Question about Motorola Mobility H500 Wireless Headset
My wirless connection is not working. I checked with my cable company and it is not the internet connection. It is the wireless from Motorola. I am doing this from my work computer................... a phone number would be more helpful
  • divaspirit Sep 10, 2008
    this is not helpful!@!@!!!!!!!!! I am having problems with my wireless rotour.
Reset the router and do installation again. unplug every cord except for the power cord then hit the reset button for 10 sec. then wait 10 sec. more to unplug the router and star your installation again.
Posted on Sep 22, 2008
Cant connect my xbox to internet. i have a motorola sb5100 motem and i lose it at internet connection
Try getting a wireless adapter or a wirless router and buy a ethernet cable plug into the back of your x box 360 console tou get it working add me if u do on (XXXLONG HORN666)
Jan 22, 2010 | Microsoft Video Game Consoles & Games
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless not working
You've got to set up security for both the router, and the laptop or other wireless device your trying to connect to the router.
Jan 24, 2009 | Dell (743NE) Remote Access Server
My sister has a Motorola SP4200 router with a Netgear WPN824v2 wireless router/accesspoint/switch connected to it. Previously she had the SP4200 connected to port 1 (not WAN) port on the Netgear as it is...
it might be asking for a WEP password in order for you to use it which is on the botom of the router or the game sistem is the one causing the trouble and should not be conected to any wirless or eathernet internet routers.
Jan 03, 2009 | Computers & Internet
Losing connection
I assume this is a cable modem? You need to call your cable company and have a trouble ticket created. I worked for the cable company installing cable for quite a while and I bet my paycheck the signal getting to the modem are below specs and that's why the modem gets dropping the internet connection.
Hope this helps.
Aug 13, 2008 | Arris SURFboard SB4100 Modem
Tiscali wirless connection issue
Sounds like the router may need a firmware update as the DHCP service is failing to run correctly.
You can however just use a static ip address.
First of all find out the network address in use.
eg. 192.168.0.1 - 192.168.1.1 - 192.168.2.1
to find out, - start menu - run - cmd - ok - ipconfig
1. Log on to the client computer as Administrator or as Owner. 2. Click Start, and then click Control Panel. 3. Click Network and Internet Connections. 4. Click Network Connections. 5. Right-click Wireless Network Connection, and then click Properties. 6. Click the General tab, click Internet Protocol (TCP/IP) in the This connection uses the following items list, and then click Properties. 7. In the Internet Protocol (TCP/IP) Properties dialog box, click Obtain an IP address automatically (if it is not already selected), and then click OK.
Note You can also assign a unique static IP address in the range of 192.168.0.2 to 192.168.0.254. For example, you can assign the following static IP address, subnet mask, and default gateway:
IP Address 192.168.0.2
Subnet mask 255.255.255.0
Default gateway 192.168.0.1
Jun 20, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless connection lost
Wirless and modem systems both are different, there is no connection between them.
If you were using your modem for internet access then you should chek-out your modem and phone-lines etc. Wirless will not effect.
verify your modem driver is installed correctly and check the settings.
Thanks
Iqbal
Apr 06, 2008 | HP Compaq Presario V2000 Notebook
SSID and WEB KEY number
i WANT TO CONNECT MY PS3 USING MY WIRLESS ROUTER BUT DON'T KNOW HOW TO CONNECT IT CAN YOU HELP
Jan 04, 2008 | Linksys Wireless-G Broadband Router
Motorola Mobility H500 Wireless Headset Logo
42 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
