Cant seem to transfer my photos to computer, i did everything it says in manual ,but when i connect the camera to the usb port nothing is coming up on the computer to recignise it
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
There are two ways to import your photos. One, your camera should have an sd card which you can eject and put into your computer. The sd card should have all your photos and videos in it. Typically the card is located near the battery and you can press down on it and it should pop out. You may also need a sd card reader or micro sd card reader if it doesn't fit in your computer. Second, your camera should also have a usb port, whether micro or mini or whatever. It should have a port to connect to your computer through a usb cable. In this case, just connect your camera to your computer and it should show up on your computer like an extra drive where you can go in and see all your photos. Also, the folder that holds everything is usually labed DCIM i believe. Hope this helps.
TRANSFERRING PHOTOS TO COMPUTER If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
First. reboot the computer. If you leave your computer on all the time, an occasional reboot will often clear up an unresponsive program and "sharpen the teeth" so-to-speak. If you've done this, try going directly from USB cable to the camera. If it is still unresponsive, try plugging into a DIFFERENT USB port on the computer. If you've done all of this with the same cable, try using that cable and camera on a different computer. If it is unresponsive there, you may suspect the cable as being bad. Try a different cable. If you're still having issues, suspect that the USB port in the camera has gone bad and have a reputable repair shop take a look at it.
My kodak easyshare camera will not transfer my photos to the computer.
Everything is plugged in and the camera is blinking but nothing is
happening. Please help. I checked the connections, they are fine.
