This is the auger, the unit that dispenses the ice. Check to make sure that the power to the unit, usually plugs into a port in the freezer, isn't dislodged or loose, If that doesn't fix the problem, you can call local part sellers, you can find one on www.whitepages.com, and see how much for a new or reconditioned one.
Hope this helps
Joe
The ice
maker not working: ---
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
