Question about Whirlpool Dishwashers
Whirlpool Dishwasher detergent door not operating properly. Main wash door opens immediately after starting dishwasher. No pre wash cycle. Loud humming noise coming from bi-metal switch or wax motor attached to the detergent cup assembly. I just replaced detergent cup assembly including the wax motor and I still get a loud vibrating humm from the actuator. model number du1055xtp3
    Novelist:
  • 166 Answers
Pdemaio,
ngafm at your service
I believe the loud humming you describe is an electronic problem. And is not worth changing parts randomly and spending unnecessary funds in this fashion!
my advice is a hands on experience repair person that does this day in and day out!
Whirl pool units have many variables! and for the price of randomly changing two or three parts you could have a certified tech finished the repair at a lesser cost to you!
Unfortunately i can not be there hands on or I would be happy to do a hands on diagnoses for you.
Bless You ngafm.
Please leave me a good rating, before you sign off the site.
Ps. Let me know the end result and which electronic part was the culprit..
Thank you
Posted on Sep 10, 2008
    Genius:
  • 1,028 Answers
If the old dispenser relay was melted or damaged replace control bd the power for the dispenser relay comes from main control and should only be at dispenser when called for in wash cycle ..the control bd is keeping the relay energized too long causing melt down
I have a whirlpool gu2400 dishwasher. The spring loaded soap dispenser door does not open during the wash cycle to release the soap.
Whirlpool dishwashers use a wax motor or a solinoid to release the door at a specific time during the cycle. So for proper cleaning the soap cup is nessesary . The part isn't that expensive and fairly simple repair.
Dec 30, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
Instructions
1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
Feb 24, 2011 | GE Dryers
AEG 250 operating manual
hi friend,
step 1
Remove any large food deposits from the dishes to prevent damaging the dishwasher.
  • Step 2 Load the upper rack of the dishwasher with smaller items, such as glasses, cups and cookware lids. The items must be inserted face down, with the soiled side of each item facing toward the bottom of the dishwasher. Some dishwasher models feature clips, which can be used to secure lightweight items to the tines of the upper rack. The clips work like clothesline pins, and can be moved from one tine to another.
  • Step 3 Load the lower rack of the dishwasher with heavier items, such as plates, bowls and pans. Insert the items between the tines of the rack with the soiled side of each item facing toward the center of the dishwasher.
  • Step 4 Load the silverware basket. The silverware should be inserted into the basket with some items facing up and some facing down to ensure the items do not fit together, which would prevent the dishwasher from being able to clean all surfaces. Knives should be inserted blade down, so they can be inserted and removed from the dishwasher with the handle to avoid injury.
  • Step 5 Add detergent to the dishwasher, and then close the dishwasher's door. Note that the dishwasher has two detergent sections. One dispenser, called the main wash section, has a lid. Open the main wash section's lid by pressing down on the cover latch located next to the section. Fill the main wash section with 3 tbsp. of automatic dishwasher powdered detergent, then close the lid until it snaps into place. The other detergent section is the prewash section. It does not have a lid, because the detergent within the section empties into the dishwasher when the door is closed. Fill the prewash section with 2 tbsp. of automatic dishwasher powdered detergent. Close the dishwasher's door until it clicks into place.
  • Step 6 Prime the dishwasher by turning the kitchen sink's faucet on until it produces hot water. This will ensure the dishwasher has an immediate supply of hot water.
  • Step 7 Start the dishwasher by choosing and pressing the appropriate wash-cycle button, located on the front of the dishwasher's door. Cycle selections include "POTS --N- PANS," "HEAVY" for heavily soiled items, "NORMAL" for standard washing, "CRYSTAL/CHINA" for delicate items, "LOW ENERGY" for lightly soiled items and "RINSE ONLY" for items that will not be washed immediately.
  • hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | AEG Dishwashers
    Detergent door does not open, it completes cycle without using the detergent
    1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
    2. Broken Timer
    3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
    4. Malfunctioning Door Components
    5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
    thank you
    vijay(vote for me)
    Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
    Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
    It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
    How to Purge Smart Dispenser
    The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
    Follow these steps carefully to have a successful purge run.
    For Top Control Models:
    1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
    2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
    3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
    4. Press Start button one time
    5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
    6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
    7. Open door and wipe up excess detergent from the door and tub
    8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
    9. Remove SmartDispenser cap and fill tank with water and then replace cap.
    10. Repeat Steps 1 through 9 one time.
    11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
    Front Mount Controls (same as above except for the changes in the two below steps):
    2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
    3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
    Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
    My detergent cover broke
    yes u can run it just like that or vist sears.com for parts u need Here to Help Shaun
    Nov 18, 2008 | Whirlpool GU1100XTLB / GU1100XTLQ /...
    Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
    Check both arms are spinning freely when you have the machine loaded up normally.
    If thats ok you could try powder instead of tabs if they are not disolving correctly
    Apr 05, 2017 | Dishwashers
    Main Detergent Dispenser does not open during cycle
    check to see if anything like dried up soap in there if so wash out with warm water or try a liquid
    Jan 13, 2008 | Whirlpool 24 in. DU930PWP Built-in...
    Dishwashers Logo
    148 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
