Question about Sony STR-DE345 Receiver
Reciever not working
One time i turn on so loud the fuse blownoff.i replace the fuse but every time i turn it on the display said (protect)thats all it wont work.
  • 21 more comments
  • Anonymous Nov 01, 2007
    sony model STR-DA1ES will not power on at all
  • Anonymous Nov 13, 2007
    3rd time receiver turned itself off while being played loud and getting way hot - even when outside of shelf (all speaker connects were being used). But unlike last two times when receiver came back after cool-down with no problem - this time I get nothing on the digital screen - no dtails at all - just a blank. Power is showing on - and blown fuses.
  • Alex Nov 18, 2007
    Where are these fuses? My KLH R7000 does not have any exturnal fuses
    and the interior the only fuse is for the main power supply... am i
    missing something?
  • David CRASH Nov 21, 2007
    My receiver volume goes silent and the display says protect. It worked great for about a year and now lately if I turn the volume up it does it again. The manual says to check the speaker connections, I did, they are all ok. Please HELP!
  • Anonymous Dec 08, 2007
    replaced the fuse inside and all it reads is protect
  • Anonymous Dec 09, 2007
    My reciever won't work at all and the display say's protection, I'm sure it's a
    fuse, but I can't find it.
  • nickscrap Dec 20, 2007
    I was listening to my receiver on medium loudness when i saw a puff of gray smoke come out of the top.It turned off and said protect.I opened it up and checked the fuses and they were good.So,i looked on the amp coil and there was a black spot around a black chip with white lettering that said (MP1620/ 50 P).if you could help me out and give me an idea whether its worth trying to fix it would be great.You can reach me at (s.percle@yahoo.com).thanks and good day!
  • Anonymous Dec 21, 2007
    same exact problem
  • Anonymous Dec 22, 2007
    After connecting all 5 speakers, I heard music from one speaker but the rest did not deliver any sound in CD mode. So I switched to the dvd mode...then the receiver displayed "Protect" and the standby started blinking continuously. How can I rest it?
  • absolute12 Jan 15, 2008
    I have had this sr6001 for 6 months; Since it was new it was shutting off while saying protect. I was not playing loud. I would have to unplug unit and then plug back. It would then be fine for a few minutes, then again shut down. I took it to Marantz they upgraded the firmware. Now same problem but does not come back on when shuts down. They told me to reset the unit by pressing 3 buttons. This works but from time to time the unit for no reason shuts down while saying protect. Speaker hook up is fine no crossed wires. Marantz tested unit again and says nothing wrong. I like the unit but would not recommend it.
  • wayne1071 Feb 23, 2008
    no power
  • Anonymous Feb 24, 2008
    turn power on and it only stay on for about 2 seconds then it say power off.
  • Anonymous Apr 23, 2008
    My reciver blow the 8A fuses.
    My reciver teac model AG-D8900 blow the 8A fuses.
  • pedronicolas May 03, 2008
    cam you helpme? i need service manual tks.
  • Anonymous May 13, 2008
    the DTM 5.3 display reads protect.  what gives and how do i fix it?
  • tann1963 May 25, 2008
    we have taken ours to Steve's TV and they fixed it. But if we turn the power off, the same thing happens again....so now we when we had it fixed, we just do not turn the power off on the receiver....never and then it is ok....but if you turn it off.....the protect comes back on again. It is getting to costly to fix and thinking of buying a newer receiver to replace this one.
    unless someone has a solution...of course the manual does not tell you about this in the trouble shooting section
    rc
  • wboi978 Jun 01, 2008
    i turnd my sony str-de325 up loud and naw all it does is clicks wen i turn it on
  • Anonymous Jul 12, 2008
    protection flashes
  • kacaks23 Jul 23, 2008
    I have the same prob.Thats when I listen dvd.
  • Anonymous Jul 29, 2008
    quand jpese sur power la fuse saute a chaque fois ke faire
  • Anonymous Aug 26, 2008
    No speakers connected it still says protect- tried different outlets. It seems normal at power up for about 4 - 8 sec. and then flashes protect. I have held the power button down until "initial", protect comes on 4 secs later
  • Mitcheal French May 11, 2010
    sorry but I'm a little illiterate when it comes to technical terms... So what am I looking for? where is the protection circuit? how do I know if something is wrong with it? same with the output transister and the caps? Thanks !! : )
  • 3 Answers
You many have a fraid wire or if you playing the unit to loud and overload the amp this may cause it to go to protect. Also is the the receiver properly vented.  If it get to warm the receiver will also go into the protect mode.  hope this helps
Posted on Oct 24, 2007
How to install Guide for Stereo Power Amplifier 3way input Pioneer Model GM-5.
