Question about Polaroid FLM-3734B 37 in. LCD HDTV
Hum Our set hums until it is warmed up. I see that there is a solution posted somewhere with details, but am unable to locate the instructions.
  • 2,307 Answers
Click here to find the solution.
Posted on Sep 18, 2008
See more detailed question below.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Dec 09, 2015 | Dynex Televison & Video
Car starting sluggish, stalled and would not restart
Your post doesn't say what kind of car or year, so I can only guess. First you need to see if it's getting gas. Turn the key to "run" without turning the engine over. Have someone listen at the fuel cap for a humming sound that will last about three seconds after you turn the key to "run", and then stop. That humming is your fuel pump. If there is no hum, you either have a fuse blown or the fuel pump is toast. It is located in your fuel tank. If you had an engine light on when it started to act up, you'll need to get a code reader and find out what that was. Many other electrical problems can shut down the fuel pump. If the fuel pump is humming, you should check the fuel filter. It is located under the car on the frame somewhere depending on the make and model. It could be clogged.
Aug 18, 2013 | Vehicle Parts & Accessories
Reflex watch setting instructions
there is a area on this site for watches--this is posted in the TV area; You might try to Google the brand/model number with 'manual" to locate instructions for the watch.
Aug 28, 2012 | Televison & Video
How do you set the timer
You posted under mechanical outdoor timer with time dial located on face.
If you have different timer, add a comment.
Instructions:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
There are segments or pins located around outer edge of dial.
If timer has segments.
Pull these segments outward, or leave them in place to set on-off times.
Pull out a few segments and then rotate dial clockwise to see if lights turn on or off with segments out.
Then pull out segments for the times you want timer to turn on-off.
If timer has pins.
Click pins outward, or leave them in place to set on-off times.
Click out a few pins and then rotate dial clockwise to see if lights turn on or off with pins out.
Then pull out pins for the times you want timer to turn on-off.
Some timers also have an override button located on inner dial or somewhere on body of timer.
Move this switch to TIMER or AUTO, depending on your timer
Dec 05, 2010 | Stanley 38445 TimeIt 24Hour Daily Outdoor...
Unable to print
have you try POST i mean power on self test.....?
if not try and see if it can print like that
Sep 09, 2009 | Brother DCP-350C InkJet Printer
When the "no detailed maps found that support routing" screen comes up it covers any of the icons, so I'm unable to do anything.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
Jul 07, 2009 | Garmin nuvi 260W GPS Receiver
Can't see anything on the TV screen
connect you system to a VGA monitor. reste your setting to RCA
Dec 13, 2008 | Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/...
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
1999 Dodge Durango
the humming noise is the front drive shaft u joints as far as the shifting ??????? check the fluid level in the tranny........ fully warm and in neutral..... set the park brake..... it should be in the "hot" area or just under
Oct 15, 2008 | 1999 Dodge Durango
Hum
If the noise starts out fairly loud and decreases or dissapears after a warm up period this is probably the cap problem,which has a detailed solution posted on Fixya.If you replace the 2 caps ,while you are in there I suggest replacing the 3rd 1000 microfarad cap that is very near the 2 10 volt units which are definately bad ones.The repair posting is very good,and if you or a friend can solder it is easy to do.The instructions are really very good.
Aug 14, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid FLM-3734B 37 in. LCD HDTV Logo
51 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
