Question about RCA T27TF668 27 in. TV/VCR Combo
TV is dead
When I try to turn the TV on, the red ON/OFF led comes on (front panel) both manually and via the remote, but nothing happens. VCR starts playing upon casette is loaded, but stops in a couple of seconds. Kids told me they saw vertical lines for a couple of seconds the other day and the unit went dead. We can not turn it on now. What is the problem? Is it the tube? If it is, can I change it myself, or that is not possible?
  • 513 Answers
Could be many things, possibly a vertical IC failure, or bad soldered joints, or problems with the power supply. Considering your questions, if theres a problem with the tube, you don't want to change it, it won't be worth the expense, and since you're asking, then you probably shouldn't try anything with it. VERY dangerous, more or less like a microwave. TVs store very high voltages even when unplugged. What you could try is to unplug the TV over night, maybe the TV needs a bit of a discharge. also try another power outlet. other then that, you better take it to repair shop. Good luck
Posted on Mar 29, 2006
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Sanyo vwm390 vcr
That might be the TV output channel. I found these instructions in a Sanyo manual:
How to set the DVD+VCR's RF output channel 1. Set the TV to the VCR channel (3 or 4) depending upon the selected channel. 2. When the DVD+VCR is turned off, press and hold CHANNEL (V/v) on the front panel for more than five seconds. It will turn itself on and "RF03" or "RF04" appears in the dis-play window. 3. Press CHANNEL (V/v) on the front panel or CH/TRK(v/V) on the remote control to change the RF output channel (CH 03 or CH 04). 4. Turn off the DVD+VCR.
It might solve the problem!
Jan 01, 2014 | Televison & Video
IHAVE REMOTE PX-RC1 ILOSE THE CODE BOOK & TV NAME PRIMA
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED should stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. Then press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.
Dec 24, 2010 | Universal Remote Control MX-500 LCD Remote...
I have a living solutions jumbo remote and im trying to program it but it does not have a code search button like every manual i seem to find on the internet says to hold what do i do?
Here are the code search instructions for the Innovage Jumbo Remote that you are looking for.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 06, 2009 | Innovage Jumbo Remote Control
Programming the innovage remote
  1. Turn on your TV.
I hope that helps.
Oct 04, 2009 | Innovage Jumbo Remote Control
SANYO DP26647 blank screen, please help
U have LED front power tv light come on and bliking?Than ur power suply it dead.Power supply board must be replaced.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board.
Sep 21, 2009 | Sanyo DP26647 26 in. LCD TV
No manual. How do I install (program ?) jumbo innovage.
To program your Innovage Jumbo Remote Control, you can ask it to cycle through all the codes it knows for TV's, DVD's, SAT boxes etc.
  1. Turn on your TV.
To program for your VCR, repeat the steps starting with turning on your VCR, and substituting the VCR button for the TV button.
I hope that helps.
Jul 31, 2009 | Innovage Jumbo Remote Control
Need directions to use the code search of my jumbo remote
  1. Turn on your TV.
I hope that helps.
Jul 13, 2009 | Innovage Jumbo Remote Control
No power to tv
You say didn't do anything, Like did you hear a squealing sound or did you see led lights on front of panel or just dead nothing? If dead and nothing then look for fuse blown in power supply if not then there maybe a small sound coming out of set when you press power if so then the power supply is trying to start up then you will have to look elsewhere like horizontal or convergence or vertical areas.
Sep 18, 2007 | Philips 51PW9363 51" Rear Projection...
TV/VCR seems to be dead
sounds like it may be tripping line output transistor gone, due to dry joints on the base driver transformer, just check if you have a red light at front and its constant or pulsing
Apr 22, 2007 | Zenith TVBR1322 13 in. Combo
RCA T27TF668 27 in. TV/VCR Combo Logo
180 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