Posted on Sep 20, 2009
I had this same problem with STR DE310. Problem was due to loose speaker wires causing a short. Re-attached wires, both at the tuner and at the speakers, problem solved.
Posted on Feb 12, 2008
The problem has nothing to do with the output, the problem sits in the small board with the yellow connectors, there is a dataflow from the frontand the masteboard and te data is interupted at a moment and tha gives "F70 " I repaird alredy some of them by replacing Q1701 and Q 1702 by BD649, (5V stabilizer ) they can have more power, also replace fuse F5 =1At internal resistance my be too large .
Mostly is it a fall down of the 5 volt that gives the F 70
The best solution is resoldering the print but this almost impossible because their may be some intreruptions between the solder and componentside
The board "REP3107G-T " is no longer available;.. Daniël from Belgium
Posted on Jan 09, 2008
Shouldnt there be a built in circuit breaker that turns the system off when you are overloading it? This is my experience with them - i usually blast the sucker but it just shuts off and works fine on reboot! - Put a fan on it so it doesnt get too hot!
Posted on Dec 16, 2007
  • 524 Answers
Where are these fuses? My KLH R7000 does not have any exturnal fuses and the interior the only fuse is for the main power supply... am i missing something?
Posted on Nov 18, 2007
If you check the owners manual there is a menu for setting the power on volume, I had the same problem and fixed it with the manual.
Posted on Nov 05, 2007
    Problem Solver:
  • 5 Answers
Or keep it simple and find which speaker wire or speaker itself is shorted out. usually your positive wire it touching a negative either at the stereo or speaker connection. unplug 1 speaker at a time but do not play sound very loud. or just disconnect all and add one at a time until error comes back.
Posted on Jul 27, 2007
Check board grounding points.
Posted on Jul 09, 2007
Check to see if you put the correct fuse in the receiver, and if it is the correct one, you will need to check the protection circuit because with it being turned up so loud the amp was probably damaged. in most cases with protection circuits you will probably find your problem with an output transister. than check for blown caps.
Posted on Apr 01, 2006
My reciever is saying on the display screen protect. what does this mean?
That means that the receivers' overload protection circuitry has been engaged. Depending on the number that is also displayed after the alarm message, there are several causes for this. Overheating, running inefficient speakers such as below approximately 85dB/1W/M rating or too loud a volume with demanding source material and last but not least a loose connection of any kind on the rear panel or on any of the devices connected to it. Especially the speaker cable.
Oct 30, 2010 | Sony Audio Players & Recorders
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
I replaced an inline power fuse inside of my Onkyo reciever, power returned and now I have no output to main speakers and the unit flashes back and fourth between regular display and protect. ?????
THE GOAL HEAR IS TO DETERMINE IF THE INSTALLATION IS CAUSING YOUR PROTECTION FAULT OR IS IT THE RECEIVER ITSELF HAVING INTERNAL DAMAGE. REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION, THEN THE RECEIVER WILL NEED TO BE SERVICED, AS YOU HAVE TOTALLY SIMULATED A BENCHED CONDITION THAT IS TOTALLY INDEPENDENT OF YOUR INSTALLATION. MOST TIMES, THE RECEIVE WILL GO INTO PROTECTION WHEN IT SEES AN EXCESSIVE LOAD WHEN TURNING UP THE VOLUME, WHICH IS USUALLY CAUSED BY TOO MANY SPEAKERS OR DAMAGED SPEAKERS, BUT IF NO SPEAKERS CONNECTED, THEN IT IS USUALLY BECAUSE THE RECEIVER SEES AN EXCESSIVE LOAD DUE TO ITS OUTPUT SECTION BEING DAMAGED. IN ANY CASE, ONCE REPAIRED, YOU MUST CHECK YOUR SPEAKERS FOR BURNED VOICE-COILS, WHICH WILL IMPOSE AN EXCESSIVE LOAD TO THE AMPLIFIER AND CAN CAUSE IT TO FAIL AGAIN. ALSO, BE CAREFUL ABOUT HOW MANY TIMES YOU KEEP TURNING IT ON OR OFF, AS AT LEAST ONE TIME, THE PROTECTION CIRCUIT DID NOT DETECT IT IN TIME AND THAT IS WHY THE FUSE BLEW. ALSO, DO NO REPLACE THE FUSE WITH A LARGER FUSE. YOU DO NOT WANT TO SEE THE POWER SUPPLY ALSO GET DAMAGED, AS THIS WILL DEFINITELY ADD TO THE COST OF THE REPAIR. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 14, 2010 | Onkyo Audio Players & Recorders
Getting out of protect mode I have a Denon 787 receiver. It was working fine for 8 months. All of sudden, my reciever goes into protect mode after playing for about 30 min. Right after it goes into protect...
