Question about Cameras
I want to replace the memory card cover for a Kodak cx7350. I need the instructions
  • 4 more comments
  • Gary Sep 10, 2008
    MY Kodak CX7530 memory compartment door has broken off. I have ordered a new one, but don't have it at this time. I just posted this request for instructions on how to replace the broken one. I got a message that said to remove the two screws that hold down the plate that the door is inserted into. I have removed the two screws, but there is nothing that I can see that is removable to replace the door into.
  • Gary Sep 10, 2008
    I just purchased this part from a supplier a few minutes ago. I am a little confused that you tell me the part is non replaceable. You may be right, but It just seems that the part being available, should mean that it is replaceable. Maybe I need to wait to get the part. Will I be charged a new fee if it takes a few days to get the part before I can get back to you?
  • Gary Sep 10, 2008
    Bestdarngood, I don't know if you are the same one that just told me that they had checked and found that the part is not replaceable. I hope that my last repost was not confusing to you. I think I need to wait to get the part. Can I find you to help me when the part does come in?
  • Gary Sep 10, 2008
    Kindacheap... I did not order the part from Kodak. I ordered it from Image Galery online. It may have instructions, maybe not. It it does, I will use them and get back to yall and rate your help. I may have to get your help again though. Thanks for your help so far. Gary
  • Gary Sep 17, 2008
    All right friends... I received the new door just today, I have removed the 5 tiny screws holding the case together. I have spread the case apart slightly. The new door has one hinge with two little ****. the other hinge has three. I don't want to force the guys into the slot, but I don't see any other way to get the hinges in.
  • Gary Sep 17, 2008
    My problem is installing the cover for the memory slot .  I know how to install the memory stick.  It is the door that I need help with.
    Brigadier General:
  • 6,966 Answers
Might this help? It is for another model but would closely resemble CX7350 removal procedures.
The above photos originally appeared here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 10, 2008
  • Louie  Role
    Louie Role Sep 16, 2008
    Any updates?
    Genius:
  • 2,035 Answers
You use this link to details for the replacement of the part:
http://www.advancecamera.com/repair/
Good luck....
  • 1,183 Answers
Kindly go to the folllowing link , that would show you where and how to put the memory card in the camera
http://www.kodak.com/global/en/service/publications/urg00252toc.jhtml?chapsec=urg00252c1s8&pq-path=2310/2324
The maximum additional storage the camera would support is 512 Mb SD/MMC card.
The complete user manual can be viewed at
http://www.kodak.com/global/en/service/publications/urg00252toc.jhtml?pq-path=2310/2324
Thanks
Proton
Do rate the solution
  • 928 Answers
You can wait for 2 or 3 days till you get the part and respond back. The threshold is about 7 days exactly.
  • Thomas Lim
    Thomas Lim Sep 17, 2008
    You have to sort of pop it in the slot.
    Do make sure the old one and the new one are exactly the same by the way.
    Sergeant:
  • 241 Answers
Www.kodak.com/global/en/service/products/replacementParts.jhtml?CID=go&idhbx=parts
Hi I checked and that part shows that it is not a replaceable
Part?? I would call to confirm as for the instructions If the part is not available there would be no instructions... If there is a 3rd party which I have not located may have some type of instructions
Thank you plz rate my solutions
  • 1 more comment
  • Jayson Brollini
    Jayson Brollini Sep 10, 2008
    I would wait until your Part
    arrives Kodak is pretty good at
    giving instruction to there parts
    You may take a chance a break something else
  • Jayson Brollini
    Did you order it from the link KODAK this would be
    the place . Go there and see if that part is .
  • Jayson Brollini
    plz let us know I would like to know if the part was a 3rd party or an orignal part. The image galery online (?) .com .org .net
    President:
  • 1,952 Answers
The card may be corrupt.
Reformat the card ().
Caution: Formatting deletes all pictures and videos, including protected files.
Card is not properly inserted in camera.
Insert a card into the slot, then push to seat ( Storing pictures on an SD/MMC card).
Camera freezes up when a card is inserted or removed.
Camera detects an error when the card is inserted or removed.
Turn the camera off, then back on.
Make sure the camera is off when inserting or removing a card.
Memory card full
Image storage is full.
Insert a new card ( Storing pictures on an SD/MMC card), transfer pictures ( Transferring and printing pictures), or delete pictures ( Deleting pictures and videos).
The maximum number of files or folders is reached (or other directory concern).
Transfer pictures and videos to the computer, then format the card or internal memory ().
Caution: Formatting a card deletes all pictures and videos, including protected files.
