Question about Dishwashers
DISHWASHER LEAKING A LARGE AMT OF WATER AND ALSO THRU CEILING OF LAUNDRY ROOM
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi DERRICKDM,
I'm Harvey the Master Plumber.
You're poblem is: DISHWASHER LEAKING A LARGE AMT OF WATER AND ALSO THRU CEILING OF LAUNDRY ROOM
The only way to find and repair this leak is to remove the d/w so you can inspect the parts under and in the rear. I don't recomend this to the average homeowner. If the d/w has a few years on it you may look at the cost effectivenes of repair verses replacement. If you choose you might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
Excess humidity in laundry room. water running down walls. why?
Check that the vent hose is hook up properly
Sep 14, 2014 | Samsung Dryers
Water leaking from dishwasher into my basement. Help!!!
I see the water leaking out the bottom plastic cover through the two little holes. I do not see water leaking around the top seal. I assume it is coming from a seal on the bottom.
Is there a manual that shows how to take the dishwasher apart to get to the seals? I have the parts sheet which shows the exploded views where the parts are shown. Much appreciated!
Mar 14, 2012 | KitchenAid KUDH03DTSS Dishwasher
There is water in the living room floor after the unit runs even for a short time. Where do you locate the stopped up drain. Where would I begin my search?
If your furnace is in the closet or laundry room, the coil that's leaking is either(1) on the top of the furnace if your ductwork is in the ceiling,(2) on the bottom of the furnace if your ductwork is in the floor. The drain that may be stopped up stubs out of the bottom left or right hand corner of the coil box. Sometimes you can flush it out with water but the best way is to find the end of the drain and get a shop vac and stick the shop vac hose on the drain, seal it real good and try pulling the junk out of your drain. Your drain may drain outside somewhere on maybe to a floor drain.
Apr 12, 2011 | Heating & Cooling
Leaking faucet
Most likely bad solder joint or leak where shower arm is screwed into fitting.
Sep 26, 2009 | Home
30 yr old Viking dishwasher leaks...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
tyue56
Aug 06, 2009 | Viking DFUD04 Built-in Dishwasher
Water trickles into Kenmore front load while machine is off and door is open
sounds like a bad water inlet valve stuck open and permitting watertto enter even though not on, untill you replace the valve turn off water between uses part number 8181694
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Heating element broken, water leaking
You have to pull out dishwasher to replace the element.The element is easy to replace once you have pulled dishwasher out.This enables you to reach the area that you need to reach.It is common for a element to brake.On a newer dishwasher ,I would say it must have been defective if it just broke in half.Nothing electrical in a dishwasher can cause it to brake.
May 20, 2008 | Kenmore 24 in. 15953 Built-in Dishwasher
Plumbing connection to dishwasher leaking
Remove bottom panel and run dishwasher while monitoring it. A large leak may be from a hose off at pump underneath. Mice can chew holes in hoses too.
Nov 15, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Dishwashers Logo
83 people viewed this question
Top Dishwashers Experts
