Question about Acer Aspire 3050-1733 Notebook
Error Loading Operating System
Was running XP pro sp3,is'nt running now.Black screen says"error loading operating system" Do I need some kind of boot disc or ???
    Novelist:
  • 116 Answers
Do you still have the original recovery disc for the PC? If so, put that into the disc drive then boot the computer. It can help you either save the installed operating system or create a new one if there is a serious problem.
This could also be due to a hard disk drive failure, in which case you'd be needing to get a new hard disk. Most of the time however, just a file allocation table messes up during a power down, or some other random problem happened and just caused a simple error on the drive. I'd definitely find that recovery disc. If nothing else, you can use google to search for recovery boot disks that you can download and burn to a CD using a different computer. They can help as well.
Posted on Sep 10, 2008
When i start my laptop it shows that error loading operating system with black screen and it cannot boot window xp cd????????????
This means that the system files are corrupt or that the system can not locate the device with the operating system on it.
Boot your laptop while pressing F2 and go to the System BIOS. In the BIOS look for boot order or boot sequence. Then select the HARD Disk Drive to be the first booting device and let the CD Drive be the second one and press F10 to save and exit. Observe the results, If it gives you an error message again, try to go back to the BIOS and load Default System settings and restart your laptop again.
If you try all this and you still have the same problem, then organize an XP CD and change the boot device to CD Drive. This will let your laptop boot from the CD. When the CD loads, press enter and after accepting the license agreement (by pressing F8) select "R" to repair your operating system.
NOTE: Do not press "R" as soon as the CD finishes loading because this will induse the Automated Repair, and that is not what we want here....
Man, this will work you out of your trouble. Good luck
Aug 17, 2011 | Computers & Internet
Error loading operating system - Windows Xp
If you are attempting to use Recovery and this is happening, Most likely you have a corrupted recovery partition....
If you are attempting to load Windows XP from A CDrom (Externally)
you will need to use an XP Cd that has integrated Sata drivers.. Windows home/pro 32bit does not..
Or Use a Windows Media Center Edition Version
Nov 18, 2009 | Acer Computer AOA150 Notebook
1. The reason it says "error loading operating system" is because kill disk wiped the operating system from off your computer.
2. Now that you have the installation disk, you need to tell the computer to boot from it. For Dells, usually press F12 when the Dell logo appears, and it should bring up a boot menu. Select the optical drive and it should boot. If you do not see a boot menu, go into your computer's BIOS and tell it to look at the optical drive first when booting, then it will boot from the disk.
Jun 28, 2009 | Dell Inspiron 1100 Notebook
C640 can't boot up
Ok.Better reinstall the os.Because disk boot error cannot be solved is suppose...To install the os follow these steps.
Step 1:Power on your system and press DEL key
You will see a blue screen with some options on it in white. (you can only use your keyboard to navigate in this screen). Go to the Advanced Setup Options ---> then select Boot Priority ---> 1st Boot device to be Floppy drive , 2nd Boot device to be CD-Rom drive
Step 2:Insert the Bootable DOS floppy in your Floppy Drive. Press F10 to save the bios settings and exit. (Your system will re-start automatically)
Step 3: Let the Dos load from the floppy and A: shows up.
Step 4: Change the Command prompt to HDD Drive letter, it will be D: or E in which u have Xp cd contenet.And type If xp content in d:under x folder mean.D:cd\x and press enter.
Step 5: now type on the D:\ prompt -- setup.exe and press enter
Step 6: follow the prompts there after. and for more info contact http://tinyurl.com/m7ghqz
Jun 19, 2009 | Dell Latitude C640 Notebook
Error loading operating system in dell
You may be right , the harddrive on the system may have gone bad.
You can run a diagnostics on the hardrive,shut down the computer, and then Press the Fn+ power button at the same time , it would initate the diagnostics.
Do post the results back
Thanks
proton
Apr 05, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Press the F2, and laptop will go to the bios where you will be able to change the boot order from the hard drive to the optical drive.
Mar 11, 2009 | Acer Aspire One PC Notebook
XP-Pro Crash
I don't know why but some systems which have XP (SP1 or SP2) simply can't take the upgrade to SP3. Your system appears to be one of them. For instance our family's computer had XP SP2 and upon upgrading to SP3 we received a fatal crash while XP was loading into normal operating mode.
I managed to resolve the issue by booting to safe mode and restoring the system to a date before I installed SP3. Sorry that the new SP doesn't work for you.
Feb 03, 2009 | Microsoft Computers & Internet
Error : loading operating system
plz try to boot in safe mode run check disk and then boot normally, if the problem arises then try by repairing the operating system. plz post your findings
Jan 12, 2009 | HP Pavilion ze2000 Notebook
Acer 4720Z lost vista os
Most likely the hard drive went out, do you hear a clicking noise or loud ticking coming from the laptop?
Does it give you any kind of message like " NTLDR missing."?
Let me know.
Dec 16, 2008 | Acer Aspire 3690-2196 Notebook
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Acer Aspire 3050-1733 Notebook Logo
117 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
