Question about Gateway GTW-P42M303 42 in. Plasma Television
GTW-P42M203 My plasma has a green power light but is showing a black screen. What part or parts can I check or replace. I am an electrician with 15 years experience can you help me out.
    Scholar:
  • 83 Answers
Has the childlock function been activated?
Posted on Sep 14, 2008
I have a 2002 42 inch Plasma made by Gateway I can power up but tv clicks back off without ever showing a picture-the green power light remains on but no sound no pic-I used to be able to unplug and p
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to plasma screen are given with illustrations. You can get an idea about the fault to an extent. It is not easy to include all here by this window.
Dec 04, 2014 | Gateway GTW-P42M303 42 in. Plasma...
Tv black with red green yellow dots but when warms up it alright
Try backstepping the set resolution on your TV to see if that cures it.
Please rate my help++++Thanks for using FIXYA
Mar 06, 2010 | Gateway GTW-P42M303 42 in. Plasma...
I have a Gateway gtw-p42m303 powers up to the warm up screen then light switches from green to standby orange. smells hot could be a power supply or capacitor?
Most likely a Y sustain module failure. Gateway does not make a set, so I would need a part number off of the board in order to give you an exact price of the part. Usually they're around $300.00
Nov 13, 2009 | Gateway GTW-P42M303 42 in. Plasma...
GTW-P42M203 shut off and will not stay on
Chances are there are cracked solder on one of the boards. This is a common problem with Gateways. If you're handy with soldering then this is an easy fix.
Jun 30, 2009 | Gateway PLSM42TV 42 in. HD-Ready Plasma...
The screen on my Gateway Plasma 42 in TV went blank tonight. There is sound.Model GTW-P42M203. We purchased it in 2003.
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. The question will be, is the part still available? Before paying a TV repair person $75+ to diagnose the problem, ask yourself if you're willing to pay $250 minimum to fix this particular set. Also keep in mind that most TVs that old have a very limited number of replacement parts still available. Normally it will cost at least $75 to have the set looked at by a repair shop (diagnostics). If the part needed to complete the repair isn't available, you won't get that money back.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Jun 18, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Gateway GTW-P42M102, first sparks, now flashing green lt. in back
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 21, 2017 | Gateway GTW-P42M303 42 in. Plasma...
Gateway plasma tv
I was able to resolder the pin shown in the picture and it fixed my problem as well.  I also used a razor and cut off the last socket for that pin on the connector and put a dedicated connector on so that it will take the heat a little better.  Also when I re-soldered that pin on the bottom side of the board I scraped away some of the protective coating around the solder puddle so that I could make a bigger solder puddle to add a little more strength and heat resistance.
Dec 26, 2007 | Gateway GTW-P42M303 42 in. Plasma...
Non working TV, can someone help???
Replace Q8023 (top224y) which you will find is blown apart or it's shorted, and the Q1 (2sk2662) which would check to be shorted inside the heat shrinked wrapped board next to the blue relay and the smd zener diode ZD8018 (shorted) along with the ceramic fuse F8001.
I don't remember the value for the zener diode but there's lots of them with the same color code. You will have to take one of the others off to test on a resistor jig to get it's value.
The 2SK2662 is a cross for the original.
Nov 29, 2007 | Electrograph Systems DTS42W 42 in....
Gateway GTW-P42M303 42 in. Plasma Television Logo
610 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
