Question about RCA F36444 36" TV
Will not turn on?
When I push the power button, on the tv.the button flashes then goes out.if you push button alot it sound like it might ,but will not. remote will not turn tv on also. Tv is four years old, I hope it could be fixed. Could someone give me idea what it could be .Thank you,
  • 1 more comment
  • koran Nov 01, 2007
    I have a sony TV as well and it turns on when it feels like it usually in the morning but if I go to turn it off and then back on it will not turn on until the next day. The red light flashes and it makes the sound like it is going to turn on, but the light just flashes and then it turns off. We bought the TV in 2003 for over 3000 this should not be happening. I called remairman and TV will cost over 350 in parts and 200 labor I don't know what to do.
  • Anonymous Nov 13, 2007
    tried to turn tv on with and without remote it just makes a click noise but no picture
  • AJHTER Feb 28, 2008
  • 4 Answers
Tell the technician to replace the starting capacitor in the voltage section the value of capacitor is 50v/100uf or 50v/47uf.....good luck
Posted on Jul 30, 2008
Flyback transformer is bad
Posted on Jan 26, 2008
I have had the same problem twice. The complete PC Board had to be changed on mine for it to start working again. The part usually runs around $150 not including labor.
Posted on Dec 16, 2006
  • 513 Answers
A couple of easy things you could try is to unplug the TV from the AC over night, to let it discharge, and see if theres any difference, and also try to connect it to another power outlet. anything else is a bit tricky - if you have no electronic repair experience you should take the set to a repair shop. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. Its possible that you got some dry joints, look for poor soldered joints on the high voltage side, and resolder them. Good luck
Posted on Mar 29, 2006
Recently we replaced the bulb in our LG 52SX4D-UB. Once the bulb was installed we reset the hours for bulb according to the instructions that we reviewed on-line. Once the power button is pushed on the...
Tv goes off and on.It have alots of clicking noise sounds too?Yes.The board that call the Ballast board it is also dead too.The Ballast board only job it is to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Apr 03, 2011 | LG 52SX4D 52" HDTV
Will not turn on?
the lightining battery is not working very well. You should exchange it, so the TV power could get to the Tv and let it Work.
Feb 28, 2008 | RCA F36685 36" TV
Tv wont turn on used it for two months and one day it turns on then the power led light flashes and the opc led light ...
This tv still under warrenty?Yes take ur warrenty repair.This problems very common on Sharp LCD tvs.I have one too.This tv have a Tuner signal board problems.But this tv still use able.Just push power button again after the POWER and OPC flashes.POWER and OPC some will flashes again and wait just push the power button again and wait.Sometimes have to push power buttons and wait power button push out of three or four times power button push POWER and OPC flashes.Than tv will work again.
Jan 06, 2011 | Sharp LC-52D64U 52 in. LCD HDTV
TV power button comes on to turn tv on & goes right back off but nothing on screen & no sound
Hello
This could be alot of things but I tend to lean towards a power supply issue. The short story is that when your tv starts up, it checks alot of things to make sure they are correct. If one of the voltages is off, then the tv protects itself and turns back off. In my experience when they turn back off its almost always power supply issues. It could be a card pulling down the powersupply, or the neat gizmo that powers the light. But I have not seen alot of that.
Generally if its not a power supply fault that the tv just cant tolerate it will flash a code at ya. Blink blink (Im messed up and here is the number of the fault) Blink blink BLINK!
I wish I had better news, however powersupplys are one of the cheaper and easier things to fix.
Best of luck
Nov 25, 2010 | Mitsubishi CS-32307 32" TV
Rca model D52W20BYX1 comes on for a moment then goes off rite away
rca model d52w20byx1 itc222. sounds like shutdown mode. Does the led flash. unplug the set leave set unplug for 30 min. this reset procesor. now i tell you this in the shop its never that simple but it first step. IF you have a flashing led when you push power button. it tells you alot. it tells you main fuse is good the processor is getting power and it detects something wrong. leading causes are shorted horzontal output transistor. shorted cp150 capacitor. technicians have a computer that read error codes much like that of a car. let me know if i can help troubleshoot it down.
Nov 23, 2008 | Televison & Video
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
Aug 29, 2008 | Mitsubishi Televison & Video
Flashing light - video going out
When you push Power Button on remote, TV goes to Standby state i.e its power light (LED) lit but no picture / no sound. Power button on remote has symbol looks like.. ( ! )
Aug 14, 2008 | Sony KP-53HS10 TV
FLM-2011 will not turn on
does anyone have the answer to this problem. it seems like alot of polaroid tv's are doing this. please if anyone knows how to fix the tv and get it to turn back on and not flash red to blue anymore, please let us know.
Jun 28, 2008 | Polaroid FLM-2011 Television
Help ,help.
On- timer light flashing no picture no sound.
Dec 23, 2006 | JVC AV-32D502 32" TV
RCA F36444 36" TV Logo
272 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
