Pressure Washers
Problem for Pressure Washers
Generic problem for all Pressure Washers
Power washer does not work
By jdredman on Sep 10, 2008
I have a Sears 1350 psi power washer. It is probably 10 years old but rarely used. My neighbor borrowed it, it worked for 10 minutes when he brought it back, but now does not come on. Recently I hooked up the water, plugged in the power cord, turned it on and then pulled the trigger. It started to spray, for about 2 seconds and then just went to a trickle coming out of the wand. Even with the trigger pulled, the motor will not start up.
Any ideas?
Same Problem
Oct 03, 2008
-   1800 psi pressure washer runs but no pressure -   Guest
Best Solution
posted on Feb 20, 2009
Helpful)
mrfixit-jerr
Rank: Guru  Tools - Building & Power  Expert
Rating: 94%, 7687 votes
hello sir,that is ongoing problem with power washers the pump not working. than working sporadically. the main cause is leaving the pressure hose hooked up to machine over a long period not draining hose & machine,in winter time the hose & pump will freeze causing hose & pump to expand and burst.build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be the problem.hope this helps,good luck,MrFixIt. oh could you please give me a rateing.thank you.
Comments:
Mar 24, 2009
- Hi please don't shoot the messenger ! I went out of my way to help you for free ! did a search done some asking trying to solve your your problem to the best of my knowledge. im sorry that the answer was not good enough or you didn't understand the answer. so could you please rate the solution anyway,thank you,MrFixIt.
Was this helpful?
Yes
No
15 people thought this was helpful
Popular Solutions for Pressure Washers
Questions and Unsolved Problems for Pressure Washers
Answer
do all troy bilt pressure washers have brass pumps?
Answer
Hi, my Karcher steam cleaner is working ok apart from the burner does not come on to supply hot... (More)
Answer
karcher K2.91M lets water in and out but won't pressure up. Motor just makes a noise
Answer
low water pressure and no heat
Answer
water leaks out between brass head and the carter #190626Gs
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Pressure... Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
