Replacement fan for a Philips 44pl9523
I have a 42 inch Philips model# 44pl9523 TV. The fan is starting to make plenty of noise and sounds like it will blow up soon. Other than contacing philips can someone please tell me where I can locate a new fan.
Thanks
Ken
  • 4 Answers
Radio shack. check the voltage and make sure you get the right size for you tv.
Thanks
C Dill
Posted on Sep 10, 2008
Why does my magnavox 52 inch dlp make a fairly loud humming noise for 10 minutes or so after turning the tV on? It gradually get quieter.
It is likely a bad fan that gets quiter as it warms up from use. There are two fans on that TV - one under the bulb housing and one at the left vent hole. They are special fans with three leads - +, - and an RPM indicator (yellow lead typically).
Apr 24, 2014 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Where can a find a fan for my 60 inch philips plasm tv..
Ahm, Clearly Philips would be the first place to call and if you are sure a fan is bad they should provide a part number and or cost---I will presume you have (some models have more than one fan) cleaned the fans off with compressed air as dirt gathers on them and causes issues.
I can provide more help if given a model number
Apr 10, 2012 | Philips Televison & Video
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Philips 60pl9200D/37. Two Red lights on power button.
If the power button is displaying the bulb fault indicator AND overheat indicator lights at the same time, it indicates a faulty cooling fan. The television is smart enough to detect when either of the two cooling fans in the chassis have failed, or aren't spinning fast enough. To prevent overheating and damage, the set will not turn on if a fan is faulty. You'll need a replacement fan.
Jun 20, 2010 | Philips 60PL9200D Projection Televisions
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
My Philips 60 inch rear projection TV model
Mute the volume and listen at the rear of the unit. You should be able to hear a fan running since these have hot-spots that require some kind of air movment to keep them from overheating. There are protective circuits that will shut down the power supply once a critical temperature is reached.
The second possibility is the power supply itself; these sophisticated units are very energy efficient but have components in them that age and lose their function over time. The main supply should be fairly easy to spot; it will have larger components on it, some cylindrical (capacitors), others block-like.
If the fan is running and it is still shutting down, this supply may need repair or replacement. Look for a part number on the board and inquire at the manufacturer's service center about those possibilities. Have your model & serial numbers of the set available too.
Sep 01, 2009 | Philips 60P8341 60" Rear Projection...
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Black screen
You have a cracked panel and the gasses inside have escaped. The buzzing noize you are hearing the the current flowing throught the panel. It will be cheaper buying a new TV than buying a replacement panel. But if u wanna check out the price look up your model on parts.com
Apr 04, 2008 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
