Question about NEC GT5000 Multimedia Projector
Nec gt5000 projector turns off 10 seconds after power up
Recently purchased and shipped NEC Gt5000 projector lights up with green light, then powers off after 10 seconds.
  • wosfu Sep 13, 2008
    The projector is not new but is used and not under warranty.
  • wosfu Sep 14, 2008
    When I remove the bulbs, the normal blinking yellow then blinking red lights come on. But with bulbs in, it does not do that but just shuts down. Wouldn't the regular bad bulb warning lights come on if that was the main problem? Does anyone know if there is a way to test the bulbs outside the machine? Thanks
    Brigadier General:
  • 5,158 Answers
If the bulb is not lighting up and you want to test it. use a multimeter to test continuity on the two seperate connection points on the bulb... no continuity... the bulb is burnt out and you need a new one...
Robert
Posted on Sep 14, 2008
    Sergeant:
  • 241 Answers
Does it shut off even when there is no devices plugged into it.
If this is the case the High Voltage Output needs to be repaired/replaced
Thank you
Jayson
Posted on Sep 13, 2008
  • 3 more comments
  • Jayson Brollini
    Jayson Brollini Sep 13, 2008
    The lamp could be the case but it is shutting before it even heats up.
    How old is this and is there a Refurbished label on it>
  • Jayson Brollini
    Do you have a pc card in the slot if so please remove that and try to power it back up
  • Jayson Brollini
    ok please make sure that when it is powered up and the light is green
    does it flash before it shuts off or does it stay constant then fades out
  • Jayson Brollini
    if you have no blinking lights Green Red or Orange
    additional notes would be that the Power button is sticking or the remote power button is
    sticking
    The Sleep Mode Function (timer Is activated) as been enabled and that may be a possibility
    You can also check the housing for the lamp (rear) and make sure that it is connected properly
    Anything else the Lights are the key to narrowing down the source of the problem
    so make note of any changes that may occur in the light colors Steady or Blinking
    of the 3 can mean several things but with a steady green light that can mean that it may be internal
    Thank you
    Jayson
  • Jayson Brollini
    Please feel free to post any additional comments
    so we can assist you with your question
    Thank You Jayson
    Master:
  • 726 Answers
That is usally cause of the lamp this is not in my expertise but that happened to my dads one if the lamp is at the end it will shut down it usually give warnings first like change lamp then its over has to be replaced
    Genius:
  • 2,035 Answers
Please click on this link and get the user manual and then check the trouble shooting page ,if this did not resolve the issues then you need to contact the company :
http://www.projectorcentral.com/pdf/projector_manual_2056.pdf
To contact the company:
Service and Support Customer Service
1.800.836.0655
Tech Support
1.800.366.5213
Good luck...
  • Anand Kumar
    Anand Kumar Sep 13, 2008
    Then you need to get it serviced as this hard ware problem,please get it serviced at local projector service center....
    President:
  • 1,952 Answers
Up to a maximum of 10 seconds. The OFF key exits and ...... Use the right arrow key to make use the green light is on the 1 position; ...
down load this link ur problemis use ful
http://www.jedmicro.com.au/T460_274.pdf
  • 1,183 Answers
As its a new product , kindly contact Nec support team on the following website
http://www.nec-display.com/global/contact.html
If there is more information available on your problem , i would get back to you .
Thanks
proton
  • 1 more comment
  • Mandeep  Singh
    Mandeep Singh Sep 13, 2008
    Kindly refer to the user manual , chapter three , Turning on the projector. check if the projector is going into the stand by mode , after being powered on.
    Thanks
    Proton
  • Mandeep  Singh
    Troubleshooting given as per user manual
    Does not turn on
    Will turn off
    • Check that the power cable is plugged in and that the main power switch on the projector is on. See pages 1-
    9 and 2-11.
    • Ensure that the lens hood or the lamp cover is installed correctly. See pages 1-4 and 9-2.
    • Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is
    insufficient ventilation around the projector or if the room where you’re presenting is particularly warm, move
    the projector to a cooler location.
    • The lamp may fail to light. Wait a full minute and then turn on the power again.
    • The lamp has reached the end of its usable life. Replace the lamp.
    • Ensure that the Power Management is off. See page 8-16.
    Thanks
    proton
  • Mandeep  Singh
    http://www.projectorcentral.com/pdf/proj...
    Above is the link for the user manual
  • 2,336 Answers
If this device is new and is acting up on you already, I would suggest to get it fix under warranty. If you attempt to fix it yourself it might void the warranty.
    Genius:
  • 1,665 Answers
It;s power supply circuit seem to be faulty.
NEC LT25 Found a lot of people have the same
mainboard is not work well ,it need to be repaired
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 03, 2013 | NEC LT25 Bulb/Lamp
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
I have a nec vt560 and the power light stays orange and the status light is off until buttons are pressed. bottom line is...i cant get the projector to come on...the power light never turns green.
The projector is in standby mode, which is a good sign.
When you press the ON button for "at least 2 seconds or more", what happens.
Do any lights come on at all?
Mar 20, 2011 | NEC VT560 Multimedia Projector
Power light is steady orange and lamp light is red but there is a new bulb in it. NEC VT676
If the unit will not power up it sounds like you may have tripped the lamp timer. You will need the remote plug the unit in and hold down the menu button on the remote for 10 seconds. The red light should go off and the unit should fire up.
Thanks Projector Guy
Apr 21, 2010 | NEC VT676 Multimedia Projector
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
NEC VT 470 projector won't work at all
Try pressing the HELP button. Don't release and press the power button. The LED lights should blink. Release then try to power on again.
Jan 11, 2008 | NEC Replacment Lamp Projector Lamp for...
NEC MT820 Projector
Press and hold the power button on the remote control for 10 seconds.
Sep 07, 2007 | NEC (MTLAMP820/1020) Projector Lamp for...
NEC GT5000 Multimedia Projector Logo
1,084 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
