Question about Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only
7336 orbital sander
How to replace sanding pad
  • Anonymous Mar 19, 2014
    my sander wheen i go to sand it just freezes up uts like the orbital is crooked
    New Friend:
  • 55 Answers
If you are talking about the actual sanding pad itself it should just pull of .If you are talking about the backing pad it should un screw
Posted on Dec 04, 2008
Where can i obtain a sanding pad for a ryobi HRS115K Orbit sander
The 4 1/2" 8 vac hole Hook & Loop back-up pads for the Ryobi Sander are no longer available, But you can apply a new hook surface to your present pad $3.75 each conversion disc at Supergrit abrasives , Gettysburg, PA 800 822-4003
Jul 03, 2014 | Tools & Hardware - Others
How do I remove the rotating disk on a porter cable polisher model 7336
You have to use a wrench behind the disk for a stop and then unscrew from the housing Porter Cable
Feb 23, 2013 | Porter Cable Porter-Cable Variable Speed...
Installing brushes in porter cable 7336
Go on line to porter cable customer service ask for a blow out of the motor of your 7336 assembly 6 inch variable speed sander they will have the parts blow up showing each part with a line going into each area where the parts fit together Good luck
Aug 26, 2012 | Porter Cable 7336 6 Inch Variable Speed...
I have a Mastercraft random orbital sander Model 54-7206-2 and need a dust bag. Is it available, how much, and how do I order it in Canada?
I just had the same problem. I couldnt find any information online.
call the toll-free help line
1800-689-9928
Tell them the make of the sander and what kind of part you need. They will look it up and ship it to you in 7-10 business days
Feb 20, 2011 | Porter Cable Porter-Cable Variable Speed...
The sander is chatterin g on the oak wood and only barely stops if I apply a whole lot of pressure. I don't want sanding marks so how can I fix it?
You may be applying too much pressure. Also it is my experience with this type sander that one has to use the side of the pad. If you try to use the whole flat pad they chatter. For flat sanding I use a "Jitterbug" type sander. What you have is for coarser work I SUSPECT than what you are trying to do. The quarter sheet type would probably be better for you.
Sep 05, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Slows down and looses power intermettently
you need new brushes or clean out the holes they go in so they move freely
Aug 08, 2009 | Porter Cable Porter-Cable Variable Speed...
Orbital sander doesnt orbit!
Never start the Sander without first placing it against the surface to be sanded. In free air the Sander will not osolate.
Jun 12, 2009 | Makita BO5010 5" Random Orbit Sander
Porter Cable 7336 polisher - pad/backer plate will not begin to start without starting it by hand. Will changinging the brushes fix it?
The first thing to do is to make sure the unit is completely clean. Many of the contaminates that get airborne while you are sanding can and will affect the motor's performance with time. Pay particular attention to the brushes/commutator or any kind of centrifugal switch it may have.
Jan 02, 2009 | Porter Cable 7336 6 Inch Variable Speed...
Porter cable beffer
Check for string or build ups where the spindle come out of the housing, a little light oil at that point will help, 3-in 0ne is good, not to much, a little goes a long way
Porter Cable 7336 6 Inch Variable Speed Random Orbit Sander Only Logo
432 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
