Question about Samsung SP-R4232 42 in. Plasma HDTV
Samsung sp-r4323 This tv has a black line on the left side of it about 3inches from the bottom to the top. You could still see the picture and everything is fine just a black like on the side of the tv.
  • 579 Answers
SOURCE: large black line top to bottom
The plasma display screen is made of a matrix of elements connected to cables along the side and top. On your unit, some of these many, tiny connections are making contact intermittantly thus losing the elements in that area. These contacts are held in place with just pressure and if that is disturbed, you lose that line of elements. Try squeezing the cabinet of the TV on the outside at the top in the area of the loss and see if that makes a difference. May have to go inside and see if the contact assembly is disturbed or warped or something.
Posted on Dec 31, 2007
  • 103 Answers
SOURCE: samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
jerryg50
  • 1689 Answers
SOURCE: Black Line on Samsung TV Model # HPR-4252
This is a screen address failure from part of the matrix addressing. This can be caused by fair number of types of faults to cause a missing part of the addressing. You will not be able to fix this yourself.
Find out who the authorised local Samsung service is for your area. They will be able to give you an estimate.
Jerry G.
Posted on Jun 03, 2008
SOURCE: Samsung HP-R4252 42 in. HDTV screen black outs and red lines
Hi: We had this problem under warranty, and tech installed the following to solve it: Parts BN96-02033A, BN96-02034A and BN96-02216A. This solved the problem for 2 years. I now have the upper half going black now and then for 2 to 3 seconds. I am ordering these parts from www.partstore.com and will just plug them in. Better than a new tv.
Posted on Aug 16, 2008
SOURCE: red in left sie of screen show up sometimes on 42 samsung SP P4251
Solution 1: I am watching on cable through a bright house hd box. Im using cables w/red,white and yellow connectors (if thas what you're asking)
Posted on Nov 06, 2008
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Hpr4262 samsung plasma picture problem
You need to call a technician.The problem lies in the board [internal].
Jun 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
3inches black line
Even though we are at a level of technology where most things can be addressed by a button on a remote or through a menu there still comes the time when we need to think back when we used to adjust TVs manually. It sounds like this is an analog TV and it is possible there are pots or potentiometers on the rear of the TV at the bottom. If you have children, they love to turn things and it may just be if they are there they need to be set to default. Typically a bad tube will give different symptoms, however, depending on the age of the TV there are some that have circuit boards that will effect the display on a good tube. Not to many symptoms given on this one other than what you describe as "the problem"
Jun 04, 2009 | Sansui DTV2760 27" TV
Black vertical line 3inches in from the left on my fujitsu PDS4233W-H plasma screen
If the line is all the way from top to bottom, it could be your upper and lower buffer boards or your plasma display unit is bad. I suggest you contact a servicer for your brand.
Apr 01, 2008 | Televison & Video
Can it be fix?.
Could be a buffer board, it all depends on the exact location of the lines
Oct 25, 2006 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung SP-R4232 42 in. Plasma HDTV Logo
35 people viewed this question
Henry  Thomas
Henry Thomas
