Question about Mitsubishi WS-73713 73" Rear Projection Television
Fixed blinking green LED but, NO signal comes in...
Hello, hope someone can help me fixed this Mitsu WS-73713 projection TV. the problem is after replacing the 4 caps on DM boards w/ 1000uf 35v it fixed the blinking lights of death. but,now no signal comes in on tv. if I turn it off for about 3 - 5min. and, then turn it back ON it will show whats on TV for about 4sec then it will loose the signal.( just blue screen) but if I go to setup menu it will shows all the options settings. ie: cable-A, Input1, Comp1 & so forth. it looks like its working normal but, when I get out of menu setting it doesn't shows anything. then after awhile since no signal it will power off itself. the first mitsu tv I've fixed is flowless. that was 11/2 yr ago. & all I changed was the 4 caps on DM board that everyone advised me to changed. first try works. second time no go. Pls. help guys. Im on my wits on this one.
thanks in advanced
  • Anonymous Dec 16, 2008
    TV will turn on and show direct tv. After a minute or less the tv pops and no signal. Sometimes it will come right back on other times it wont get a signle no matter what. But the Tv always comes on to a blue screen
Hi hook up a dvd see if it's working with it ,if is you have a problem with direct tv
Posted on Feb 13, 2011
The power on no piture
If the power light comes on (green) for a few seconds and goes off:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Nov 06, 2012 | Mitsubishi WS-73713 73" Rear Projection...
Mitsu 65513
I also have the blinking green light problem with my WS-65513 Mitsubishi TV. I would appreciate any information you could send to help fix this problem. Thank you, Keith. elitemachine @netnitco.net
Nov 04, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Model WS 73713, mitsibushi big screen TV. green blinking light on front panel doesn't stop blinking and tv will not turn on by remote or power button on panel
called a TV repairman. I know $65. to start service call but feel it will be fixed correctly in a timely manner.
Sep 08, 2008 | Televison & Video
Mitz ws-55859 tv
Was the symptom a steady blinking green led/ If so you most likely need just the DM repair kit thats 35.00 and comes with the instructions on CD and the replacement capacitors that repairs the DM module. I can post a link for the repair kit if you would like?
Jun 24, 2008 | Mitsubishi WS-55859 55" Rear Projection...
HD1080 65inc.mitsubishi
Hello hope. Try pushing in the input and menu buttons on the set and hold them both in together for 8 seconds to see if the Led will blink a two digit code then let me know what that code says. I can get you a link where to get a new power supply, but that may not be your problem. Try this test an see what the led blinks if anything then let me know I will try to help you determine whats wrong. I am a specialist with mitsubishi projection units.
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Green Light on the front flashing
Needs DM module repair = replace four 1000mf/25v 105 degree
caps..www.chrisandnat.com/projects/blinkingtv/blink.htm
.......................T.
Feb 07, 2008 | Mitsubishi WS-73713 73" Rear Projection...
That damn blinking light
If you can solder and know alittle about electronics, you can DIY
Jan 05, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Have mitsu model # ws-65813 wont turn on
You have a common problem in the DM (Digital Module), more specifically the DM power supply. There are four electrolytic caps in that supply 16v/1000uf that are bad and likely buldged from heat stress. Replacing these caps and the E2P module, a small stand-up board further back on the main DM board should restore normal operation...
You might be lucky enough to have a tech come out and simply replace those caps in-home. It's not a really big job for a qualified tech.
Hope this helps!
Bill
Dec 01, 2007 | Mitsubishi WS-65813 65" Rear Projection...
Cannot turn tv on
i have a fix for this DM board, if you want it please leave your e-mail addy and I will send it to you. This guide has pictures and tells you how to get to the board and what is the problem with it most of the time. good Luck
Feb 28, 2007 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-73713 73" Rear Projection Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
