues.
If that doesn't help, please reset the wireless network adapter for your printer. On the printer operator panel, press Setup button -> Network Setup -> Reset Network Adapter to Factory Defaults. The WiFi light will momentarily turn off, then turns on steady orange. You can now reconfigure your printer for wireless connection.
May 02, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Wifi switch is turned on however, when i try to search for a wireless network i get a message saying that i need to turn on my wireless switch
So I understand that your wifi card doesn't work?If that is correct go to Toshiba site and check their support-from the other computer-of course.If card is dead, you will need usb wifi.
Nov 15, 2010 | Toshiba Satellite Pro L300 Notebook
Wireless adapter in laptop keeps turning itself off and back on
there must be a touch button for Wireless networks put it off ....... guess it is looking for some wireless networks around.
Jul 01, 2010 | Compaq Presario CQ60-220US PC Laptop
Configure Modem Echolife HG520s With WRT54G OR WRE54G
Not sure if I understand properly but your router should have a WAN port or an "Internet" port
your modem should be connected to it and your PC should be on any of the LAN port
Apr 04, 2009 | Linksys Wireless-G WRT54G Router
Wi Fi doesn't work. Have compaq 700. Says the
There are many reasons why wireless doesn’t work but lets look at it step by step
How it works is that there’s a card inside your laptop which detects networks “wireless only” that are in your house and near you like neighbours.
The most common mistake is “the button” there is bound to be a button either
On the side, the rear, the front of the laptop or even near the keyboard it usually has
A dot with signal lines that button switch on and off the wireless device so make sure its on and then wait 10 second for the signal to appear.
There is no button? Right then there’s a keyboard shortcut to switch it on and off
You must first press and hold the “fn” button or the function button then find the wireless key which is either “f8” or “f4” it varies from model to another but it always has the wireless logo on it and it is always one of the f keys.
Didn’t help? It could be you’re running multiple utilities to run your wireless, you either have to use windows utility which is normaly in your task bar but if that’s not working then another utility is using it, so find in your programs list “wireless utility” or “belkin utility” which usually does the same.
Didn’t help? Its getting more serious, makesure your driver is installed for the wireless, if you go to the device manager and then to the network area and there makesure your wireless drvice is enabled “no red cross on it” or else if you cant find a wireless device in there then it means your wireless card is faulty and need an expert looking at it.
It is good practice to re-install the wireless driver to fix most issues.
Mar 07, 2009 | Compaq Presario 700 470024-192 Notebook
Wireless internet connectivity problem
On an unsecured access point (not WEP or WPA) it should work.
Try here for advice http://forum.eeeuser.com/
Presumably you don't need to set a proxy in Mozilla?
Aug 06, 2008 | ASUS Eee 4G Notebook
Can't get sound from the wireless subwoofer
There are 2 things you can try, first ensure that the digital transmitter is fully inserted into the slot of the main unit. Secondly do you have any other wireless devices near such as cordless phone or wireless network equipment? See page 5 of the installation manual as per this picture.......
Jul 25, 2007 | Panasonic SC-PT1050 System
HP Smart Buy Notebook Logo
333 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
