Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Remote control My remote control stopped communicating with my TV after I cleaned (vacuumed) the dust as suggested by manual. I reopened the everything up again and ensure that all the wire and what have you has not been touched. NOTHING! I reset as stated in the manual. I called Mitsu themselves and went through the whole reset process. Nothing.... Now (just posted a few minutes ago), my TV screen is black, code 34 -- lamp abnormality went on. I have the green light come on, then it turns to solid red. I read about changing out capacitors. I really need help as this TV lasted me only 3 years. : (
  • 18 Answers
Do not replaced anithing .filter cover needs to be turn dow. them press reset boton.......
Posted on Sep 17, 2008
RC-261 fails to turn on/off Insignia TV. Remote stopped working (batteries good)
Check the battery contacts inside its battery compartment for any rust or dust accumulated. Clean them well. If this too do not help you, check the remote control for its infrared emission. In some cases, cleaning the remote control may be necessary. If you wish to get more details about how to check, repair and clean a remote control, visit this site. Pull up older posts. One among the post has details.
Mar 24, 2013 | Insignia RC-261
Cannot get tv to work with converter box remote control
1) RESET THE CODE again for remote contrl
2) Try again .
3) Clean the contacts batteries very well
4) Change the batteries by alkalines
5) Retight the springs contacts with pliers
6) Resolder the wires contacts.
7) Otherwise you must open the remote for clean, from dust, or oxide. or you must go to the repair shop.
God bless you
May 20, 2012 | RCA Televison & Video
Remote hand control won't turn system on. Batteries are OK
1) Change by new batteries type alkaline
2) Clean the contacts batteries with special spray contacts cleaner
3) Retight the springs contacts batteries with plier very well for good contacts.
4) Resolder wires contacts batteries.
5) Reset the code again download for free from www. fitness.manualsonline.com or www. remotecodelist.com
Otherwise you must opent the remote and clean any contact from keypads very well, or go to the repair shop
God bless you
May 14, 2012 | Televison & Video
Suddenly my remote no longer communicated with the tv. I replaced the batteries in the remote. Still no communication. I can operate the tv with it's buttons, but the remote has no effect. Is there any...
The Infer Red eye sensor is on the tv manual control buttons PCB board.The manual control buttons are on the tv right side on the tv frame bazel,tv facing you.Test all the manual buttons like power button,channels + -,Menu button and input button.All the manual buttons work,than the remote control is problems and the causes.The remotes devices are heaviely depend on it CPU chip.The remote CPU is short or dead,if everythings buttons on the remote completely dead or will only partially functions.The remote is garbage,remote CPU is dying.Try website like Remotes.com to buy an original remote or very close to it.
Jan 03, 2011 | RCA L32HD31 32 in. LCD HDTV
Sony TV no longer responds to Harmony remote
try using some rechargeable batteries. they tend to have more miliamps and last longer.
Jan 14, 2009 | Logitech Harmony 670 LCD Remote Control
Won't turn on
Hi, everyone. Me too have the same problem. TV just stays in red but won't turn to blue. I tried unplugging then wait and restart again, sometimes it will work but lately that trick doesn't work anymore. Then somebody suggested to open the back of the tv (it's not hard... just a lot of screws and a couple of bolts to remove) and clean (vacuum) the exhaust fan. Out of frustration, I did open the back and clean the the fan (has a lot of dust on the blades) and everywhere where there is dust. Just be careful not to touch any part of the printed circuit board with the vacuum nozzle to eliminate the destructive effect of static electricity. Or while you're cleaning it you have to hold the metal frame with your other hand to ground yourself (by the way you have to unplug your tv before you start opening the back). After the cleaning then covering the back, the tv worked... for only a few hours. It did stop working again as soon as I turned it off then on again. Again I opened the back, this time I removed the power supply board ( that's the biggest board and located above where you connect all your wirings). Got myselt a small brush and start brushing and vacuuming the dust out. I don't know if the cleaning did the trick or it was the unplugging of the connectors from the power supply board. All these work did the job... my tv is still working for almost three weeks now. Another thing, when you have a a time warner cable with a dvr box where you can program its remote to power most of your equipment in sequence by pressing the remote power button, I set it so that the tv will be powered up last considering that power can fluctuate everytime a unit starts up specially when they are all connected to the same power/surge protector... tv doesn't like it when the power fluctuates while it is still starting. Hope these helps.... (Hitachi 42HDS69)
May 21, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Remote no longer works for volume control
Guys, I might have accidentally found the problem because the fix worked for me :). I have the RX-V995 and for the last 2+years or so, I had resorted to getting up and using the knob manually for volume control. System will show 'voluem up/down' in the display, but the knob didn't rotate. Same problem as yours.
I was getting ready to buy the service manual, find the knob motor which I thought was the main culprict and replace with a new one.
So I took out the top cover (just a few screws), the front face-plate (again just a few screws. The inner details were all visible. The volume knob circuit board was vertically placed. They were all covered in a good layer of dust. I got my Dyson vacuum cleaner and gently and carefully tried to **** up all the dust that had settled down. With soft front brushes, I agitated the dust I couldn't reach with dyson wand direclty, once dust were loose, dyson did a great job even with picking up those last dust pieces.
I couldn't succeed in taking apart the volume knob circuit board, as I was still awaiting for the service manual. I put all the covers back on and guess what? I used my remote and the knob was moving again. Responding very well, the knob made the full turn, when I was on the remote. It has been working perfectly for the last few days now.
I think I know what was happening. Teh top of the RX-V (and I am sure many Yamaha receivers) are very porous to allow for good heat dissipation. Over time, this allows a large amount of dust to collect on top of the parts. Most parts are electronic (not mechanical) and hence don't get affected by the dust. But the few mechanical parts might have adverse affect if dust settles down in between the rotating mechanisms.
My volume knob had stopped responding to remote command, very slowly. Initially it worked a little, missed a little, then it missed a lot and eventually it didn't rotate. That proves the theory to some extent that if the motor had completely failed, it would stop working from the get-go, not intermittently. Dust build-up provided intermittent contact between the parts and hence the response was intermittent.
The dyson vacuum did a great job in pulling out those fine dust from such parts and amazingly, things are looking very good at present. Honestly, I hadn't the slightest hope that vacuuming would fix the problem. I had vacuumed to make it easy for me to work on the parts :).
So, it doesn't hurt at all to just give it a try. Do open the covers so that you can reach closer to the real boards and parts.
Good luck and let us know!!!
cheers
PN from San Jose, CA
Apr 02, 2008 | Yamaha RX-V995 Receiver
Remote not communicating with TV
ok your problem is so simple,just clean the circuit board of your remote control.unscrew the remote control,get the circuit,then use a cotton with alcohol,then scrub,that's it......
Oct 27, 2007 | Emerson EWF2704 TV
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
Sep 27, 2006 | Panasonic CT-34WX54 34" TV
Toshiba TV Remote Control not working
I have been seeing a lot of Toshiba remote "eyes" (the infra-red receiver inside the TV) fail recently. If several known good remotes cannot control the TV then the IR receiver will have to be replaced. If you have no experience soldering and unsoldering PC boards then have a qualified tech handle it for you.
Jun 27, 2006 | Toshiba 32A30 32" TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
76 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
