Question about Mitsubishi WS-65809 65" Rear Projection Television
Tv bows i have a 65in mitsu 1080i tv 6 years old it just recently started bowing at the top and bottom?????? do you know what it may be??
  • sgriego Sep 11, 2008
    is this menu the Convergence menu on all the rear projection TVs? I have a 65 inch mitsubishi and my TV is doing the same thing. It happened after the earthquake we had here in CA and ever since i see double vision and i see the person in red blue and green. I'm not sure which model I have but I will take the advice and see if I can find this section of the menu on my tv. Thanks for the tips!
  • 3 Answers
I have the same TV and just finished having my TV repaired for the same problem. I was unable to converge the colors even in the advanced convergence setup menu. The lines were bowing so far that adjustment was not possible. I had to replace the vertical and horizontal convergence controllers located on the main electronics panel. They require a lot of soldering and should be done by a professional. Unfortunately this is a common "maintenance" repair that happens every 5-7 years, depending on the usage, costing around $500.00 for in home repair. DO NOT USE YOUR TV IF THE CONVERGENCE IS BAD AS IT MY CAUSE THE POWER SUPPLY TO BLOW resulting in addition repair costs.
Posted on Sep 12, 2008
    Novelist:
    Champion:
  • 203 Answers
Sounds like convergence or vertical. Are you seeing double vision? Also try going into the menu and under advance you should see the convergence menue try adjusting the colors and see if they move. Once you give me this info i can help you more.
TIm
Posted on Sep 11, 2008
Mitsubishi WS-65615 65in TV blinking
needs capcitors in power supply they will be bowed on top
Jun 08, 2009 | Televison & Video
Picture Bowed towards the center
It is a convergence problem, probably one of the convergence ICs has blown and must be replaced. Call the number in the last pages of your user manual to get repair service in your area.
Jul 25, 2008 | Mitsubishi WS-65413 65" Rear Projection...
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Pioneer SD-532HD5 - Picture Bowed on sides only on 1080I
The problem you are describing is known as a pincushoin problem. I'm a bit surprized that you only see it on the 1080i signal though. I've inquired at my Pioneer contact about this and will update this soon.
Stay tuned...
Dan
Jan 07, 2009 | Pioneer SD-643HD5 64" Rear Projection...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Problem with convergence
bad convergence ic's
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mitsu 55'' screen
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs (STK392-570), have a basic knowledge of electronics and be able to use a soldering iron.
Feb 17, 2007 | Mitsubishi WS-55807 TV
Mitsubishi vs 60719 - Wavy bow in picture
Either a bad solder connection on your convergence module or a bad convergence IC. Repair costs will probably be in the $350-$500 range.
Jan 28, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Bowing image top and bottom of screem
No im sorry there is nothing to do but replaceing the convergence IC
Oct 30, 2006 | Toshiba 55H70 55" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
