Question about Reebok Watches
Reebok watch model 0434
I found this watch three years ago in the snow. I tried to find the owner for three months in the neighborhood. I had no luck, now i would like to try and use it but it needs a new battery and I would like to find a manual so I can set it. Can you help me? On the back there is only what i believe to be a model # of 0434 or CE 0434 and a serial #. Hope to hear from you.
Kevin Jopp
P.S. It has a Heart rate monitor. My e-mail is huckleberry62280@yahoo.com
SOURCE: Sportcraft Heart Rate Monitor Watch
On mine you press and hold the ST/FWD button.
Posted on Feb 17, 2009
  • 2976 Answers
SOURCE: Timex heart rate monitor does not keep correct BPM. I changed the battery, now the heart rate hovers in the 30' and 40's, never getting to the correct BPM
Make sure the back of the watch is spotless and your skin isn't too dry.
Posted on Apr 23, 2009
SOURCE: inaccurate/intermittent heart rate info?
Here are the things I have noticed that help:
- enough moisture between the HR monitor and your chest. Apply water right before your workout to make sure it isn't all dry between the time you put on your monitor and when you actually started your workout.
- Make sure the strap is tight enough. Mine gets loose over time and the bouncing of running will give me inaccurate readings until I tighten it up again. You can test if this is the problem by using your hands to press the monitor more tightly against your chest - if that seems to fix the problem that a loose strap could be it.
- Use a "conductive gel" instead of water between the monitor and your chest. Conductive gels are pretty cheap.
Posted on Jul 03, 2009
escapement
  • 2334 Answers
SOURCE: Manual of Timex Zone Heart Rate Monitor watch . Model T5H881F5
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Posted on Apr 14, 2010
  • 3 Answers
SOURCE: I've accidently turned off the
Press and hold the reset button, for 5 seconds, while in Time mode. the heart monitor will reset and the symbol reappear on the screen
Posted on Apr 27, 2011
About three months ago, it was covered by water for about three hours and now will not power on. Tried reset button but no results.
you have to take the top of the watch and blow the water out. And then after you need to look on the bake of the watch and see if it says water proof or water resistence. can't spill just a little tired
Jul 17, 2015 | Watches
My Reebok watch's dial glass has broken. You ...
you are requested to please give me any contact number and address of any Reebok Watch store/showroom in Latur so I can get it changed.
May 20, 2010 | Reebok 1243760 Wrist Watch
I bought this watch citizen BL5334-04E year ago,
Mechanically operated date changes occur at 12 O'clock. If your watch thinks it is midnight when it is noon then it will change date.
The solution is to wind your watch on 12 hours.
Apr 17, 2010 | Citizen Eco Drive Perpetual Calendar...
Its broken and I need a replacement strap. I order one from Invicta three months ago and still haven't received it.
Have you tried your local watch shop?
Unless the strap has an unusual fitting, a standard type should do the job.
Mar 23, 2010 | Invicta Grand Lupah 2236 Wrist Watch
Reebok Strapless Quick Touch Heart Rate Monitor Watch (Reg. Size)
Have tried going to a watch shop ? It may sound a bit obvious, but looking at your watch and comparing it with mine, I think that a standard strap might fit.
You have nothing to loose by asking and it tends to be expensive to send them back to the makers.
Feb 16, 2010 | Watches
I have had my MTG900 for about two years. About a month ago I noticed that the blue light would come on by itself. This happened every two or three minutes or so. Now my watch is dead except for the word...
All you need is to find the nearest watch repair shop. Ask them to replace capacitor (in case if your watch is light powered). If it's run on battery - replace by new one. It is very hard to guess what's the MTG900 is. Next time you are here, plz give:Make, model, ALL the writings on case back and every detail you know.
Feb 05, 2010 | Casio Atomic-Solar MTG900 Watch
Seiko Self winding 200M Divers Watch Stopped Working
your watch needs a good service.disassembling cleaning oiling and reassembling!this must done every three to four years in automatic watches!try in a authorized seiko service center!
Jun 28, 2009 | Seiko Divers Automatic watch
Pulsar v182 (804892)
I have the same watch and the same problem. The solar battery is depleted. You need to recharge the watch like you did when it was new. The instructions can be found through the following link: www.pulsarwatches.com.au/manuals_pdf/108_1.pdf
Oct 28, 2007 | Watches
Watches Logo
576 people viewed this question
Top Reebok Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Reebok Watch Expert? Answer questions, earn points and help others