  • mohammed marika thambi
    mohammed marika thambi Sep 17, 2008
    ...cover open) 1 Shutter button 6 Microphone 2 On/Off button 7
    Lens/Lens... Kodak EasyShare LS755 zoom digital camera User’s Guide
    www.kodak.com For interactive tutorials, www.kodak.com/go/howto For
    help with your camera, www.kodak.com/go/ls755support Eastman Kodak
    Company Rochester, New York 14650 © Eastman Kodak Company,...
    .instructions. This warranty does not cover damage to the
    Product.Reference Guide Text P/N 217857-1 Rev.
    C © Eastman Kodak Company, 2002 KODAK, NovaJet, ENCAD, CADJET, Extreme
    Color Printing and Ink Caddy are trademarks of Eastman Kodak Company.
    Other trademarks are the property of their...
  • 3,037 Answers
Alright, there should be a couple of screws on the side with the cover. Take those out and the panel they are holding down should free up the slot that the hinge for the cover goes on to and you should be able to put the cover on and reassemble.
Let me know if you have any further questions
  • 2 more comments
  • Benjamin Patri
    Benjamin Patri Sep 10, 2008
    I may be thinking of a different model, so you may end up having to take off the entire outer panel instead in order to access where the hinge will go. They are basic phillips screws with a #0 head.
  • Benjamin Patri
    Have you seen my last comment that this model may need all of the exterior screws removed in order to get the pieces apart that hold the metal hinge for the cover on?
  • Benjamin Patri
    You can just reply here if you need further help from me, are you able to see the other experts' responses still since I was not the one you are referring to about not being replaceable?
  • Benjamin Patri
    Benjamin Patri Sep 17, 2008
    on the camera itself the cover should separate with another piece where the hinge goes in to let both ends slide in at the same time.
My kodak c1500 wont work with a memory card in it, or it does for a bit then actually wrecks the card so it can't be used
Hello Hank, Sounds like camera firmware is corrupted, you can try Kodak website for firmware download and instructions to correct the problem.
Best Regards, Russell
Jan 20, 2013 | Kodak Cameras
Getting photos from kodak internal memory?
There should be an option either in the Setup or Playback menus to copy pictures from internal memory to a memory card. You can insert a new memory card, copy the pictures to the card, and then transfer them to your computer.
If you need further instructions, feel free to reply to this message and specify the model of your Kodak camera.
May 07, 2012 | Kodak Cameras
My kodak easyshare 500 printer is not recognizing when I put in a memory card. Is there a reset I can do?
the memory card could be to large for it to recognize. look in the instruction manual for the max size. or just try a smaller card
Apr 26, 2012 | Kodak EasyShare Photo Printer 500
Getting an internal memory full message on my kodak easyshare c143 camera but it only has 9 pictures on it?
The internal memory is very small. You need to be saving the pictures to a memory card instead. However, Kodak cameras have this nasty habit....once you save a picture to its internal memory, it won't save to a memory card. To make your card work, remove it from the camera...go into the camera menu and find "format"....follow the on-screen instructions to erase the internal memory....insert your card and it should work properly.
Apr 11, 2011 | Cameras
Kodak C160 camera says internal memory full. How do I correct it so it will take a pic? Have tried new memory card.
You need to get rid of the pics in the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert the new card and do the format thing again to erase and initialize the card. Everything should work properly now.
Jan 26, 2011 | Kodak EasyShare C160 Digital Camera
I CAN'T UPLOAD PICTURES IN MY C813 CAMERA'S INTERNAL MEMORY TO MY COMPUTER
Hi
I am not sure the Kodak EasyShare C813 can transfer files straight from the internal memory. Many cameras need you to copy the images on the internal memory to a memory card and then you can transfer them over.
On the Kodak you can copy (not move) them to a memory card by following the instructions below:
Copy pictures/videos:
1 Press the Review button, then the Menu button.
2 Press ^ v to highlight Copy, then press OK.
3 Press ^ v to highlight an option.
4 Press OK.
Hope that helps
David
Dec 29, 2010 | Kodak Easyshare C182 12MP Digital Camera
Kodak M320 with message "internal
You need to get rid of whatever is in the internal memory. With no card in the camera, go into the menu and find "format"....follow the on-screen instructions. Then, remember that all new cards must be formatted in the camera to work properly.
Oct 29, 2010 | Kodak EasyShare M320 Digital Camera
I have a Kodak C330. I have a 1gb SD memory card installed. How do I access card memory? Camera says internal memory filled. Thanks
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
Oct 25, 2010 | Kodak EasyShare C330 Digital Camera
Have copied images and videos to PC from a Kodak easy share c 180. Now need to erase images from camera's internal memory, and sd memory sitick. How To?
1. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. Insert the card and do the "format" thing again.
Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
Problem with memory card
There should be something in the menu to save pictures to memory card.
Jan 09, 2009 | Kodak Easyshare M753 Digital Camera
Cameras Logo
83 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
