Question about Frigidaire Kitchen Ranges
Hi, I have a Frigidaire ES300 Black electric smooth top range (model # FEF366EB). The overlay for the digital display and digital buttons sort of got warped and messed up and I want to replace it. I just ordered the replacement part. Do you happen to know if it is easy to install the replacement overlay, is it as simple as removing the old and dropping the new one in it's place once I get the outer hardware removed? I was concerned that I may have to hook the overlay up to a circuit board or some other wires. Can you advise me on this?
  • 116 Answers
The overlay covers the circuit board but - no - no electricl connections to contend with
Regads
Posted on Sep 10, 2008
While preheating my electric frigidaire smooth top oven, we heard a loud pop and saw a flash. The breaker had tripped. After resetting it, the clock and digital features still work, and so does the st
I appreciate your inquiry, Stephanie Givan!
From what you are describing it sounds like a possible short with your breaker box or issue with your terminal block within your Frigidaire range. I would recommend reaching out to a professional technician for a proper diagnosis to be completed. The technician will have the correct tools to check for any electrical issues within the range to make sure the correct component is being replaced. This will help avoid any unnecessary part purchases. -Matt
Nov 12, 2014 | Frigidaire Ovens
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
No response from the oven control panel.....no lights, clock, nothing Stove top controls work fine.
The Electronic Range Control (ERC), also known as an Electronic Oven Control (EOC), controls all the features of the oven. This is your clock/timer assembly. The surface burners work independently of the oven and usually have electrode type igniters that get their power from a spark module. Since you mentioned your clock display is blank, more than likely you have a defective ERC board. The following link explains how to replace one:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
A replacement control board can be purchased from any of the following webistes:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: In most cases the overlay (preprinted plastic display covering with all the numbering and lettering on it) does NOT come with the control board. If your overlay is still in good condition, it can be easily removed from the old control board and reapplied to the new one. Just make sure you properly orient the overlay so the buttons all match up. If you need to replace your overlay, you may need to order it separately. Read the part descriptions carefully to see what your replacement parts include.
The part number for a replacement ERC is 316455400, the overlay (if required) is 316220701 for BLACK. The parts are listed as items 20 and 20A, respectively, under the "Backguard" parts listing.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Aug 23, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Display not working nor oven frigidaire gallery smooth top
Could be a thermal cutout or control board problem. If you can email me the exact model number at info@fixyourboard.com I may be able to help you troubleshoot the cause.
Regards,
Bruce
www.fixyourboard.com
Oct 05, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Need clock overlay touch pad can't find compatible part
Hi, I can get you the overlay. It is about 30.00. It is black in color.
Vic
May 20, 2009 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire electric range digital display light stuck on
Try turning the power off to the appliance for several minutes or un plugging it.
Mar 30, 2009 | Frigidaire Kitchen Ranges
Is their a reset button on a frigidaire elctric range model ES300
clock, timer, temp gauges for oven shorted out, is there a reset button?
Jan 09, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Electric oven range not working
common replace eoc clock get eoc and overlay the black or white cover for the clock is the overlay if you peel the old one off carefully you can restick it on the new eoc pull the range out and remove the 1/4 inch screws from around the top panel after un plugging the range remove the top panal face the front of the range right under the clock remove the two 1/4 in screws go to the back of the range and pull the eoc bracket backwards from the bottom and out take the four screws out that hold the eoc to the bracket turn the eoc sideways and out of the bracket and let it hang screwthe new eoc to the bracket with the two srew holes at the bottom put the overlay on the new eoc and put the top of the bracket in first then push the bottom in making sure the holes in the bottom line up with the holes on the cotrol panael go to the front and replace the two screws then go to the back and with a small screwdriver gently pry the wires off the old eoc and place them on the new one if you get lost theres letters on the wires that match the ones on the eoc replace the back panel plug it in reset the eoc clock all done make shure you get the complete mod# when you order the eoc its on a plate on the left side of the range body when you open the bottom drawer all done
Dec 22, 2007 | Frigidaire FEF336BC Electric Kitchen Range
My Frigidaire range display has gone out and the oven doesn't work.
sun, first test is to power the unit down. Find the pair of breakers which are generally 40 or more amperes. Turn them both off and back on. If this doesn't fix it, you will probably need a circuit board.
Nov 10, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
240 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
