Question about Minolta EP1083 CS/PRO Copier
Red light is on. - Minolta EP1083 CS/PRO Copier
  • sam gerban
    sam gerban May 11, 2010
    ANY CODES ?
  • Mitch Schwartz
    Mitch Schwartz May 11, 2010
    So turn it off! No, seriously, does it look like a picture of a camera?
    If so, it means you need to do a maintenance on the copier.
    Welcome Back:
    Visited the website for 2 consecutive days.
You have to change imaging unit
Posted on Jan 14, 2009
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
Feb 19, 2011 | RIM BlackBerry Bold 9000 Smartphone
Red rings
Depending on how many you have it means different things:
1 red light - scaler chip E74
2 red lights - overheating
3 red lights GPU and CPU have burnt out
4 red lights - the AV cable is not in correctly
You can fix all of these errors yourself or you can send it in to have it repaired
Dec 23, 2009 | Microsoft Xbox 360 Console
A red light keeps flashing and the screen says error when it comes on
If you have a red light flashing then you have one of the following: 1 red light e74, 2 red lights - overheating, 3 red lights GPU and the CPU, or 4 red lights you need to plug the av cable in.
For the 1, 2 , 3 red lights you can send it in to get it fixed or reapair it yourself with a good guide
Oct 26, 2009 | Microsoft Xbox 360 Console
A red ring is around my xbox start up button
How may lights are showing up?
3 red light is GPU and the CPU overheating,
2 red lights is general overheating
1 red light is E74 and 4 red lights is the av cable.
For the 1, 2, 3, red lights you will need to get it fixed you can either send it in to do this or repair it yourself
Plays games then stops when red lights start flashing
How may red lights are flashing?
1 red light normally E74 error message on screen
2 red lights overheating
3 red lights the GPU and the CPU have overheated.
4 red lights is the AV cable not plugged in properly.
You can fix the 1, 2, 3, red lights yourself or send it in for a fix
Oct 25, 2009 | Microsoft Xbox 360 Console
What causes the 2 red lights on xbox?
1 red light indicates that there is general hardware related problem with the console, 2 red lights indicate the overheating of the console, 3 red lights indicate the red ring of death and 4 red lights indicate that you need to tighten your AV console wire.
Oct 22, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
29 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
