Question about Intel Motherboard
RAM for Intel E210882 mboard
Need to upgrade PC w/ 2, preferably 4GB RAM.
What type of RAM could be installed on Intel E210882 m board
  • 1 more comment
  • Pavel Syngaevsky Sep 22, 2008
    Ye, it does
    At least partially.
    I've got 4 GB RAM, after installation PC shows only 3.23 GB.
    Is it a MB limitation or...?
    Thanks
  • ausintokyo Nov 25, 2008
    Hmmm, my MOBO is also an E210882, and I also want to upgrade from 1gb of ram to 4gb (or at least 2gb).
    The reason for my comment though is that the ram that I currently have in is 2 * 512mb chips - they are not DDR, but actually 533 MHz DDR2. I am therefore assuming I can replace these with DDR2 ram, just not sure if I can go higher than 533 MHz though?
    I have had my PC with this MOBO and ram configuration for 3 years so far. Recently my machine started crashing a lot (wont stay up for more than 5 mins recently), so thinking it may be a ram issue as I have completely wiped and reinstalled XP with no success.
  • Mantagtj May 11, 2010
    Actually xp will only show up that much and is only limited to that much if you use vista you can go up to 8-16 gig and it shows!!!
    Trouble using XP is this problem!!
Is because yo have a 32-bits system
Posted on Feb 24, 2010
  • 6,487 Answers
This are the compatible RAM for this mobo :Support for DDR 400, DDR 333, and DDR 266 and you can upgrade up to 4GIG or RAM this is the complete specs for this mobo http://www.gearxs.com/gearxs/product_info.php?products_id=8076
Hope that helps..........
Posted on Sep 10, 2008
  • Mark Gil
    Mark Gil Sep 22, 2008
    Yes sometimes if your MOBO is showing a lower amount of ram instead of displaying $gig that can be resolve by a BIOS update but if its still not resolve by a BIOS update the MOBO has some problem on the memory slot or its a limitation of the MOBO ...
"e210882 driver free download intel e210882 vga driver"
that can not be the boards number look in the pci slot or cpu area for number of board then go to intel support web site type in board numbers then download drivers then install one by one ok
Nov 30, 2013 | Intel Motherboard
I NEED RAM FOR MB 210882
This is the specs for the RAM you require.
Memory
The Dell E210882 system board is compatible with PC2-3200 (400MHz) or PC2-4300 (533MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Compatible capacities include: 128MB, 256MB, 512MB or 1GB. The maximum installable RAM is 4GB.
Google search the Internet for this RAM
Sep 20, 2012 | Intel Motherboard
Hi i have a desktop of HP it have a speed of 3.06MHZ and mother board is 915 can i upgrade the ram up to 4Gb
Mr. Ajay Verma I'm sorry to say but *********** board doesn't support 4GB RAM, It can only support upto 1GB of DDR SDRAM DIMMs(DDR1) RAM.
Jul 18, 2011 | HP Pavilion a305w (DM181AR) PC Desktop
I have a G41T-AD motherboard i installed 4GB of RAM in it on wednesday and since then it keeps blue screening saying to check my hardware is there anything that i can do for this issue
Test the Ram dimms, one at a time. It sounds like you may have a bad module. Carefully reseat each one. And ground yourself to avoid static electricity.
Jul 16, 2011 | EliteGroup ECS G41TM6 Core 2 Quad Intel...
I need RAM for an Intel E210882 D865GBF motherboard (DIMM, single notch more or less in the middle of the board). What do I need?
It appears your board was manufactured sometime around 2003.
It has supported front side bus speed of 800, 533, and 400 MHz, and has a capacity of up to 4GB Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this desktop board
Hope this helps.
Feb 22, 2011 | Intel Motherboard
I want to upgrade my ram for my pc...atmost to how much i can upgrade and in each slot individually how much capacity of ram it supports ...my motherboard is 915glvg
i would like to inform you that *********** board supports upto 4 gb ram and 2 gb in 2 slots will be the best combination but depends on the OS you are using if its 32 bit XP or Vista it wont accept more than 3 gb so if you wish to use your system in full throttle mode upgrade you r OS to 64 bit XP or Vista and enjoy all 4gb standards that you actually wish to but even 3 gb is like playing with wild fire that will be really too fast processing speed and thrilling performance that you expect.
thanks and regards
kindly rate this solution
Oct 28, 2009 | Intel D915GLVG Motherboard
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
Ram
It appears to support either PC2700 or PC3200 DDR memory. (The PC3200 is faster).
May 26, 2009 | Dell (E210882) Motherboard
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
Processor
you can not make it, please see this document.
http://www.intel.com/design/motherbd/so/so_proc.htm
or see this is very instructive.
http://forums.techguy.org/hardware/475688-upgrade-processor-dell-board-e210882-2.html
Thanks
Sergio
Mar 01, 2008 | Dell (E210882) Motherboard
Intel Motherboard Logo
7,876 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
