Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Red light wont go off
I've done it all... cleaned it, unplugged it, flipped it upside down, HELD it upside down, and I realized that the light stays green if you hold down the button. I decided to hold my hand near it in an effort to feel air coming from it. Instead I got smoke and the smell of burning plastic. This thing was plugged in for 7 hours!! and it's dead. Sharper Image is out of business and I now have a 2 foot tall paper weight. Any help would be good help, but judging from the previous posts no one knows why this happens. I just wish it would have worked for more than 7 hours.
  • 2 more comments
  • Anonymous Oct 05, 2008
    Cleaned unit several times but the red light will not go off.
  • Anonymous Oct 30, 2008
    same thing 1 year old
  • ben hilbun Dec 06, 2008
    red light will not go out....does it work...can you help me...does it work...will it work...ben
  • Anonymous Dec 27, 2008
    same
I went to the following web site and did exactly what it said to do and the red light is now off and working fine. Used 1500 grit sand paper glass balls go up and down wires with no problem now,before they didnt move.
http://desiredcreations.com/Misc_IonicBreeze.htm
Posted on Dec 14, 2008
  • 2,794 Answers
Sharper Image recalled the units because they couldn't prove in court how they clean the air based on a report relesed by Consumer Reports. They lost and had to pay all the legal bills.
Ionizers have been proven by the EPA to not only be ineffective for cleaning the air but can be harmful to use as well.
Consumer Products Safety Comission is going to issue a report by the end of the year on them and their decision could put an end to ionziers sales in the U.S. altogether.
Posted on Sep 22, 2008
Thera Pure. Why won't it turn on?
My THERAPURE wouldn't turn on either. I got it when my mom upgraded but could never get it to power on. I came here for help. I figured it out myself. The filter was put in upside down after it was cleaned. Odd that it even fit. I flipped it, plugged it in, and it turned right on! Good luck. Hope your fixes are all as easy as mine!
Jul 23, 2015 | Air Purifiers
Why does a red light on top of the ionic breeze GP S1750 blinks and does not blow the air
well i had the same problem at one time ..heres what to do... try turning it upside down and bang on the unit gently .not to break it and make sure you did not break the two strings behind the vents..
take out the bulb and clean the whole inside as best as you can..
and if that wont work unplug turn button to on pisitioin and then plug the unit inand hope for the best ... if all else fails go to amazon and replace the unit..hope that helps
Jun 11, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
We bought this model, I removed and cleaned the metal colums, and now a red light stating the unit needs cleaned stays on and the unit does not work. I swapped the metal part with another unit that was...
There is dirt on the inside of the unit. Remove the metal plates and turn unit upside down and gently shake to release the dirt built up in the bottom, also check metal contact near the base of the unit. If it isn't clean the machine cannot make the magnetic connection necessary for operation. Use a q-tip and 91% Isopropal Alcohol NOT rubbing alcohol. This should get your Ionic Breeze going.
Mar 28, 2010 | Sharper Image Professional Plus Ionic...
"Cleaning overdue" red blinking light after cleaning was done
Check that there are no fine pieces of lint that are bridging the plates or the ionizing wires, to ground.
Check the contact points of the collector cell and inside the unit.
The light is caused by a shorted collector cell and associated components.
Dec 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Ionic breeze is making clicking sound
maybe try flipping it upside down and right side up 2 or 3 times. mine has a little ball on a metal wire that has to run across it several times to finish the cleaning. hope it helps.
Jan 08, 2009 | Air Purifiers
Red Cleaning Light won't turn off
After cleaning the unit, replace the grid into the unit. Hold upside down for at least 30 seconds to reset.
Jul 19, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper image quadra silent air purifier has red light flashing
Have you cleaned the bars lately? I believe that red light means that the bars that collect the junk from the air are at capacity and needed to be wiped down.
If you don't know how to do this, pull them out from the top after having turned the machine off. Get a rag or paper town moist, but not dripping and just wipe the black soot off all visible sides of the metal bars. Lay it aside when done over night for it to dry completely, then re-insert them into the machine. Turn on and hopefully that should take care of it!
Jun 18, 2008 | Sharper Image Professional Plus Ionic...
Take it back. Hopefully it is inder warranty. I have had 2 units do the same.
Nov 29, 2007 | Sharper Image Ionic Breeze 3.0 Air...
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
215 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