most of the receivers come with a cooling fan inside see if its working they usually work when you turn the volume up,, if its working that means you are playing it to loud if you lower the volume a little it will play just fine..( if the fan inside is not working thats the reason it goes into protect mode and it means you must have it repaired,, it goes into protect mode to prevent furter damage to the unit or the speakers,,
Dec 18, 2009 | Denon AVR-787
Protect displaying
Protect on any reciever usually means that it has reached its maximum capacity of volume (known as clipping) and at the reciever is now automatically reducing the volume to avoid damage. This some times is triggered if the reciever was used hard and is now damaged so you would need to bring it to a repair shop. Sometimes its caused by a bad wire to the speakers, a short to say. Check all your wiring, make sure its not overheating and getting plenty of air. Some where its recieving a signal telling it to go into protect mode.
Joe
May 28, 2009 | Audio Players & Recorders
It says protect on the front screen
An amplifier goes into protect when it detects a load with too low an impedance. If it displays protect with no speakers connected at all, the amplifier is damaged. If not, reconnect speakers one at a time (while the amp is off!) to determine the cause of the fault.
It may be as simple as a single strand of copper wire shorting between the positive and negative terminals of a connection.
Nov 29, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Feb 16, 2008 | Sony STR-DE345 Receiver
Reciever wont go on
Your are running out of power !!
Feb 02, 2008 | Onkyo TX-SV444 Receiver
Avr 3806 power shuts off when volume turned up
Hello david 420
It looks like your receiver's high-speed protection circuit is being activated. It is definitively not a fuse. When a fuse pops, you have to physically replace it. When the protection circuit is activated, the speaker output is cut off and the power supply indicator flashes. There are a few reasons why this happens:
1.- Your speaker wire connections are loose. Whether they are banana plugs or bare wire ends, make sure the speaker terminals on the back of your receiver are tight using clockwise turning.
2.- Verify that your speakers have an impedance between 6 and 16 ohms. Your receiver was designed to work with that impedance range. Any impedance lower than 6 ohms will activate the protection circuitry.
3.- The receiver is used at high volume levels over a long period, which results in an
extreme temperature rise. Improving the ventilation conditions around the unit might help alleviate the problem.
If after complying with these suggestions, problem is still present, you might need to have the unit checked by a professional for possible circuit failure.
Hope this helps. Let me know.
cancerags
Dec 31, 2007 | Denon AVR-3806 Receiver
Trouble shooting a Denon Reciever
I just picked up a non working AVR 900, there are a total of 4 fuses inside the unit: 2 on the protect board, 6.3A and 8A, and 2 in the middle near the front. I was told by Denon the following might reset the microprocessor. 1) unplug unit 2) press and hold tuner and video select on front panel 3) plug in while holding buttons Unit display should flash until you let go of buttons. Unit stays on you should be ok/ goes back to red- service They also said: There are 3 types of protection that will commonly occur with our receivers. This is designed to protect the unit from permanent damage. 1) Thermal Protect = When the unit overheats this will occur, usually if there is not enough air space above and around the unit. There cannot be anything directly on top of the unit and there must be at least 4 inches of airspace above the unit. 2) Overload Protect = Most commonly occurs when a strand or more of copper speaker wire is not securely connected to the speaker terminal and is touching the chassis of the receiver. If the volume is turned higher than 85% this may also occur. If you need to turn the volume higher than this point to get the level you want, you need a more powerful amp. 3) DC Protect = When an amplifier fails this will occur. This will protect dc current from damaging the speakers. When this happens the unit will need to be serviced. I had a bad 6.3A fuse ? I replaced it and tried to reset. The microprocessor would not reset. I had the exact same results you had. The chip on the back side of the front IC board was smoking. Before I attempted the reset I asked Denon if it was worth sending in for repair. The answer was "NO" BC
Apr 20, 2007 | Denon AVR-900 Receiver
Sony STR-DE345 Receiver Logo
3,880 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
