Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
Haier sdw4a hi the problem i have is when i turn on dishwasher after 10 seconds it just beeps and does nothing all lights flash,i have no manual to consult and can not source one for this model, can you help.
  • csimmerl Dec 14, 2008
    same problem- it acts the same as when the door is not latched. that's they key, and as someone here suggested it, bending the latch to close the contact switch fixed it. careful- current runs through that switch! it's still flimsy and needs a better long term solution.
Water not emptying completly
Posted on Jan 12, 2008
    Champion:
  • 277 Answers
Hi cant help more then this: try the manual in the end of the page see if it helps http://www.haier.com/servicesupport/manualMore.asp if not contact the firm http://contact.haier.com/engdefault.asp if they dont help call a tech guy he'll know whats worng good luck
Posted on Mar 29, 2006
I have a countertop model of this dishwasher and it has a sliding latch at the top of the door.  It wouldn't do anything fresh out of the box except beep.  I had to take a lot of screws out that held the outside shell on because there is a little flimsy piece of metal that makes contact with the metal latch at the top of the door.  Both the piece of metal and the latch had to be slightly bent so that closing the latch causes the flimsy metal to make a clicking noise.  Then I turned it on and it worked, and of course then put all the screws back in.
Posted on Feb 26, 2008
Jazzy wheelchair scooter 1450. Why does it go crazy with flashing (charging lights)?
Hi Emilee,
The lights flashing crazy, may mean you have locked out joystick. to unlock, try first, turn on joystick and push horn button twice right away. if that did not work, try turn on and push lever forward all the way wait until it beeps, then back all the way until it beeps again. that should do it. If not then count how many lights are blinking and how many times it blinks. consult owners manual trouble shooting guide for answer, or call 800-800-8586 Jazzy tech
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 12, 2016 | Health & Beauty
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
First four lights on cycle indicator flash and machine beeps 10 times and then beeps every 30 seconds
I recomend checking drain hose for kinks or obstructions and checking drain pump. most dishwashers will drain first for about 25/30 seconds.Also check the drain hose into the main plumbing connection it maybe blocked.If it cant drain it wont do anything hope this helps.
Feb 17, 2012 | KitchenAid Dishwashers
L65X Dishwasher problem
has there been a soultion mine is doing the same?
Jan 10, 2012 | Dishwashers
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
After selecting a program, the dishwasher beeps for a while and the 3 buttons on the left flash too. Program wont start, water wont fill and nothing happens. THe lights keep flashing but the beeps stop for...
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
Aug 13, 2010 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    My playstation has the light trun green yellow flashing red light
    With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
    Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
    CDA CW 446 dishwasher problem
    Emma:
    Is there a reset button on it? If so, press that. There are also sequences of buttons which one has to push to reset it. These are kept secret. Try pressing Hi Temp and Heated Dry, turn loose and press again within Five seconds. Or turn off the electricity and see if that resets it
    May 11, 2008 | Dishwashers
    Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
    639 people viewed this question
    Top Haier Dishwashers Experts
    Tim Doolittle
    Tim Doolittle
    deton8 von Splosion
    Tom Chichester
    Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
