Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White Logo
jeni higgins Posted on Aug 29, 2011
Code f31 shows when try to turn on oven - Frigidaire Gallery 30" Self-Cleaning Freestanding Gas Convection Range - White
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Aug 30, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
1631
Points
9
F31 means there is a short in the oven cavity probe circuit. The probe is the one of easiest things to replace. But this could be a control as well. To start, remove power from the range, unplug it. Remove bottom backguard panel, look for two purple wires leading down to a small white connector, which will lead you to a rectangle piece of metal (approx 1 X 3/4in) with one corner tucked in the body and a screw on the other end. This will be located on the right hand side of the back about half way up. Once you remove the screw, twist from the corner, slide out gently. http://b2b.frigidaire.com/support/manuals.asp?user=&NewSearch=New+Search will provide documentation for a part number for the "probe" or may be called "RTD."
I would be glad to provide more detail if you like, I would need more details in return...
4 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Dec 30, 2008
SOURCE: oven not turning on f31 code kenmore
may be a real simple , lets try this. unplugh the unit, and uscrew rear panel of the unit, there is a thermostat that may have tripped, very small maybe the size of a quarter, with 2 wires on it, easy to sppot because it will have a small red button atop of it, its resettable, so if it did "trip" melrey reset and your on your way,there are actuallly 2 of theese thermostats on your unit, and actually a more common one to trip would be the one in the control panal, so id prblaby check this one first, to acces it remov eht knobs, then wehere the knobs were are "large plastic lock washers" holding down the control panel, one around earch knob opening, after ermoving htem the control panel will lift up and lean over. i belive there are 4 screws to remove the clock(plenty of slack in wiring no worry)after thats out of the way, if you look down under behind the switch to right is the same resetable thermo(lok for the the red button) and with a small long screw dricer youll be able to reset it, this should cure you issue. sounds like a ton of directions but should take no maore than 20 min, to check em both
A
Anonymous
  • Posted on Mar 03, 2008
SOURCE: f31 code for kenmore oven
Hi Jim,
I have the exact same problem on my Kenmore oven. Did you get any help as to what it is? My email is [email protected]
Thanks,
Oren
Mike McWhinney
  • 537 Answers
  • Posted on Apr 18, 2009
SOURCE: oven does not start and gives code 31
Check this link:
http://www.applianceblog.com/mainforums/showthread.php?t=11880
It sounds like your oven probe is failing or has failed. The control board could possiblly be bad too
Anonymous
  • 6784 Answers
  • Posted on Dec 15, 2009
SOURCE: oven shows error F31 when trying to bake
F31 - Shorted Temperature Probe connection
Check the sensor probe connections for damage. Make sure it is plugged into the socket, all the way, when the oven is in use. If the connections are sound, and not separated from their respective contacts, replace the temp probe.
Turn on over and get F31.
Hello, Janice -
There are many ovens in use today. It will help to know the make and model of your oven. You can add that information by choosing Comment and typing in the make and model of your oven
If yours is a Kenmore brand oven, the F31 error code means that the oven temperature probe has shorted out or there is a shorted sensor probe harness connection.
Sources of information + repair instructions:
https://www.shopyourway.com/questions/1068107
and
https://www.shopyourway.com/questions/1036659
If your oven is a Frigidaire gas oven, then the F31 error code also means there is shorted oven temperature sensor probe or a shorted sensor circuit.
Source of information:
https://www.shopyourway.com/m/questions/1018474
I hope you have the owner's manual for your oven. The F31 error code will probably be described in the manual.
Best wishes.
F31
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Oven wont start, shows F31 error on display
What is the complete model number of the unit?
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
When I try to turn on oven the code F31 shows
Hi and welcome to FixYa,
I am Kelly
See this link:
http://www.applianceaid.com/faultcodes3.html
Scroll down past mid page and read F31
Your Temp probe is shorted. It shuld read around 1091 Ohms (+or- 5.3 Ohms) at 75 Deg.
If you respond with your model number I can point you to parts sources.
Thanks for choosing FixYa,
Kelly
1helpful
Oven shows error F31 when trying to bake
1helpful
My Frigidare stove Model FGFL67DBD will not light the oven. A display of "F31" comes up. What's the deal. My name is Brenda.
F3 is the oven temperature sensor, F31 may be a similar code. If you are comfortable with your own repairs, you can remove the panel covering the controls and check the connection to the oven temperature sensor. Remove power to the over before removing any panel. Once the panel is off, make sure all connectors are firmly seated, connect and disconnect the plugs ensure a good connection. If this does not resolve the issue, try Appliance Parts Pros to order a replacement sensor. The wiring diagram that shows what color wires are the temperature sensor is usually secured to the back of the range, inside the storage drawer, or inside one of the service panels.
Otherwise, you will need to call a tech to repair the problem.
1helpful
2answers
F31 error
it is a shorted oven probe sensor
Apr 09, 2008 • Ovens
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
