posted by stosh on Mar 29, 2006
Hi
I was watching tv(we have comcast cable)and I
hit a button on the comcast remote control. I lost the picture and have not been able to retrieve it. I tried to use the remote control that came with the tv but was unsuccessful....I need help. Thank you, Warren
Solution #1
posted on Mar 29, 2006
Its possible that you changed the channel or the input line your TV gets the cable signal from. unless you caused more of a problem while trying to fix it, I would suggest you to go through the TV(not cable) channels to see if you can find the one that gives cable picture, or to go through the different input settings(TV/AV on older TV's, and 1, 2, 3 etc on newer ones). one general icon for the later is an arrow going into a circle. I think its the "select" button on your TV remote.
Good luck
Good luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Philips 30PW8402 30" TV
Email this problem
Email this problem
This Problem Also Relates To:
GE 27GT277 27" TV
GE 27GT722 27" TV
GE 13GP341 13" TV
Panasonic CT-32G6 32" TV
Panasonic CT-36SX12 36" TV
Sony KV-32V42 32" TV
Sony KV-32S26 32" TV
Can you Help with these Standard Televisions problems?
36inch Sony Wega KV-36HS420...
The TV will turn on I will hear... Answer This...
Panasonic 30 inch just an...
Just an electric line middle of... Answer This...
Repair Service
Find Standard TV Repairman Near You:
