Question about Insignia Sport MP3 Player
Please i need help
Well, my Insignia is freezing all the time. I think it was because i used to charge it while my computer had a problem with Windows Defender, while it messed up and try to make me buy the original program. It was fine every time i charged it and you know took it away from my comp.. Now ever since i got it fixed every time i turn it on it freezes, and i have no idea on how to fix it. Please help, i can't last any longer not hearing it at school.
Battery
Posted on Sep 14, 2008
    Novelist:
  • 116 Answers
Connect it to your computer and then use windows to go into the "my computer" window. Usually by the start menu or the desktop.
Find your MP3 player on the list of drives then right click it. You should have the option to format the drive. Try this, it should help out. You might have a bad file on the player and it's not able to read the information correctly.
If you need some more help in finding out how to format it, please ask. (formatting will erase all the data on the MP3 player) Just so you know that. :)
Posted on Sep 10, 2008
My insignia sport MP3 player froze so i turned it off and now it won't turn on, i tried to charge it thinking it was low baterry but it doesn't charge either
I had the same problem. The reason is because you have not charged your player, in a while.
First of all, try this.
Reset the Insignia Pilot if it freezes during normal use. To reset the device, press and hold the "Power/Hold" switch to the right for approximately 10 seconds until the screen turns off. The "Power/Hold" switch is located on the top of the player.
If that does not work, you need to remove the battery and then put it back.
Here's how to do it.
https://www.youtube.com/watch?v=29ULLzZqHLI
Then plug your cable and wait until it comes back to life. Be patient, it may even take a couple of days, until a full charge is accomplished.
Jan 22, 2014 | Insignia Sport MP3 Player
Just got an Insignia NS22E450A11, 1080p LED TV. Using as computer monitor primarily. Every time computer is restarted the screen will not display properly (racing lines & dots only). Computer is older...
The computer does not know the resolution capablilty of your TV, so it set to default resolution. You need to fond out if Insignia website has the driver for your TV. Are you running XP or WINDOWS 7?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 31, 2011 | Insignia NS-LCD19 19 in. LCD TV
I want to download an album from my computer to my Insignia mp3. When I plug the player into my computer all I get is the charging screen. I want to get the album from media player.Jerry
When the player connects only with the charging display, there are 3 points that need to be checked:
Battery and cable connection
1. Connecting the player to the computer, the charging symbol should start loading; battery "green" or "partly green" indication. The player should respond with "OK to disconnect" = connection established correctly.
For proper charging and connection put the USB cable plug directly to the computer preferred at the back side: not through a hub or card reader.
MSC mode
2. The player is switched to MSC mode. MSC = Mass Storage Class. In this mode the device is seen as a flash drive also called removable disk, that can be accessed using Windows Explorer.
The Hold switch was in hold position on the top side, before connecting to the computer.
Disconnect the player and release the hold switch. Next the player should be in standard MTP mode. MTP = Media Transfer Protocol used for transferring files with media software.
MTP mode
3. The media software on the computer for transferring files is not installed or not working properly. Update or reinstall the media software.
Manual for Insignia NS-DV2G:
http://insigniaproducts.com/cms/documents/NS-DV2G%20UM%20EN_SP_FR.pdf
When this didn't help the firmware on the player needs to be reinstalled.
For firmware see the Drivers in the Support tab of the next link:
http://insigniaproducts.com/products/portable-audio/NS-DV2G.html
Oct 01, 2009 | Insignia NS-DV2G MP3 Player
Keeps freezing up after downloads
My new Insignia NS-8V24 player, that I've had for 3-4 months, won't charge. I've used charging USB lines I have to charge it on every computer possible, but it won't charge. It would turn off and on for a few seconds and turn off again. I do not know what to do, because I cannot download music into the Mp3 player if it cannot be turned on. What should I do?
Jun 09, 2009 | Insignia NS-DV2G MP3 Player
Insignia shuts off on me when it's fully charged
Taking the Battery Off the Insignia Pilot 8GBhttp://www.youtube.com/watch?v=29ULLzZqHLI&feature=related
You may need a new battery.
GoodLuck
Dec 10, 2008 | Insignia Pilot MP3 Player
Insignia player program not responding
need more info
what OS do you have?
and what Program are you trying to use?
did you try syncing with Windows Media Player
Jul 31, 2008 | Insignia NS-DV2G MP3 Player
Computer Freezes During Startup (Urgent!)
slamming the keyboard would jar the memory on the bottom or under the keyboard, and make this happen, inspect them both, and then restart it..
check your computers warranty here 4 FREE
Mar 15, 2008 | Acer TravelMate 2300 Notebook
Insignia NS-DA1G MP3 Player Problem
There might be a little switch that says "hold". Make sure it is not at the "hold" end.
Nov 05, 2007 | Insignia NS-DA1G MP3 Player
Try firstly, on start up keep pressing F8 until a menu comes up. Look for the line that reads 'Start windows with last known good configuration', move cursor to it with the up or down keys as your mouse won't work; and press enter. Hopefully your pwill restart and run as normal. If not you may need your Windows cd.
Jan 03, 2007 | Toshiba Satellite A105 Notebook
Insignia Sport MP3 Player Logo
43 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
