Model # request
It has a paper tag says kf 83  zbm   spec # xh /us --i think it requires a 5 digit code  using 1-6 preset buttons
  • 4 more comments
  • robert clark Sep 10, 2008
    i need the code to unlock the radio --i am pretty sure it is a 5 digit code, i cannot find serial # to go to dealer to look up, have aquired 3 different units ans the have no ser # on case --the only identifying tagws the model # i sent in last response --
    sorry the model is ke 83  zbm    there is a mode button , when i try procrdure all i get is code on display --i turn off--- hold the mode button----- and turn radio on --it beeps and code is all that will display i did not find as button as i gave u wrong model number it probably doesnt apply to this model --thanks rec---i can e mail u picture of face if it will help identifing model this unit has weatherband button thanks
    no number appeared just the word CODE--i tried with 2 different radios
    anyone still there or do  u give up.
    lets try again, first  i realize i need serial # of unit to get accesss code for this radio  this unit needs a 5 digit code using numbers 1-6 , i turn key off and  off hold the "m" buttton  which i understand to be the mode button on my unit cause there is no "m" button. while depressing mode button with radio off i turn key on and then turn radio on,,,,,,all i get is 1 beep and the display still shows "CODE"
  • micromaster
    micromaster May 11, 2010
    may i know please the your problem.
    thank you
    Brigadier General:
  • 3,614 Answers
May i know please the complete information regarding on your problem/
thank you
Posted on Sep 10, 2008
  • 4 more comments
  • micromaster
    micromaster Sep 10, 2008
    Comment by micromaster, posted on Sep 09, 2008
    as an initial info:
    please try this code : 3511
    Comment by micromaster, posted on Sep 09, 2008try one of these 9131,1131 if still not work maybe eprom was reprogrammed and now is another code.
  • micromaster
    i will give you some certain recommendations that you have to do:
    The code is possibly 3184....If not try 5024....But first you will have
    to "unlock" your radio..Do this as follows : press AS plus the ON
    button at the same time and leave it on undisturbed for at least a
    couple of hours* see note below ....(don`t press any other buttons
    After a couple of hours (or more) just enter the code , press AS
    again (you should hear a "beep") and all should be OK. However if the
    radio switches itself off automatically after an hour or so , and it is
    still locked then you are going to have to take it out of the dashboard
    and wire it up via the ISO socket at the rear to a battery (plus
    connect a speaker) and repeat the above. (AS plus ON together then
    leave for at least 11 hours. )
    This normally works + should then reset
    it. ...*note: The length of time to leave it switched on depends on how
    many previous incorrect codes have been entered. If it was 10 , then
    the time will be 640minutes (nearly 11 hours). Please post back here
    whether successful or not..Good luck
    Just let me know here again...
  • micromaster
    With key in off position:
    • Press and hold the "M"
      button on radio.
    • While holding "M"
      button turn key on and turn on radio.
    • Radio serial# should
      show on display.
    • Write this number down.
    • You should double check your radio serial number for
      accuracy, as incorrect number will delay your radio code
      retrieval process!
    NOTE: CODE RETRIEVAL NEEDS THE SERIAL NUMBER OF THE UNIT..
  • micromaster
    did you write down the code that appear???
  • micromaster
    wait... have you try doing this one:
  • micromaster
    micromaster Sep 11, 2008
    try on this supported sites BMW radio
    codes
Can you provide me the code for BLAUPUNKT IDC A-09 BP915034455060 7 607 769 150 prod NR fiat : 735 273 184
CODE 5731
Code Entry as Follows:
If Required, Enter Code in Head Unit First.
Press And Hold " CD.C" Button
The Display Shows "CD Player" Then "0000"
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press Tuning Up Button " ^ " To Enter
Nov 25, 2014 | Blaupunkt IDC-A09 5 Disc In-Dash CD...
