Question about Whirlpool Washing Machines
Whirlpool front loader washer does not move further on programs. Only the water inlet and water drain program works. Other wash and rinse programs does not work.
  • zarraff Sep 10, 2008
    I did called an authorised whirlpool Service Technician and he said that it was the timer that's gone which needs replacement. How much would the timer for the model WF/665/1 cost? Can I get it in the market and replace it myself?
    Problem Solver:
  • 3 Answers
You may want to check into your warranty status. I work for a rent to own service and have seen this quit often. Most of the time when service calls us, it's the front control panel going out. You should really get a whirlpool tech to check it out.
FYI.... There is a compartment located behind the bottom panel on the front of you machine which catches all your change in a little box. You can remove that panel farely easy. Just thought you might like to know.
Posted on Sep 10, 2008
Whirlpool front loader washer will not do the last drain and rinse cycle. Cleaned the drain pump but still doesn't work. When it gets to the last cycle it just beeps every couple of seconds.
check the pump motor if running when the program is in drainning time,if not!check the power going thru the motor or if theres is, or check the motor winding if its okey!
Oct 03, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Front loader washer will not start F-1 light blinking
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Feb 12, 2013 | Maytag EPIC MFW9700S Front Load Washer
My whirlpool steam duet washer won't pour water in the wash cycle
There is no output from the control panel to switch on the inlet valve, so check the inlet valve at this time of the cycle. Also check the water level pressure sensor switch.
Choose another program to confirm if not the controller seems to be suspect.
Jan 24, 2013 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washer won't drain or run thru any cycles.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jan 14, 2013 | GE WSXH208A Front Load Washer
Problem with Kenmore H3 front loader not running on? Light flashes but washer will not run.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 25, 2012 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kitchenaid washer model kawe742wwh1; when it gets to wash cycle will stop completely.
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect. If the machine stops at the wash cycle after the pressure sensor works then it can be the control panel board as the processor or drive is faulty and so there is no output to the motor.
If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jul 04, 2012 | Whirlpool Washing Machines
My front loader will not spin the water out
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jul 02, 2012 | Frigidaire Washing Machines
Whirlpool duet after pressing start button nothin happens. goes thru add garmet and wash just beeps. no water rushing in
If there is no water flow the inlet valve is a suspect.Check this link to replace the inlet valve:
Thank you for using fixya.
Sep 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore front loader is not spinning. everything else works fine, it tumbles when washing, it drains, it rinses, etc, but it just wont spin. is there anything you could help me with to fix it myself? ...
Aug 30, 2011 | Kenmore HE2 Plus Front Load Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Washing Machines Logo
162 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
