Hello, plugged in my hard drive, error message "USB over current detected" pop up instead :( Any idea?
    Scholar:
  • 69 Answers
That is typically a general error seen on many devices.
Normally it means you are plugging in a USB device (your hard drive) and it requires more power than the USB port can put out. Many TV's and DVR's don't like USB powered hard drives, they want hard drives that plug into the wall AC outlet for their power. If your hard drive has a second USB plug, or a AC plug, you will likely have to use them in addition to just plugging the USB cord into the TV.
Posted on Aug 29, 2011
SOURCE:
Windows update stops working, check for updates failed
I've found that re-registering the dlls has solved quite a lot of windows update issues. have you tried this?
see method 5 here:
http://support.microsoft.com/kb/326253
Dec 22, 2012 | Toshiba Satellite X205 Notebook
Tip
How To Fix Usb Device Not Recognized in Windows
Sometimes, when you plug a USB device to your computer you may receive a Usb Device not recognized or usb port not working pop up message. If your USB device is not detected, then we will show you how you can troubleshoot usb not recognized error.
Follow Quick Steps To Resolve Usb Not Recognized Error Windows:
Press "Windows" + "R",a run window will open
In the "Open" box of the run window type "devmgmt.msc" and press "Enter"
This will open theDevice manager
Click on the arrow besides "Universal Serial Bus controllers"
Right click on each USB port and then click on "Uninstall"
Restart your computer and wait for Windows to re-installs USB controllers.
Try to connect yourUSB deviceagain.
How To Fix Usb Device Not Recognized In Windows 7 8 1
on Jan 28, 2015 | Computers & Internet
Tip
External Hard Drives
Most problems involving "external hard drives" have 1 thing in common: "Machine won't recognize the hardware". This has been an issue ever since they were introduced to the market. In most cases, this involves a hardware conflict amongst USB devices. To verify if this is the case:<br /> <ol> <li>Unplug all USB devices</li> <li>Reboot the computer</li> <li>Plug in the external hard drive</li></ol>The hard drive should now be detected. Once detected, you may now plug your other USB devices back in. <br /><br /><br />
on Mar 19, 2011 | Computers & Internet
Windows xp sp3 stop error message 7e usb
Why not just pull it out instead of clicking on safely remove hardware? Try it and see if it works. Sounds like your usb drive is not windows 7 compatible. Or windows 7 has some driver issue which is not uncommon.
Jun 04, 2012 | Hitachi 1TB LifeStudio 35 Desk Plus...
Mine keeps saying "USB Over
The power adapter could be faulty.
If you get an error message"Insufficient power to operate USB device" when you plug a USB deviceinto the computer's USB port, then this device is drawing excessive currentthat the USB port cannot supply. In case such as this, youneed to purchased a powered USB hub and connect this hub into the computer'sUSB port and then connect the USB device into this powered USB hub.
Apr 14, 2011 | Western Digital 250GB MyBook External USB...
Tip
No Hard disk detected / boootable device
<span>When the computer/laptop cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message </span>- <span>"No bootable device. Insert boot disk and press any key"</span><span><br /><br />First thing, check to see if the is a floppy disk inthe floppy drive, if so removes this disk.</span><br /><span>If there was no disk in the floppy drive then it maybe a hard disk problem.<br />Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.<br />If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.<br /><br />A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.<br /><br />To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.</span>
on Jan 17, 2011 | Computers & Internet
I am getting the error message-"Hard drive not
it caused the hard drive malfunction try open the bios and try to read the hard drive is your hard disk stll there. in some case on the hp compaq laptop the hard drive was detecting eror but it can be use to external hard drive.
you can find some usb to mini ata or usb to sata to try your hard drive on another laptop or pc(make it external hard drive)
Jan 14, 2011 | HP Pavilion dv5-1132us Notebook
Freeagent Go not recognized as an identifable USB device.
I plugged mine's directly through the back of my computer instead of the hub in the front and it's working fine.
Mar 02, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