Hi Can anyone help me unlock my ford mondeo Radio? Serial Number M124058. Thanks?
your radio code should be 4944
follow these instructions to enter code
Switch the ignition ON using the key
Switch Radio ON - Display Shows CODE with " - - - - " flashing
Press Preset Button " 1 " repeatedly for 1st Digit of your KeyCode
Press Preset Button " 2 " repeatedly for 2nd Digit of your KeyCode
Press Preset Button " 3 " repeatedly for 3rd Digit of your Keycode
Press Preset Button " 4 " repeatedly for 4th Digit of your Keycode
If the display now shows the correct KeyCode number then
Press Preset Button " 5 " to Enter
May 09, 2012 | Ford Mondeo Cars & Trucks
I tried to put 3 different codes into my ford focus radio after having recharged the battery and after entering the 3 sets of numbers that i found on the top of the radio it started counting down,,,can...
Good Day Konnie!
Try code 6151
To Enter the Security Keycode for a Ford
1. Switch the ignition ON using the key
2. Switch Radio ON - Display Shows CODE with "-------" flashing
3. Press Preset Button " 1 " repeatedly for 1st Digit of your KeyCode
4. Press Preset Button " 2 " repeatedly for 2nd Digit of your KeyCode
5. Press Preset Button " 3 " repeatedly for 3rd Digit of your Keycode
6. Press Preset Button " 4 " repeatedly for 4th Digit of your Keycode
7. If the display now shows the correct KeyCode number then Press Preset Button " 5 " to Enter
Please do rate my answer.
Thank you for asking Fixya.
Aug 06, 2011 | Ford Car Audio & Video
I have the code for my ed station wagon number is 2602 problem is there is no zero number on radio how do you enter the code.Thanks for your help
The code entry instructions depend on the make + model of radio.
See if you can find your radio here
CLICK HERE
Many radios require the multi-pressing of Preset Buttons 1 , 2 , 3 , and 4 to be used for each digit separately
For example
Press Preset Button " 1 "repeatedly until the 1stDigit of your Code is displayed Press Preset Button " 2" repeatedly until the 2ndDigit of your Code is displayed Press Preset Button " 3" repeatedly until the 3rdDigit of your code is displayed Press Preset Button " 4" repeatedly until the 4thDigit of your code is displayed
Mar 02, 2011 | Car Audio & Video
Put code in to my ford radio which button do press to enter
usually the 5 Button (occasionally 6 Button)
Ford Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
Oct 03, 2010 | Metra 86 5618 Ford Radio Removal Tool
Security code harman kardon
I think its fairly standard across all Land Rovers. You only actually need numbered button <1> and the two seek buttons that look like <| and >| .
When you turn the radio on, you should see it request <CODE>
Press preset button <1>. This should identify character 1 of the code.
Use one of the two tuning buttons (Seek up , or seek down - the ones with arrows going into lines) to move to the right number (0-9).
Press preset button <1> again to lock digit 1 and move onto code digit 2.
Repeat twiddling the upseek and downseek. Press button 1 etc .... until all four codes have been entered.
When you press <1> for the final time, if the code is correct, you'll get a two tone beep to confirm and the radio is unlocked.
If incorrect, you are progressively locked out (in doubling time periods).
Hope this helps.
Jan 03, 2010 | Alpine TDM-7561 Cassette Player
Radio code required for ford fiesta
Your code is 0051
The set should now operate
Oct 11, 2009 | Car Audio & Video
Sony kf-60we610 stand by blinks 5 times
Hey there,
I've had my Sony KF-50WE610 for approx. 4years now and have just experienced the prob you described (though I didn't think to count the number of red blinks). I called Sony TV technical support (888-772-7669, #3 for TV/digital cameras, #1 for TV, then #1 again I think). They said that if the power/standby light blinks 5x, that means there's something wrong with the lamp driver and service will be required. Needless to say, I better go home and count my red blinks! Good luck, I hope this helps a bit. Have a happy and safe holiday!
Dec 09, 2008 | Sony XL-2100U Projector Lamp for...
1990 bmw radio unlock code
I have a Ke-83xbm. there should have been a serial number not on the same tag as the fcc#. Mine was a # on hte very back end of the radio by itself.
Sep 15, 2008 | Car Audio & Video
Javyo
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Oct 31, 2007 | Kenwood KDC-MP228 CD Player
 Grubhead
Grubhead
