Question about NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor
My monitor not stay on
When i turn on my monitor the display show up but after a few seconds gone everything
  • 3 more comments
  • FarmerDave Dec 30, 2007
    I have the same problem. Hooked up another monitor and it functioned with no problem, so I'm assuming fault is in the NEC monitor.
  • pippy187 Apr 10, 2008
    Start-up it displays for a second then it displays nothing.but if you unplug the power and plug i back in again it goes on and off again
  • marnold52 Oct 06, 2008
    2005 model multi synch NEC 17" flat panel monitor. 3 months past warranty expiration and it turns itself off every few minutes. I have "jiggled" all of the obvious wires and connectors, but problem persists. I am plugged into Mac Mini with Tiger OS 10.4, which, by the way, also started acting up 3 months past warranty exp. date
  • hasselhoffer Feb 08, 2009
    Yes I have the same problem -way past warranty and just through out my 17inch FG (tube), what a workhorse that was.. wish I still had it now.
    So my NEC MultiSync LCD 1700V turns on for a second then off.
  • johnny duchesneau Mar 11, 2009
    I also have the same problem....the display lights up for one second then goes dark.....if I turn the power off and then back on...it does the same thing.
  • 38 Answers
Very common for this model that top backlight globe goes faulty. Can be also inverter PCB fault. If you have couple spare lights connect them to your inverter instead of panel lights and see if fault remains.
Posted on Apr 09, 2006
    President:
  • 814 Answers
This monitor is going into the protection mode due to a componentfailure. The unit should be sent or taken in to a service center fortesting and repair. The NEC customer support telephone number is1-800-632-4662. The website for customer support iswww.necdisplay.com/support center. They will be able to tell you whereyou can take you monitor for servicing. I hope this information helpsyou with you problem
Posted on May 24, 2009
Tft problem
your monitor might not recieving incoming signal thats why it turns off try to examin your cpu this might be the problem your system is no booting...replace your videocard..
May 20, 2010 | ViewSonic VX2235wm LCD Monitor
Proview Monitor Blank display after 3 seconds issue
First place to look will be the power supply section, look for bad caps (bulging tops or bottom seals), the post back what you see so we can guide you further for direction such as voltage checking, see example of failed monitors due to bead caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Xerox XG-91D 19" LCD Monitor
Computer keeps turning on and off, plus monitor won't display
Sounds like a loose wire inside the system touching something inside and shorting it out. My brother had this same problem. I brought it to my house to work on it and it was fine, no problems. Open the panel and look for any wires that are touching metal or something else and tie it up out of the way. I won't swear that is your issue, but sure sounds like it.
Jul 27, 2009 | Gateway FPD1975W 19" LCD Monitor
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Apr 01, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
My SVA monitor 5 blacks out after 5 seconds
use f 8 to go to safe mode then set the resolution at the very least liek 8 bits or whatever the lower=st is and save it then restart in normal mode and then play with the resolution in display settings to get to the ma your video card will support.
Jun 19, 2008 | Gateway FPD2275W LCD Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
NEC MultiSync LCD1700V 17" Flat Panel LCD Monitor Logo
569 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
