Sony kf60xbr800 need to set the convergence? - Televison & Video
    Novelist:
    Champion:
  • 203 Answers
Use the sony remote to pull up the menue for the tv and then find the convergence menue and try to adjust it there. Most likly it will not adjust and the circuit is bad. This will cost somewhere around $300-$500 to have a repair man fix. It is not common for convergence to go out for no reason.
Posted on Sep 11, 2008
4 Suggested Answers
chesterpendi
  • 195 Answers
SOURCE: how do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking li
Good day!!!
6 blinks its the clear indication that you have bad power supply board..
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Dec 07, 2011
  • 2326 Answers
SOURCE: Sony kf60xbr800 red ghost
There is good information on this site: http://myweb.accessus.net/~090/sonyadj.html#suggested
I would suggest that before you access the service menu and make any adjustments to write the factory settings down for future reference.
Good Luck.
Posted on Feb 05, 2008
Slinteriors
  • 8617 Answers
SOURCE: red convergence out of alingment
If you cant adjust it with the convergence option on the menu you will need new ICs. They are inexpensive. I can post a link where you can get replacement ICs and free step by step instructions on how to do the repair yoursel. The Conversion ICs will have STK numbers such as STK392-110 or simallar There are two of them identical attached to a large heat sink.
Posted on Mar 30, 2008
How do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking lightshow do i fix my sony grand wega tv kf60xbr800 with 6 blinking...
Good day!!!
Nov 20, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
See if you can download the manual from here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KF60XBR800
Also, if you haven't been here already:
http://esupport.sony.com/US/perl/model-home.pl?mdl=KF60XBR800&LOC=3
Hope that helps!
Feb 05, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
I have sony grand wega kf60xbr800. When I turn on power, about one or two minute,it turn off and it blinking on stand by mode light. Could you tell me what wrong. Thank you.
If you can hear the fans kick on when you power TV on and Set does not come on,and the Lamp has never been replaced then Problem will be the Lamp.
Mar 09, 2011 | Sony Grand WEGA KF60XBR800 60" Rear...
I have a sony kf60xbr800 60 when i press power
Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is XL2000 found it here: http://www.discount-merchant.com/SearchResults.asp?Search=XL2000+?Click=48173
Nov 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
There is a double or ghosted image now while watching the TV. It seems to be shifted to the left, almost like a shadow. Is there an adjustment that can be made?
Look on Menu for convergence adjust thier first if this does not help you may need to replace convergence ICs they are Big Black ICs will have part number on them STK-392-110 example. for Pats call Mats 1-800-628-1118
Nov 12, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Convergence problem with TV Pojection Sony KDP65WS550
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Oct 08, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony KP-61XBR200 Convergence problem
STK392-020 ICs are the convergence ICs for your model, you may also want to check the 3.5 amp pico fuses and the 4.7 ohm 1/2 watt resistors as well.
Aug 16, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red convergence out of alingment
Mar 30, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Televison & Video Logo
Top Televison & Video Experts
