Question about RCA 32V550T 32" TV
Power cable replacement
Power cord has a short..can i buy this part any place and what is the easiest way to replace..any feedback would be very helpful
  • 41 Answers
You can buy a power cord in any electronics parts store...cut the cord to have a sample...you can connect the new one by splicing it.and twisting it and you should put an electrical tape to it..to make it insulated..
Posted on Sep 10, 2008
How to repair a short it a power cord on a front loading washing machine
have you checked the three places the power cord is bolted into the washing machine? if a nut is loose that could be causing the problem. If you have a shorted cable I would recommend buying a new cable they aren't that hazard!
Sep 28, 2015 | Kenmore Washing Machines
Tip
Lost your USB cord? Replace it cheaply. You also might have a backup cord!
Cant find your USB cable for your Fantom? The easiest way to get a replacement USB 2.0 cable is to go to Wallmart or Target, where the cost is about $8. It is a standard size, but if you go to Best Buy, Circuit City, or any of the big Computer stores, they will sell you the same thing for $32 plus!
You may already have a cable to use--most USB printer cables are the same size--as is the one for my HP Deskjet!
on Jan 02, 2008 | Fantom Drives 120 GB Hard Drive
Heater will not shut off it will run 24hrs. even when temp. is above heater setting
seethis procedure and fix it. God bless you
    • 1 Connect the test leads to your DMM. Insert the black lead in the black "common" socket and push the red lead in the red socket labeled "volts, ohms, milliamperes." Set the function switch on your DMM to the "ohms" function.
    • 2 Use a Phillips head screwdriver to remove the space heater's back cover and disconnect the power cord from the switch and heating element
    • 3 Check the power cord for a broken wire. Touch one test probe to first one blade, then the other blade on the plug and then touch the other probe to the other end of the power cord. If the wire is working, there should be an indication of 0.00 to 0.5 ohms between each blade on the plug and a different end of the power cord. If the meter indicates "O.L." on one or both sides of the cord, the wire is defective. Most often, the wire will be broken right at the molded plug or inside the plug. The easiest way to fix this problem is to replace the cord set.
    • 4 Check between the two sides of the power cord for a 0.00 to 0.5 ohms reading indicating a short between the two sides of the line cord. If the heater tripped a circuit breaker, there is a short circuit somewhere in the heater wiring. Shorts in a power cord usually occur inside the molded plug. The short could be inside the cord set, if it has been pinched or cut. Fix by replacing the cord set.
    • 5 Check the thermostatic switch by placing one test probe on each of the switch terminals. Turn the switch slowly through its complete range. The DMM should indicate a continuous 0.00 to 0.5 ohms throughout the switch's full range of movement. An "O.L." indication here indicates a faulty switch, and you need to replace it. The reason that a functional switch could read 0.5 ohms and not 0.00 ohms is that some DMMs read their internal fuse's resistance.
    • 6 Check the heating element for an open circuit or short circuit. A typical radiant heating element will have a resistance of roughly 15 to 30 ohms. A burned out heating element will read "O.L." and need to be replaced. A reading significantly lower than 15 ohms indicates a shorted or partially shorted heating element, and it needs to be replaced.
    • 7 Reconnect the wires that you disconnected earlier and plug the heater in. Check the blower motor voltage if the heating element gets hot but the fan does not work. This is the only test that you will have to make with the heater plugged in, so use caution here.
    • 8 Set the DMM for "AC volts" and touch the test probes to the motor leads. A reading of 115 volts here indicates a defective fan motor, and you need to replace it.
Sep 30, 2012 | Comfort Zone CZ1500WC Infra-Red...
I am missing half the electrical cord on my LA-2921 6 gal compressor. How do I replace the power cord to the 3 exposed wires?
Pig tails are available thru Lowes in various wire gauges and lengths. Remove cover to pressure switch and notice wiring and replace with new cord (9 to 12 feet will work great). If your pressure switch is inside the cover and you do not want to bother with complicated procedure; just install a male plug on short remaining cord and just buy a 12 foot 14 guage cord. Good holidays
Dec 15, 2010 | Porter Cable Air Tools & Compressors
I just moved and am trying to set my computer back up but can't get my printer to work, I dont know if I somehow lost one of the cords, but I have one cord plugged in the back and it looks like there is a...
You need two cables - one for power and the other for data. The USB cable is easy to replace at most stores with computer accessories. You need a cable with A/B male ends (standard USB cable). If you need the power cable, that may be harder without contacting HP. The end of the power cable may be specific to HP.
I hope this helps.
(Even Walmart has USB cables. HP recommends using a cable that is no longer than 6'.)
Mar 10, 2010 | HP DeskJet F4280 All In One Printer InkJet
The plug to the tv broke off!
One way would be to go to a store that sells electrical parts and buy a replacement plug and install it.
The other would be to replace the whole cord, much more time consuming and probably a bit more expensive. I'd just go and buy a new plug.
Oct 07, 2008 | Televison & Video
Power loss
Yes you will be able to replace the power cord and transformer (the black box).
Just to be sure thought. Shutdown your laptop and plug the cable into the laptop again. The laptop should show LED's on the front of it to show that the power is plugged in and is charging the battery. This is usually symbolised by a green or orange led.
The easiest thing to change for now would be the cable but if you continue to have issues you may have a larger problem with the power input module within the laptop itself.
Apr 24, 2008 | Toshiba Satellite M45-S265 Notebook
RCA 32V550T 32" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
