Question about ASUS A6U Notebook
No display my asus a6vm got no display but its backlight is ok. external monitor is ok when connected. can you help me on this? tnx.
  • patasnatch Sep 26, 2008
    same thing.... for the past two weeks or so, sometimes the display would not work, yet the computer would clearly start up, and i could even hear myself logging in.... now, the display does not work at all
    Scholar:
  • 69 Answers
There's probably a faulty connection between the main board and monitor and there's not much you can do. You can put it in for service under warranty if within the warranty period.
If you have to pay, I would not do it if it costs more than $300. Also is the laptop cost less than $1000 then I would just buy a new laptop, just keep this a spare or a desktop computer.
Posted on Oct 08, 2008
On my asus Eee Pc 1201HAB the display shifted to the left so the left side is partially cut off, how do i fix it?
1) Looking at the User Manual right now, and do not see a Hot Key on the Keyboard, that shifts the display.
[ Hot Key is also known as Special Key. The F1 through F12 keys at the top of the keyboard, and also for your model, colored keys on the keyboard ]
It could be the Screen Resolution is messed up. Not set at the correct settings.
Right-click on an empty area of your desktop screen.
At the bottom of the drop down list, click on Properties.
In the Display Properties window click on the Settings tab.
The screen pixel resolution should be set at 1366 X 768,
http://www.screentekinc.com/Asus_EEE_PC_1201HAB--12.1-inch--1366x768-wxga_hd-laptop-lcd-screen.shtml
In the middle of the Display Properties window, you see the blue subheading - Screen resolution
Right under this small subheading is a Slider.
The Pointed 'arrow' with the green tip, and top, slides back, and forth on the 'line'.
It should state 1366 X 768.
If it does not;
A) Left-click on that green tipped Slider. Hold the left mouse button down. Move your mouse, and move the Slider. (Drag)
Move it to the Left to Decrease the screen resolution, or to the Right to Increase the screen resolution.
Can't set it to 1366 X 768? Post back in a Comment.
ALSO, the Color Quality should be set to -
Highest (32 bit)
If not click on the blue down arrow to the right of this box.
In the list left-click on Highest (32 bit)
Now go below to the right, and click on Apply.
After go below to the Left, and click on OK.
Still no joy?
Believe the problem is hardware related.
Could be something as simple (?) as a bad Video Cable.
(Goes from the motherboard, up under the left Hinge, and then up into the Display Assembly)
Could be the screen Inverter.
However the Eee PC 1201HAB is supposed to use an LCD panel, that has qa series of LED's for backlighting.
Newer backlighting that uses a series of LED's for the Backlight, doesn't require a screen Inverter.
There were some LED backlit LCD screen, that DID use a screen Inverter. Mostly the older models of laptops.
This is what makes me think your LCD screen's Backlight, (And LED), may use a screen Inverter,
http://www.batterystyle.com/asus-eee-pc-1201hab-screen-p-168219.html
Scroll down,
"5. Disconnect the power cable and video cable from the Asus EEE PC 1201HAB Lcd panel. The power cable connects the screen's power source, the lcd inverter, to the backlight lamp attached to a side of the panel."
Probably just a generic form, and didn't take in consideration that the Eee PC 1201HAB netbook, uses a series of LED's, as a Backlight.
May not have a screen Inverter.
To explain;
Primer:
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
(Click on the window with the computer monitor in it )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
[ LED = Light Emitting Diode.
CCFL stands for Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
{Average thickness of a CCFL bulb is 2mm. That is a a little larger than 1/16th of an Inch.
The average length is almost as long, as the LCD screen is in height]
A screen Inverter is used to CONVERT the power from the laptop, for the LCD screen, and Backlight.
Do not see any listings for an Asus Eee PC 1201HAB netbook, for a screen Inverter. Believe the LCD screen uses LED's for a Backlight, and does NOT use a screen Inverter.
Which means if the problem is in the Display Assembly, the LCD screen itself will need to be replaced.
The LED backlighting is built-in.
[Hmmmm, I see a trend going on here that I do not care for, and just woke up to it. Have to replace the entire LCD screen, and cannot just replace the Backlight, or screen Inverter? Sounds like Ka-ching $$$$$ for somebody!
A screen Inverter usually averages from $20 to $40+.
A Backlight ( CCFL) usually ranges from $10 to $15.
An average LCD screen can range from $80 to $300+.]
How to know if the problem is in the Display Assembly?
Use a VGA monitor, and connect it to your laptop.
A) Laptop OFF, monitor OFF. Connect a VGA monitor's cable to the VGA port on the laptop.
(Left side rear. This is an example of a VGA Cable, and VGA connector { Port on a computer },
http://en.wikipedia.org/wiki/VGA_connector )
You can use an older CRT type of VGA monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable attached.
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should automatically show, on the external VGA monitor.
IF not;
There are at least three display options:
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press the Fn key down, and hold it down. At the same time tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
(Give it a few seconds. Sometimes it doesn't happen right away)
Still no?
Hold the Fn key down again, and tap once more on the F8 key.
Is the display off to one side on the external VGA monitor?
Regards,
joecoolvette
Jul 02, 2012 | Acer Computers & Internet
I recently uninstalled ms office 2007 program on my asus EeeBox B202 desktop pc, after rebooting the monitor displays orange color with graphical lines and mouse cursor, the computer actually stopped...
This is unrelated to the Office uninstall. Failing backlight can cause pinkish or orange coloration. I would suggest you take it to a professional to price replacing the backlight.
If you want to confirm that the computer still works and it's just the backlight, do the following:
Boot it and listen. Does it all sound normal?
Boot it in the moonlight and look at it from all angles (can you barely see the image on the screen? If so it's definitely your backlight.)
Connect it to an external monitor (google it).
Feb 22, 2012 | ASUS Eee Box B202 PC Notebook
Computer works,,,, but displays only white screen plss help ; ((
Only way to eliminate some issues is to connect it to an external monitor. If the screen works and you get an image on an external monitor, the graphics chip on the laptop is at least ok and the fault is with either the inverter, backlight or VGA cable (probably the latter).
If you get no image on the external monitor, then you need to look at the graphics chip on the motherboard as possibly failing
Jan 01, 2011 | Acer TravelMate 529ATX Notebook
I cannot get display from my board ASUS-P5GZ-MX. Ram and processor is ok.
Connect t an external display. If you get a display there then your monitor is defective and if you do not get display either you video card or motherboard is defective
Jun 04, 2010 | ASUS P5GZ-MX Motherboard
Asus Eee PC 900A will not start
Dear Friend,
1. First Check with connecting External Monitor, if you get display on external monitor that means Display Screen has gone bad
2. If there is no Display on external monitor then there is problem with Motherboard which needs to checked at Service centre.
Feb 19, 2010 | ASUS Eee PC 900 Notebook
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Nothing appears on the display.
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 07, 2009 | HP Pavilion ze2000 Notebook
THE SCREEN OF MY LAPTOP (ASUS)TURNS PINK.Can anybody help me to solve this.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5630 Notebook
ASUS A6U Notebook Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
