Question about GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker XL 1800 undercabnet microwave
Im am trying to find the lightbulb thats underneath the microwave cannot find the bulb or how to install it... LIGHT BULB BLEW OUT
  • 2 more comments
  • askmmc Sep 22, 2008
    On model number JVM1650BB008, We are having a hard time trying to replace the light bulb underneath the microwave. We are having a hard time removing the blown out bulb. We need assistance on how to remove and replace the light bulbs under the microwave. Our email address is askmmc@yahoo.com.
  • incontrol Sep 25, 2008
    Cannot get the replacement halogen bulb into the socket on my GE Profile Spacemaker XL1800.
  • Anonymous Dec 07, 2008
    I was able to remove the bulb with a little wiggle. Now I cannot get the replacement bulb in at all. I broke one trying to get it to plug in!
  • have_problem Mar 14, 2009
    I cannot find a replacement bulb for my GE profile XL 1800 undercabinet microwave. Does anyone have any suggestions for the bulb and where can I buy it?
  • 868 Answers
Remove the light cover /filter opening.Its very easy to remove.The filter will be removed by hand and may give you the best reach.
Please rate this !!
Posted on Sep 10, 2008
    Problem Solver:
When you say, remove the filter opening, do you mean the little plate the flops down when you open it? The bulb seems to be wired into the microwave on my Spacemaker XL microwave. It fell out when I opened the hatch to replace. It doesn't appear to be screw in. Seems like it is wired or something. The black housing for the bulb will not twist or pull off.
Can you enlighten me?
Judy in St Pete
Posted on Sep 27, 2008
SpacemakerXL GE Microwave changing bulbs:
When I twisted the bulb to replace it, it broke off from the housing and was really hard to get off. I unscrewed all the screws that holds the cover then when the bottom metal cover of the microwave is lowered it is an easy access to unscrew the bulb housing and pull it to the front. This way it is easy to work and undo the broken off screw part of the bulb.
Posted on Jul 08, 2009
I almost did the same thing but when I realized it was not turning, I began to press in on the bulb so it would move the other piece as well.
You must have broken the bulb off the part that screws in.
1. Unplug the microwave from the wall outlet.
2. Get some small needle nose pliers or maybe even try tweezers, to unscrew the piece that you have left in the black housing.
I am trying to locate a replacement bulb and will post my findings on that issue.
Posted on Dec 30, 2008
The microwave its power protected
Posted on Oct 05, 2008
3 Suggested Answers
SOURCE: ge profile spacemaker XL 1800 undercabnet microwave
hold down the clear/off button for 3 seconds and it will unlock..
Posted on Apr 15, 2008
Home depot sells the lights as I believe reffigeratro bulds. bring the old ones with you to match them up. i got a price from an appliance parts place of $40. The depot was like $6.
Posted on May 08, 2008
The lights on the bottom of my microwave will not turn off. This started when I changed the bulbs due to the old ones burning out. Anyone ever heard of this? Thank you.
If you put in higher wattage bulbs than designed, your bulbs may have caused the control device (relay contacts/triac/diac) to permanently fail thus allowing the circuit to always remain energized.
Apr 30, 2015 | GE Profile Spacemaker XL 1800 36"...
How do I replace the light bulb inside the microwave
Usually you have to remove the top cover, then the globe can be changed, cover is held in place by screws, make sure power is off as dangerous high power can harm you, best left to a specialist
Jan 30, 2015 | GE Profile Spacemaker XL 1800 36"...
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
Jan 28, 2014 | GE Profile Spacemaker XL 1800 36 in....
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
Ge profile spacemaker 1800 xl microwave no heat
The magnetron tube may have died. Not worth repairing unless under warranty.
Feb 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker xl microwave oven will not heat
My guess is the magnetron is bad. It is rarely the transformer
Jan 04, 2013 | GE Profile Over the RanMicrowave....
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Jan 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
2,664 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
