Question about Vivitar ViviCam 3785 Digital Camera
Broken latch on battery cover
The little clip on the edge of the battery cover broke off need replacement
  • idntkara Nov 11, 2008
    The latch where the batteries/memory card are will not stay closed! How can I fix it?
Use tape!
Posted on Dec 14, 2008
Back door won,t open on my 02 avalanche
door handle broke depends on what door handle it is.if door cant be open on out side out side door handle broke.if cant open door on inside inside door handle broke.door handle clip that connects to latch rod broken.when you try open door handle not engage to latch rod.door not going open.have to replace door handle with new clip holds latch rod in place.
Jan 09, 2013 | 2002 Chevrolet Avalanche
Trying to replace the little round lithium backup battery but it is held with clips. How do I remove the battery
Press the clip with a sharp point on the inside edge towards the outside edge and the battery will pop up. You may need to lever the battery up at the same time.
Feb 11, 2012 | Toshiba Satellite A105 Notebook
Replace system battery,with power on?
The Partner ACS system uses 2 AAA batteries to retain programming from 45 to180 days, in the event of a power outage. When these batteries fail, a system warning (replace sys bat w/ power on) will display on the screen of extensions 10 and 11.With new batteries in hand, go to the phone system cabinet and find the system processor. The system processor will be marked on the top third of the card with a label marked "Partner ACS processor".
On the bottom of the processor module,below the extension jacks, there is a battery compartment. With the power on, Push in slightly on the battery compartment and slide the black locking latch up to cover the"+" icon. Remove the battery assembly by pulling the tab at the bottom of the compartment cover.Place the batteries into the metal battery clips fully. Make sure the polarity of the batteries is correct by looking inside the metal battery clips for the "+" and "-" icons cut into the metal of the battery clip. With the locking latch in the unlocked (up) position slide the battery assembly back into the processor card far enough that the edges of the assembly slip behind the plastic housing of the processor card.Slide the locking latch down to secure the battery compartment. The message on your screen will disappear if the batteries are inserted correctly.
Dec 21, 2010 | Lucent PARTNER18 Corded Phone
How do I remove the battery in a Dustbuster chv1400 for replacement? I have removed the two screws and removed the cover, but I'm unable to figure out the retaining clips for the battery. Of course I don't...
That model looks similar to my DB200. Instead of the screws, the underside has a latch/panel that you remove. Place a screwdriver in the two slot-like holes that face each other (one at a time) and the 'door' should pop out. Mine was a little stiff and I broke one of the retainers inside. Shouldn't be a problem. Sourcing a replacement battery 'pack' is what I'm doing now.
Dec 12, 2010 | Black & Decker Vacuums
Broken battery cover latch
The battery cover latch is broke how can we repair it
without having to use duck tape?
Apr 23, 2010 | Fuji FinePix S7000 Digital Camera
1994 Lexus LS400 Broken Hood Cable - Hoe could I replace?
you have to route cable along the fender side under the hood like on battery side. you have to run it where it wont get in contact with drive belt.your cable has a ball of metal at the end of it.your hood latch should have a clip where you put your cable in it.you should not have to remove nothing.just drop cable in place.
May 16, 2009 | 1994 Lexus LS 400
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
HP Pavilion dv2120us Notebook PC battery release latch
My battery latch got stuck in the open position after replacing the battery on HP's DV 6300 series. The battery was thus stuck. I used the 'screwdriver' technique but with a rounded end kitchen knife not an actual screwdriver to remove the battery. It is important to push the knife down a little into the groove at the outer long edge of the battery and pry that outer edge up. AFTER DOING THIS THEN GOING TO REPLACE THE BATTERY I REALIZED THE LATCH PROBLEM OCCURRED BECAUSE I HAD PUSHED THE BATTERY LATCH TO THE OPEN POSITION TO REPLACE THE BATTERY. THIS IS WHAT JAMS IT. TO REPLACE THE BATTERY 'DON'T TOUCH THE LATCH AT ALL'. LEAVE THE LATCH IN THE CLOSED POSITION AND REPLACING THE BATTERY WILL SET THE LATCH IN THE CORRECT CLOSED POSITION, READY TO BE SLID TO OPEN POSITION ONLY TO DO THE ACTUAL BATTERY REMOVAL.
Dec 13, 2007 | HP Pavilion dv2120us Notebook
Battery cover for cds6300
the molded plastic clips ,when cover is closed and pushed in to lock are broken from camera body both pieces. How and where can it be repair.
Oct 21, 2007 | RCA CDS6300 Digital Camera
Vivitar ViviCam 3785 Digital Camera Logo
64 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
