Question about Philips Magnavox 27MS343S 27" TV
Magnavox MWC13D5 13-inch-- overscans
This TV grossly overscans in the H and V. Can I fix it without spending a fortune? Magnavox MWC13D5 13-inch
5 Suggested Answers
  • 476 Answers
SOURCE: magnavox 37MF337B/37 overscan only sometimes problem
This TV has a pixel resolution of 1366x768p
It will accept a 1920x1080i input from a high def source , but running a PC at 1920x1080i/p will cause the problems you describe, depending on what the PC is sending to the TV, because PC signals are not the same as high def.
Your PC should be set to a resolution as near to 1366x768 as possible. My PC allows 1280x768 and 1360x768. Try one of these for best results.
There are no settings on the TV to solve this problem.
Posted on Feb 12, 2008
rulds2008
  • 3866 Answers
SOURCE: Red Lines across the whole screen
This would consitute a covergence board issue and would need to be looked at by a qualified Tv repair technition prefer a Autherized repair technition at that such as myself. You can try if you have the expertise to repair this yourself but you need the tools to do it. Also what most people do not know and what the factory does not tell you there is a service menu you can load on this to run the convergence in Auto to try to correct this. The only bad thing about tell you that there is this menu is I cannot give up the instructions because you could make your situation worse and then come back and pass liability. So in saying that I do think your should seek a professional it might cost you areound $89-$150 to fix but well worth it because its done with qaulity. Thanks
Posted on Sep 23, 2009
Testimonial: "Thank you very much...it seems like everyone is having this same issue with their TV's too...I will have to call someone to fix it then..."
  • 1274 Answers
SOURCE: need code for universal remote rcr312w to program
hold down the program tv button till blink, then click the power button till tv comes on,then push set
Posted on Feb 13, 2010
  • 418 Answers
SOURCE: magnavox smart series 13 inch tv - when connected
There could be a dedicated button on remote that says 'cc'. Your Tivo box could have cc built in.
Posted on Apr 20, 2010
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
Overscan
Yes, if you have the original remote and get into the adjustment menu which is hidden you can adjust width, height, and centering if you want.
Dec 09, 2012 | Mitsubishi VS-50111 50" Rear Projection...
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
Green squiggly line distorting picture on TV
Ur Convergence is dead.Parts and labors,about $300 dollars.
Jan 07, 2010 | Televison & Video
Television vertical overscan
Hello!
Please check the "Troubleshooting" part of the manual to this TV.
https://manualsbrain.com/en/manuals/1874651/?page=24
Aug 31, 2017 | Insignia Televison & Video
Top picture overscan issue, again ...
Overscanned in the top of the screen,is the symptom defected capacitor in the vertical section. Filter capacitor 100uf or microfarad or it is better you replaced all capacitor there and reworks or resolder all solder joint there in vertical section.So it will works better again..
Regards,.
VOTIT
Sep 18, 2008 | Philips Magnavox 20MT133S 20" TV
Magnavox 37MF337B/37 overscan only sometimes problem
Feb 06, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox universal remote for sanyo tv
ok...got this nice sanyo ds19310 from brother without remote..have a magnavox universal remote but don't have code for tv or if i can use magnavox codes or can i set remote to it another way...thanks for any help i can get! megnavox tv code is Press following key combination 0>6>2>5>9>6>MENU to select item press cursor(up)and (down) to change item value press cursor(right)and (left) cancellation of service mode press POWER button on the set regards thanks
Sep 10, 2007 | Sanyo DS19310 19" TV
Overscan is off a bit
Does's the set have a repair history? If it was previously serviced , the capacitor which is connected between the emitter and the collector of the horizontal output transistor transistor might have been changed with the wrong value, which would cause and overscan situation.The service menu for this set is even hard for technicians to use. It' my opinion if the service manual will not correct the horizontal width, the wrong capacitor was probably installed. Scrivitron (also these sets are known for the forementioned capacitor to short , flame or open.
Jul 09, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
203 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
